Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Bobbin thread After finishing a throw I made out of fleece, I took the bobbin casing out so I could remove all the lint. I replaced the bobbin casing exactly like the manual shows, but now the bobbin thread gets all tangled up and my machine stops and beeps. I have to use scissors to cut the fabric away from the tangled bobbin thread. Please help!!!!! I have a lot of pillow orders due!!
  • Singer Master
  • 1,388 Answers
That all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
bobbin thread - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Mar 16, 2008
  • 57 Answers
Double check that the bobbin case thread is pulled through the bobbin case tension. That would be the most likely cause . Also make sure that the bobbin case is seated properly. If the top thread wraps around the bobbin case making big loops, THAT is probably the problem.
    Genius:
  • 1,665 Answers
Hi have a nice day!
I would pay attension at cleaning and lubricating instructions.The link may be helpfull.
    Guru:
  • 1,894 Answers
Have you oiled the bobbin section in which it is inserted??
  • dewan nafees ahmed Mar 16, 2008
    as it is a new one ...it will take sometime for the thread to pass out of it freely....now the joints will be gripping the thread....
    just keep using it continuously...it will be fine
The bobbin assembly has a lot of tangled up thread and is jammed. How do I clear it?
Avoid attempting to run the motor if the machine is bound--it may damage the motor.
Remove the presser foot and, if you can, remove the needle. Then remove the needle plate, the bobbincase, and the hook. If you are unable to remove some of them, you may need to use a small pair of scissors to snip the threads and gently pull them out with needlenose pliers or tweezers.
Once you have the thread tangle removed, clean with a soft brush to remove all the lint and thread bits and place a drop of good quality sewing machine oil (preferably Bernina oil for your machine) on the bobbin race. Install a brand new needle (in case the old one was damaged).. RAISE the presser foot, remove all the thread, and rethread from the very beginning. (The raised presser foot releases the tension disks so the thread will seat properly.) Use good quality thread--avoid old or bargain bin thread (some Berninas object strenuously to Coats & Clark thread too). Some threads create heavy lint buildup in the tension disks and bobbin area in addition to hanging up in the needle and elsewhere. Also, some fabrics shed more (ie fleece), so be sure to clean often. Try to oil your machine as instructed in the owner's manual--every time you change a bobbin, after 8 hours of constant sewing, or every 6 months if not in regular use.
When Thread is Caught in Sewing Machine Sewing Lessons
How to Fix Thread Jam Sewing Machine
Anyone have experience with jammed bernina sewing machine Discussions...
Having trouble with my new Bernina 820
This video may help avoid thread nesting:
How and Why to Bring up the Bobbin Thread
Oct 21, 2015 | Bernina Sewing Machines
Every time i thread my machine up my lower looper keepssnapping. what is causing it as everthing elseis threaded ok
Did you remove the plate covering bobbin and clean out any thread and lint bits that might be catching and causing the problem? Also take out the bobbin case and see if there is any thread nesting there. Be sure you get that case in just right or it won't spin properly and loop top and bottom threads together. I sew a lot of fleece and textured fabrics so my motto s always, " when in doubt, clean it out". Works 99+++% of the time.
Feb 12, 2015 | Sewing Machines
The upper thread breaks immediately I start operating
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw
to remove the old needle, place the new needle in the clamp with the flat
side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then
tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads
or lint
Apr 17, 2012 | Sewing Machines
I need to adjust the bobbin/lower thread tension on my Freesia Viking sewing machine.... Now I know why it was sold. I sew lots... but am at a standstill on how to remove or get to it to adjust it..
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 08, 2011 | Husqvarna Freesia 415
Needle keeps jamming, won't thread
Good day!
Good day!
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
Cannot get the tension right and the thread keeps braking
Good day!
Good day!
Jun 05, 2011 | Singer Inspiration 4206
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
Good day!
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
Bunches of threads on the bottom
You didn't give the brand, but if it's any of the older, non computerized machines, your problem is most likley in the tensions.
Loopies (tangles or nests of thread) on the bottom means upper tension too loose (or bobbin too tight).
Let's do the bobbin first...once it is set...99.9% of loopies on the underside are a problem with upper tension.
This is for bobbins that load on the front/side of the machine.. Take out the bobbin case...check the area (hook/race area) that the bobbin goes into for lint, tiny thread pieces, etc.). Now, most of this type of bobbin loads into the case with the thread going counter clockwise (when you are looking at the open side of the case), insert the bobbin in the case, and pull it through the hole/slott in the side of the bobbin case. To test for proper tension:
Lay the bobbin case in the palm of one hand, pull on the thread coming off the bobbin case. The bobbin will gently lift off your hand & if you wiggle the thread, the bobbin case should slowly drop about an inch at a time. If it's too tight, loosen the Larger (closest to where the thread comes out) screw on the side of the bobbin case about 1/16 of a turn...tiny bit...retest. Once that is done try a test stitchout. Remember to hold onto the bobbin & top thread for first few stitches.
If you still get loopies on the bottom...tighten the upper tension...it should be set between 4-5 for regular sewing.
Make sure the needle is in properly.
For a drop in bobbin...adjusting that tension is harder. You take the face plate (needle plate, the plate covering the sewing area of the machine) off and remove the bobbin case...First...look at the case in the machine...there is a little lip sticking out, usually at the bottom right corner of the open area (closest to you)...this is where you need to have the little lip when you replace the bobbin case.
Remove the case...check under it and inside the machine for lint/dust/threads & using a small paint brush (I use a childs tooth brush sometimes), clean the lint out. Now check the bobbin case for lint, especially where the thread fits..look at the inside of the case, you will see a little flat metal thing with a slott in it...make sure no lint in that slott. I use a pin to remove lint from there. Reinsert the bobbin case, rethread it all, (bobbin goes counterclockwise). Put the faceplate back on & test the stitches...still loopies with the upper set to between 4-5? Then you will remove the faceplate, remove the bobbin case & loosen the screw on the outside about 1/16 of a turn (these are usually covered in a colored coating) and retest.
I know that most home machine makers say not to adjust the bobbin..but that was back when you had one size thread...now we have many, many sizes and types of thread, so adjusting the bobbin may be needed sometimes.
Rule of thumb is:
loopies on underside...tighten upper tension
loopies on top...loosen upper tension.
But, like I said...with all the new threads..sometimes you have to adjust that bobbin.
May 12, 2010 | Sewing Machines
Sewing machine thread nesting
I have fixed it now the bobbin case didn't seem to stay seated during sewing or tangling i should say!. I decided to change the needle and from then on everything worked fine.
May 04, 2009 | Riccar R650
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
151 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
