Question about Canon Cameras
Canon 60D SLR Fails to power
Canon 60D SLR
Fails to power up with LCD only momentarily either saying 100 ISO or the usual photography details. LCD on top also occasionally reads ERR CF - but we have tried with different Complact Fashcards.
Back screen does not come on other than momentarily and will not take photos. Have had plugged into mains with same result.
    Sergeant:
  • Canon Expert
  • 488 Answers
Check to see if one of the connection pins in camera is bent.
Posted on Nov 18, 2017
Nick Spirov
  • 35 Answers
SOURCE: Err CF
Observe the connector inside camera, using a flashlight. If there is a bent pin take the camera to service immediately. Don't turn it on any more as we did in one similar case - creating a short circuit that damaged the camera electronics and voided the warranty.
If no visible problems, remove battery and leave it out overnight.
Posted on Jan 16, 2008
thomtime
  • 38 Answers
SOURCE: Canon 350d not turning on/screen not working/
Does the camera work properly with the CF card removed? If it does than the CF card is the problem. Try formatting the card with the camera or getting a new one.
Posted on Feb 09, 2009
ginko
  • 19396 Answers
SOURCE: Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Nope, this is not card anymore.
As you know CF is card failure, sometimes this cause to start error 99 , that is lens error , even if there is no problem with the lens.
This happens because the built in software in the camera can get messed up after an error CF.
You fix the problem calling Canon, they will guide through upgrading the firmware in your camera.
First ensure that you are using the camera menu and command to format the new card, and that new cards are properly inserted into the machine.
Call Canon support to get a firmware upgrade.
Posted on Feb 13, 2009
SOURCE: Canon rebel xt eos shows ERR CF. What do I do now?
Check that the pins in the camera that connect to the CF card are clean and not bent. You will probably need a good light and a magnifying glass to see into the card slot. If you can see a pin that is bent you could try straigtening it. BEWARE- turn off camera and use a non conducting "stick" ie cocktail or toothpick. Not sure for a Canon but a colleague paid £40 for a new pin assembly for a Nikon with similar problem.
Hope this helps.
Steve A.
Posted on May 08, 2010
  • 214 Answers
SOURCE: I was shooting pics and
hi, You might has cf receptance uinit defective ( the cf pin in your camera) or circuitry shorting in somewhere. the canon product has some production defectiveness. Screws falling out some period use and handling. Or just cf card failing... Would you give more detail problem... Thanks and good luck with you!
Posted on May 21, 2011
60d flash pop up
Mode dial is set to an auto mode or the setting is set for flash photography. Change that and the built-in flash unit won't pop-up every time you press the shutter button.
Feb 28, 2015 | Canon EOS 60D Digital Camera
How do i take indoor actions shots with the rebel xs
Indoor actions shots are tough to take because of dim lighting and fast moving subjects. With the right settings and equipment, it can increase your chances of getting that perfect shot.
The Perfect Camera Settings for Action and Sports Photography
Feb 06, 2013 | Canon EOS Rebel XS 35mm SLR Camera
I have a ricoh kr-30sp camera will not come on and what kind of film do I use
With the camera turned on, look in the viewfinder. Down on the bottom right side is an LCD display, if it's blank then your camera probably has dead batteries. It takes 2 x CR1/3N or 4 x SR44.
Your film accepts 35mm negative film or 35mm transparency (aka slide) film. It will accept any ISO from 12 to 3200, but in practice all you'll usually need are ISO 100, ISO 200 or ISO 400. You choose the film based upon lighting conditions and the lenses you'll be using, but in general you'll use ISO 100 if shooting mainly outdoors in daylight, ISO 400 if shooting in low light or with a telephoto lens, and ISO 200 is a general all-rounder good for most things. ISO is usually referred to as film speed as higher numbers need less exposure than lower numbers but the trade-off is a less detailed image.
To load film into your camera and to set the camera to match the film ISO setting refer to this link to the manual provided by Norman Butkus. The manual will also guide you through all other aspects of operating your camera.
I hope that I have fully answered your question, but if not please add a comment and I shall respond in due course. If your question has been answered, then please let me know by taking a moment to rate my answer.
Sep 15, 2010 | Ricoh KR-30SP 35mm SLR Camera
Question on SnapSights waterproof camera
The SnapSights SS03 is a non waterproof camera supplied with 200 ISO film so you clearly have the SS01 model for 800 ISO. Both cameras have fixed aperture and shutter speed and rely on the wide exposure latitude of print film. 100 ISO is ideal if you have a camera with a wider aperture than yours, but if you use it then photos will be three stops underexposed; you'd possibly get away with this on land but underwater shots typically have more shadows than highlights and you'd lose a lot of photographic detail. By using 800 ISO the camera will produce photos which are noticeably grainy and with high contrast demonstrated by less detail in shadow areas and overexposed highlights, but for most purposes the photos will be acceptable and far better than none at all.
Colour negative film has a wide exposure latitude so you may wish to experiment with using 400 ISO or even 200 ISO. 400 will be one stop underexposed, but the printing stage can compensate to produce shots which are less grainy with better shadow details but which will lack some highlight detail. This can be partially compensated for if you tell the processing lab to "push process" your film at 800 ISO, but this will usually cost extra and for just one stop under I wouldn't bother, 200 ISO is really stretching it though and you may find that results are unacceptable unless you push process. Ultimately, it all depends upon how dark and how deep you go, but at much below 1,5m everything gets a strong blue colour cast anyway unless you use a powerful underwater strobe light mounted away from the lens axis.
Basically your camera is designed just to give you a taste of underwater photography and is very limited in what it can achieve. Even with a good specialist 35mm underwater camera such as the Sea & Sea MotorMarine II I usually find that I only have one or two usable shots on a 36 exposure roll, so if you do get the underwater photography bug then invest in a decent quality underwater digital model which accepts a proper external strobe lamp. The ratio of failed photos is similar, but at least you can review and delete them immediately without expense.
Jan 09, 2010 | SnapSights Intova Snap Sights SS03 Film...
Underexposure problem maybe? please help!
Your camera probably needs a new battery.
The light meter needs sufficient power (5.5v to 6v) to work correctly.
Your ISO could have moved, even a double or halving of it will over/underxpose a full stop.
Nov 10, 2009 | Canon EOS-AE-1 35mm SLR Camera
Cameras Logo
807 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
