Question about Toshiba Satellite M30X Notebook
Toshiba Satellite M30X/m35x
The power butten lights up and the fans and stuff work but the screen wont come on
    Scholar:
  • 105 Answers
Try an external monitor - if that works then your screen or cable is faulty. If not try replacing the ram - if you are using two sticks of ram try booting with each stick individually to see if one of them is faulty. If it does not show a display with known good ram of the correct type then it may be the processor that is faulty.
Posted on Mar 16, 2008
SOURCE:
Coffe spill now screen on lap top not working
No magic fix here Philip. The only thing to do is immediately remove ALL power, AC adapter (Charger) and Battery, and open the laptop up, remove the CMOS Battery, (RTC Battery), and dry it out THOROUGHLY.
After you are SURE all components inside the laptop are dry, reassemble.
Install the Battery, then the AC adapter.
Plug into power. WAIT 1 minute, turn the laptop on.
[ On ships they use old coffee to clean the deck. It has powerful acids in it. Don't get your hopes up in otherwords ]
1) http://www.irisvista.com/
(Read the entire page )
2) http://www.irisvista.com/tech/laptops/ToshibaM35X/satM35X_1.htm
3) http://www.irisvista.com/tech/laptops/ToshibaM35X/Satellite-M35X-display-1.htm
4) http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the heading that starts with - Satellite A10. (A10 in blue)
Drop down to the fourth line (L655), and scroll across to - M30X
Click on the file name M30X.
(The Toshiba Satellite M35X-S161 Notebook PC, is part of the Toshiba Satellite M30X series of Notebook PC's )
After you click on the file name (M30X), it may take up to 30 seconds before the first page comes up.
A) Buy and wear an ESD wrist strap. Average cost is around $3 to $6.
Connect the alligator clip to a good ground source.
(Electro Static Discharge)
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
IF, the computer is still good you need to give it a fighting chance.
B) Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
There are MANY screws that look VERY similar to other screws.
DO NOT mix them up.
C) Make a personal record as you disassemble.
Make notes, and drawings. (Legible)
Use a digital camera, or video camera if available. Use good lighting.
It's nice to have a personal record to refer back to, in case you are interrupted.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 29, 2012 | Toshiba Satellite M35X-S161 Notebook
I was given a Toshiba Satellite. M35X-S149. Celeron M. When turned on I get a beeping noise and the screen is black it never loads up or show the Windows screen. The fan runs a couple of seconds then...
Try reseating the ram modules. If this dosn't work remove them one at a time but keep them in the same slot...do not switch slot, rebooting after each removal. If you remove one and it boots up then ram is bad for that slot. If this doesn't resolve your problem then repost with exactly how many beeps and in what sequence as they are diagbostic codes.
Good luck
If this helps you resolve your problem, please
consider giving me a rating of 4 and maybe a
"thanks" It will help me as well. Thank you.
Dec 03, 2010 | Toshiba Satellite M30X Notebook
I have Toshiba satellite M35X-S163 when press power cpu fan start and hdd run for 2-3 seconds then gose off nothing on the screen internal or external ; in addition no battary charging . battary and the...
in the pic that is not m35x that is m30 ... if u have m35x ...and no display open the laptop near the power jack there is maxiam ic ... jsut heat that ic.. hope that will work .. if not let me know thanks
Oct 08, 2010 | Toshiba Satellite M35X-S163 Notebook
Power on but no screen oor hard disk motion
Hello there:
i would suggest using a spare monitor and connect the cord that would normally go into a computer and connect it to the laptop and then plug in the power cord for the monitor and turn on the computer if this works and everything is ok then you know that the laptop screen may be faulty or there may be a loose connection somewhere ok?
best regards michael
Sep 11, 2009 | Toshiba Satellite M35X-S111 Notebook
Laptop doesnt work
if the power cord is broken, you need to buy a new one... bring the broken cord to the store if you want to purchase a new.. so that they will give you the right power cord for your laptop...
Jul 20, 2009 | Battery Technology for Toshiba Satellite...
Satellite (A75S206) runs well from outlet but never from battery. Was told that mobo can't accept dc. Need new mobo. True?
hello loyd516,
Have you tried a new battery? They are much much cheaper, and a whole lot easier to replace than a motherboard.
Here are replacement batteries that I found searching with Google.
http://www.google.com/products?q=Satellite+A75-S206+battery&hl=en
According to Toshiba, there has been a battery recall for your specific model.
If that is the case I would definitely contact Toshiba support about it. Maybe you will get a free battery out of the deal. Who knows.
Here is the link and the list(your model is highlighted)
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=1501060
Sony Battery Pack Recall Programs Document ID: 98082080 Posted Date: 10/10/06 Last Updated: 10/30/08 Operating System: N/A Category: Battery Distribution: Public
Applicable Models:
Satellite A70-S256, A70-S2561, A70-S2362, A70-S2491, A70-S2591, A70-S2482TD, A70-S2492ST, A70-S259, A70-S249, A75-S206, A75-S2091, A75-S2292, A75-S2291, A75-S229, A75-S209, A75-S2061, A75-S226, A75-S2261, A75-S276, A75-S1255, A75-S1254, A75-S1252, A75-S1253, A75-S1251, A75-S125, A75-S2131, A75-S213, A75-S2112, A75-S2293, A75-S2311, A75-S231, A75-S2111, A75-S211, A75-S2761, A75-S2762, M30X-S1592ST, M30X-S1593ST, M30X-S191TD, M30X-S181ST, M30X-S171ST, M30X-S221ST, M30X-S221TD, M35X-S149, M35X-S1491, M35X-S109, M35X-S309, M35X-S3091, M35X-S329, M35X-S1631, M35X-S163, M35X-S1143, M35X-S1142, M35X-S114, M35X-S3111, M35X-S311, M35X-S1611, M35X-S161, M35X-S111, M35X-S1492, M35X-S3291, M35X-S349, M35X-S3491, M35X-S3112, M35X-S1141, M50-S418TD, M50-S4182TD, M50-S5182TD, M50-S5181TD, M55-S135, M55-S325, M55-S3262, M55-S2253, M55-S3251, M55-S1351, M55-S1352, M55-S3511, M55-S351, M55-S3294, M55-S3293, M55-S3292, M55-S3291, M55-S329, M55 Series, M55-S2252, M55-S3512, M55-S3315, M55-S3314, M55-S321, M55-S3313, M55-S3312, M55-S3311, M55-S331, P30-S6362ST, P30-S6363ST, P35-S609, P35-S6091, P35-S6111, P35-S6311, P35-S631, P35-S6112, P35-S6053, P35-S6052, P35-S6051, P35-S605, P35-S611, P35-S6292, P35-S629, P35-S6291
Tecra A3, A3-S731, A3-S611, A3-S711, A5-S416, A5-S237, A5-S516, A5-S136, A5-S3291, A5-S3293, A5-S3292, A5-S329, A5-S118, A5, A5-S6215TD, A5-S116, S2, S2-S511TD
Jul 11, 2009 | Toshiba Computers & Internet
Looking for wireless on switch on laptop
Right Side, underneath your volume control. If it is switched on and still cant access the internet wireless give this a try.
Use Control Panel's Add or Remove Programs utility to uninstall the Toshiba Hotkey Utility, and then reinstall it.
This program is called E-Key Utility on the Toshiba Satellite M30X/M35X Recovery and Applications/Drivers DVD. It's called Toshiba E-Key Utility for Windows XP on the Toshiba Support website.
Unistalling the Toshiba Hotkey Utility:
  1. Click Start.
  2. Click Control Panel.
  3. Double-click Add or Remove Programs.
  4. Select TOSHIBA Hotkey Utility.
  5. Click Change/Remove.
  6. Click OK to confirm that you wish to completely remove the selected application and its features. The InstallShield Wizard will begin the removal process.
  7. Click Finish to exit the InstallShield Wizard.
Re-installing the Toshiba Hotkey Utility using the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD that shipped with the computer:
  1. Insert the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD into the CD/DVD drive and close the tray. The setup program on the DVD should start automatically.
  2. When the Toshiba Recovery and Applications CD window appears, verify that "Install applications and drivers" is the selected install type, and click Next.
  3. Select E-key Utility from the list, and click Install.
  4. When the WinZip Self-Extractor window appears, click OK.
  5. Click Unzip.
  6. Click OK to acknowledge that the files were successfully unzipped.
  7. When the InstallShield window appears, click Next and follow the prompts to complete the installation.
  8. When the installation is complete, click Exit and then OK to close the Toshiba Recovery and Applications CD window.
  9. Remove the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD from the optical drive and close the tray.
Reinstalling the Toshiba Hotkey Utility using the file downloaded from the Toshiba Support website:
  1. Download the Toshiba E-key Utility for Windows XP from the Toshiba Support website, and save it to your computer. See also the bulletin Obtaining downloads and support docs from the Toshiba Support website.
  2. Navigate to where you saved the file and double-click it.
  3. Click Run.
  5. Click Unzip.
Feb 21, 2009 | Toshiba Satellite M35X-S111 Notebook
Wont start or boot up
I had the same problem and found that disconnecting the power lead and repositioning the ribbon cable from the on switch did the job after about 5 attempts
Aug 13, 2008 | Toshiba Satellite M30X Notebook
Toshiba Satellite M30X Notebook Logo
148 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
