IMAGES ARE OVERLAID AND NOT IN FOCUS
IMAGES APPEAR WITH A HALO EFFECT. MAINLY SURROUNDED BY RED. THE MAGIC FOCUS FEATURE STARTS TO WORK, BUT WHEN IT GETS TO RED IT STOPS AT TWO BARS
The convergence has gone out and when i run the magic focus it runs for about ten seconds and then flashs a green number 4 in the lower right hand corner. I don't have the money to get it repaired but i do have some expierence with silver soldering mother boards for I.O.Mega computer systems. I would appriciate any help in getting direction to parts and schematics to fix this problem. I LOVE THIS T.V.
  • 1 more comment
  • Terrible Tom Mar 16, 2008
    Hitachi 50ux27k
  • cbuehrer May 11, 2010
    I have a Hitachi 50ux27k with images appear with halo effect, what parts do I need to fix?
  • Jaime Hernandez May 11, 2010
    We could help you if you provide more info about the model and chassis number.
  • 2,335 Answers
Here is the schematic diagram. Download all the 13 parts and unzip them using winrar.
The parts you need are listed on page # 50 of the schematic diagram.
You will find the ICs HERE.
Make sure you check the fuses and micro/pico fuse nearby the ICs, as well some crystallized solder joints.
Good Luck.
Posted on Mar 17, 2008
Halo around main subject
Check for dirt on the front element of the lens. I am always amazed that almost every point and shoot digital I see has a filthy lens.
This can also be caused by condensation inside the lens or on the rear element
Feb 03, 2013 | Canon PowerShot SD550 / IXUS 750 Digital...
My mitsubishi 65' tv starting to show a red halo around images. what to do
Sounds like the convergence circuit is failing. You can try pressing the "magic focus or perfect focus" button to see if it clears up. If not the circuit is bad and needs repair. They have repair kits on this website. tvrepairkits.com if you want to try repairing it. otherwise it can cost $300-$400 to have somone else repair it.
Sep 11, 2010 | Mitsubishi WS-65311 65" Rear Projection...
Red convergance appears tp be off, seeing ghost images shifted left
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Televison & Video
Screen was pushed in, takin covering/surround off and fixed screen, replaced covering/surround but colour not right, can see rainbow effect on pitcure. is there a certain way screen must go to transform...
If this tv has a feature called magic focus or perfect focus which is a button inside door that flips down on the front, then it has sensors on the inside of the screen. When it was pushed in, these were probably messed up and will cause a poor picture. It may be difficult to get those realigned. Magic focus will not work right until they are realigned.
Oct 23, 2009 | Toshiba 42H81 42" Rear Projection...
Picture is out of focus. Tried Magic focus - didn't work. Saw color grid; appears blue is out of whack.
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Words are doubled red borders???
Just to clarify, it sounds like what you are saying is that the image appears to duplicate in either red or blue along the edges of the image (especially white lettering and probably increasing along the boarder of the TV). This is resolved by converging your TV. Convergence will drift normally on large screen projection TV's over time or through moving them. The Hitachi 57f500a has a feature called "Magic Focus" (pg 36 in your manual) which will auto converge the image. If the auto converge feature doesn't work, on page 37 in your manual, it explains how to converge manually. If you do not have the manual, I have the image of the pages below. If for some reason this doesn't work, please provide additional info and detailed prior to rating the help.
Apr 20, 2009 | Hitachi 57F500 57" Rear Projection...
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
sounds like you are having a convergence fail. there are 2 Convergence amps in the tv should be on the largest heat-sink inside(right hand side looking from back) replace with stk392-110 and any open or burnt resistors. check for any cracked solder and mark any cables you unplug. if you do that work and need to align the convergence at all let me know and ill walk you through those steps
Feb 21, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Double image 6 yr old unit
Have you let set warm and then tried Magic Focus? Maybe after 15min.
Nov 25, 2007 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi rear projection
without knowing the model number, i can only give you some ideas on what to check.
If the tv was working fine, and started experiencing the problem after being moved, check your focus. you may or may not have an electronic focus pot on the rear of the tv, and you should have a manual focus located on the lens assembly, loosen the wingnut and rotate the lens to focus it.
also check the crt coolant level, if it has a bubble in it, it may be causing the red halo effect.
if the red is to the top or side of the characters and not completely surrounding them, it may be a convergence issue, check the manual for convergence procedures, if it does not have them, your best bet would be to take it to a service tech.
Nov 15, 2007 | Televison & Video
Televison & Video Logo
193 people viewed this question
Top Televison & Video Experts
