Sansui SAN0218-80GB; DVD Player with 80GB HDD Recorder Problem: I was using the SETUP PAGE to install the recorder and got to the stage where I had both picture and sound. However the picture was not quite right (Vertical pull)and I was trying different settings to get it fixed. The problem arose when I was on the VIDEO SETUP section. I scrolled down to the COMPONENT which was set to YUV and changed this to OFF. Instantly I lost the picture but the sound was still on. I tried all I could think of to restore the setting to YUV but I could not get the SETUP page back. All I have now is a blue screen and the sound. What can I do?
  • fregiorgio Mar 17, 2008
    How can I use the default settings if I cannot get beyond the empty blue screen?
    No, I have not tried this but I will do so now.
    Genius:
  • 3,587 Answers
You'll need to use default settings...
Posted on Mar 16, 2008
    President:
  • 1,950 Answers
Did you try disconnecting the unit for a few hours from the power to hard rest?
SOURCE:
Can the sansui vcr/dvd combo record vcr tapes to a dvd?
No, the DVD section only plays DVDs, to record VCR tapes to DVD you need a ripping device that digitalize audio and video (convert step) and then transfer to DVD specifications this data to disk (record step). The easiest way to do this is using a USB video capture adapter connected to your PC with a DVD recorder drive installed, the software to do this commonly comes as a bonus in the setup disk of the adapter.
Mar 17, 2011 | Sansui VRDVD4001 DVD Player/VCR
User manual how to set clock on Sansui dual dvd vcr player.
Go into SYSTEM SETUP. thats where the clock settings are.
Mar 12, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Sansui video/dvd player recorder
What is model number of unit? Are you sure it records dvds?
Feb 22, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
DVD-player/recorder broken - many files on HDD
Go to setup, underneath TVguide panel, press setup, press all HDD titles delete, do that than go back to same screen and do the HDD format.
Feb 17, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
DVD Recording from Television on DVD and VHS
First off, be sure that you are on the channel that you want to record!!
Press the setup button, the SETUP menu screen appears.
Select "timer rec set".
Then another screen comes up... select "new"
Enter your times, dates, etc.
Dec 18, 2007 | Sansui VRDVD4005 DVD Player/VCR
LG RH1999H DVD HDD Recorder
1. Turn machine on
2. Use remote to open disc tray
3. Use remote to go to setup area of menu (Home - Left) and scroll down to 'Lock' symbol
4. Press 0 seven times
Oct 29, 2007 | LG RH1999H DVD Recorder/HDD Recorder
Remote control problems
Answering my own question,Switch on recorder manually then hold down SETUP KEY and No 2 key at the same time.As this is a common fault with this recorder would advise taking note of this solution.
Oct 21, 2006 | Toshiba RD-XS34 DVD Player/HDD Recorder
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Ekse
