Question about Dell 5110cn Laser Printer
Please help with diagnosis of following error for Dell 5110CN CRUM ID -093-693
Please help with diagnosis of following error for Dell 5110CN CRUM ID -093-665
I tried everyting. I took the imaging drum out and poot it in, and notihng. This imaging drum worded before OK.
Tom
  • 1 more comment
  • Anonymous Apr 02, 2008
    same error without finding a solution.....probably going to a tech now
  • Anonymous Mar 10, 2009
    same problem...replaced image drum, toners, mainboard...no result
  • Cory Friedman
    Cory Friedman May 11, 2010
    this is an old post. I am wondering if you were able to get your issue resolved.
  • 4 Answers
Crum has happened to me when using the wrong toner cart or using a non-Dell cart. If that is the case, replace the chip from the old Dell cart into the new non-Dell - easy to do by prying the small circular top off. You'll probably need to switch to non-Dell toner on the printer - go through menu to find it and your toner usage software will be disabled - that's life.
I also had this happen with real Dell toner cart and I did the same thing to rectify.
Posted on Nov 18, 2008
094-402 error code resolution?
web search dell laser printer error codes
Sep 15, 2015 | Dell 5110cn Color Laser Printer 5110 Cn
Dell 5110cn printer error 016-302 can you please help?
You are probably having a problem with a particular document you are trying to print. See this Dell article for help.
http://www.dell.com/support/article/us/en/19/SLN114900/EN
I have found it is not the ESS board that is located on the back of the printer. You can pull it out and reset it into the machine to make sure it is making good contact. Before that though- it will be a lot easier if you download the firmware upgrade from there site and run it on each printer giving you a problem; that should solve your problem.
Mar 12, 2015 | Dell 5110cn Laser Printer
Crum id 093-960 what does itmean
This is happening with my XEROX workcentre 6015B. The error message says: ID de CRUM 093-960 Restaurar cartucho amarelo (replace yellow cartridge, which I've done)
Feb 14, 2012 | Dell 5110cn Laser Printer
We have an error message CRUM 009-367 and we are unable to figure out what is wrong with it on our Dell 3110cn. Thanks
009-367:The Yellow (Y) Toner Cartridge CRUM Data error is detected.
  1. Cycle power on the Printer.
    1. Turn the printer off.
    2. Wait 10 seconds.
    3. Turn the printer on.
    4. Determine if the issue still occurs.
  2. Verify that the toner installed is Dell toner
  1. Cycle power on the printer again.
  2. If the error persists, replace the desired toner cartridge.
    • If the desired toner cartridge has already been replaced, replace the Toner Dispenser CRUM.
    • If the Toner Dispenser CRUM has already been replaced, replace the Printer.
Mar 07, 2011 | Dell 3110cn Laser Printer
Dell 5110cn, says change magenta toner, crum 093-961. canged toner. still has same display
Your Toner Dispenser TF123 could be bad. It is probably not reading the chip on the Toner.
Or possibly you are using the wrong toner. Dell 5100 or Xerox 6300 looks similar and might fit. Also, if you are using 3rd party toner, check that they have caused your problem.
Whit
Item, Inc.
Aug 24, 2010 | Dell 5110cn Laser Printer
I have been experiencing the error: 016-337 - reseat mpc for my Dell 5110cn printer. What's wrong?
You will need to replace the following parts.Multi Protocol Card and the Network Controller Card.No need to call tech support.Its a problem i have encountered with these printers.The Network controller card cost about $149.00 and the multi protocol cost about
$99.00 .Here are the part numbers JG348 ,NR642 .
Good luck
May 15, 2010 | Dell 5110cn Laser Printer
DELL 5110CN 093-426? What error is this?
093-426 is a "black toner replace soon" error message. first make sure that you're using a dell-branded toner cartridge (you can order online here: www.dell.com/supplies) & you can try reseating the black toner cartridge.
Jul 13, 2009 | Dell 5110cn Laser Printer
Dell 5110 004-310 reset printer error
This may not solve your problem but it did mine when I got the "reseat cartridge" error. I had inadvertently ordered the cartridge for the 5100cn, which looks exactly the same as the 5110cn and actually fits if you order the generic version (the Dell 5100cn cartridge looks like the 5110cn but doesn't quite fit).
So, first make sure that you ordered the 5110cn cartridge. (And if you need two opened 5100cn cartridges, I've got them up on ebay :( !!!!)
Jan 23, 2009 | Dell 5110cn Laser Printer
ERROR CODE 010-387 RESEAT FUSER
I had the same exact issue with my 5110cn printer. It turned out that the 5100 fuser is wrong for this printer and will not work. The 5110 has a circuit board on the inside and the 5100 fuser does not. Dell item number KX491 with a BCN # of 652423 works perfectly.
Hope this helps!
Jan 08, 2009 | Dell 5110cn Laser Printer
Error message CRUM ID 093-693
please help with diagnosis of following error for Dell 5110CN CRUM ID -093-665
Tom
Dec 12, 2007 | Dell 5110cn Laser Printer
Dell 5110cn Laser Printer Logo
921 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
