Question about Samsung HLN617W 61" Rear Projection HDTV
Fan locations I unscrewed one of the three fans while replacing the color wheel. The cables are still attached but I can't find the locations to reattach the fan. Since the cables are still attached it should be a snap. Easy for you, not so much for me.
    Genius:
  • 3,587 Answers
Extend the cables to their furthest length, along the back panel, and your arc will bring you to the only set of holes that match up with fan.
Posted on Mar 17, 2008
Fan locations
that's not unusual...those might clip in..
Mar 16, 2008 | Samsung HLN617W 61" Rear Projection HDTV
How do i remove back and reinstall fan?
Welcome to Fixya
Here's the procedure:
1. Shutdown the laptop and remove the AC adapter. Disconnect any devices, such as a printer or external DVD-ROM or drive, that are attached to the laptop
2. Remove the laptop battery. Turn the laptop upside down, slide the battery release latch and then pull the battery out of the bay.
3. Unscrew the hard drive cover. Grab the hard drive tab and shift the hard drive to the left to unplug it. Lift the hard drive out of the bay.
4. Unscrew and remove the PCI memory cover, the optical drive cover, and switch cover.
5. Unscrew the two screws that hold the keyboard to the base, these are located in the middle of the rear panel. Flip the laptop over so it is right side up, open and remove the keyboard by using the keyboard release switches located above the keyboard. Next, unplug the Toshiba Qosmio E15-AV101 Fan cable.
6. Close the laptop and turn it over so it is bottom up. Unscrew the display assembly screws located under the laptop screen hinges. Turn the laptop over so it is right side up. Open the laptop and unplug the display assembly cable and disconnect the wireless antenna from the display assembly. Unscrew the display assembly from the laptop base and remove.
7. Unplug the mouse pad cable. Turn the laptop over so the bottom side is up and unscrew the base screws which are located along all four sides of the laptop base. Gently remove the base of the laptop.
8. Turn the laptop over so it is right side up. Unplug the fan cable from the circuit board. Unscrew the screws holding the Toshiba Qosmio E15-AV101 CPU fan assembly to the laptop. Lift the fan assembly out of the laptop.
9. Insert the new Toshiba Qosmio E15-AV101 CPU fan assembly into the lap top. Screw the assembly unit to the lap top and plug the Toshiba Qosmio E15-AV101 CPU cooling fan cable into the circuit board.
10. Reassemble the laptop by repeating the previous steps in reverse order.
Thank you for using Fixya!
May 10, 2011 | Toshiba QOSMIO E15-AV101 Notebook
Where can I find a schematic or instructions to open my toshiba satellite u205-s5067 laptop. I want to clean/replace my fan.
Taking apart a laptop to change the fan is a relatively simple task. Just keep track of where all the screws go and follow these steps:
5. Unscrew the two screws that hold the keyboard to the base, these are located in the middle of the rear panel. Flip the laptop over so it is right side up, open and remove the keyboard by using the keyboard release switches located above the keyboard. Next, unplug the Toshiba Satellite U205-S5067 Fan cable.
8. Turn the laptop over so it is right side up. Unplug the fan cable from the circuit board. Unscrew the screws holding the Toshiba Satellite U205-S5067 CPU fan assembly to the laptop. Lift the fan assembly out of the laptop.
9. Insert the new Toshiba Satellite U205-S5067 CPU fan assembly into the lap top. Screw the assembly unit to the lap top and plug the Toshiba Satellite U205-S5067 CPU cooling fan cable into the circuit board.
Hope this helps.
Apr 05, 2011 | Computers & Internet
I've a Samsung DLP Model HLR-4266WX that has started to hum and is distorting the picture. I've replaced the cooling fan on the heat sink in the back and that didn't work. Is there another fan in the set...
Color wheel would be cause of hum noise and distorted picture on screen.
Please note that color wheel is not user level repair and requires expertise because it is located in light engine, the most sensitive and expensive part of dlp tv.
If you are good with electronics stuff fix then have service manual copy in hand to start inspecting color wheel.
Aug 26, 2010 | Samsung DLP HL-P5663W 56" TV
After 10 sec. after start up the tv starts to make a large growling sound for about 5 secs. then repeats every 15 sec. sounds like if might be a fan. How many fans in this t.v. . Took the back cover off...
That growling sound is most likely a your color wheel. Often, a color segment breaks free and causes the wheel to become unbalanced. I would suggest searching for a tutorial or "How-To" on replacing it. Basically, you need to disconnect (about 4 connections) and remove the Light Engine (2 screws). Then pull the cover off the color wheel housing (to the left of the lamp, 2 screws). Disconnect and remove the color wheel (2 screws and 2 connectors). You will need to use a vac the glass out from the lost color segment(s). Here's a tip for reassembly: color wheel 4-wire ribbon.. copper on the connector should face you. Also, the lamp door switch must be tripped or the TV will not fire up. I hope this was helpful.
Mar 28, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Check Fan No. 2 Error Message
The DMD board you installed is bad. It senses the detection line from the fan and generates the error code. Try installing the old DMD board.
Mar 15, 2010 | Samsung HL-S5086W 50" HDTV
Screen says check fan 1 2 3
Hi,Sounds like you just need to clean the fans,you can do this with an air pressure can.One of them is where the lamp is a second one will be where the optical block is exactly where the Dmd board is.The third location could be any where.Also it seems there's a cable loose or bad connection ,maybe when you replaced the color wheel you unplugged a cable.Good luck and God bless you!
Oct 08, 2009 | Samsung HLN437W 43" Rear Projection HDTV
Trying to replace lamp fan
First let make sure it's the Lamp fan. What many people think is the fan, And by the way there are three fans in this model, What sound like a fan is in fact a color wheel. So listen to the set as it starts up, these Samsungs make certain sounds when they start. First after you hit the power button you get the "Samsung Tones" from the speakers, second ALL the Fans start 1 to 2 seconds later the color wheel starts then stabilizes, third you may here the lamp fire. So if the sound takes two to three seconds after you turn the set on it's the color wheel BP96-00250A Now when it shuts down its like this First the shutdown "Samsung Tones" then watching from the back after a few seconds the lamp will shut off, then the color wheel stops but all the other fans remain on for about 2 minutes. I've worked on thousands of these and in only one or two was the problem a fan. but on the other hand I have enoghf bad color wheels I was able to make a pertty inpressive Christmas decoration
Feb 05, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
Jerry Greenberg
Jerry Greenberg
