CANT HOOK UP PLAYSTATION3 TO MY SURROUND SOUND SYSTEM
    Problem Solver:
  • 5 Answers
If you have your surround sound already hook up to tv already then yes (atgjohn) is right..But don't for get when you power on your ps3 to press and hold you ps3 power button until you hear two beeps and you'll ps3 will reset it self..some times if your ps3 is hook up to another tv the setting are stuck on to the other tv on your ps3,and you'll just get black screen with sound...
Posted on Mar 03, 2009
Find an open input (RGB or yellow, white red) connect to that if you use RGB then you will need to connect the audio to optical or a anolog input, optical is better sound....also many units have an input on the front that can be used, that way you can unplug the Play Station when your done and move it to another TV.
Posted on Mar 16, 2008
How can i get my surround sound working for my ps3 i have a philips hts3357 home cinema please help
Hook the ps3 into the tv. Hook the T.V out going to the surround sound system and you should get your game sounds out of your surround sound.
Mar 01, 2011 | Philips HTS3357/05 Theater System
Trying to hook up this surround sound to a hdmi 1080p tv and cant get the speakers to make anything but background static. not sure if wires are connected correctly
You probably have to use the TV remote,go into the sound settings,and change it from stereo to whatever options there may be for surround.Good luck! Greg
Aug 22, 2010 | RCA -RP9972 190W Dolby Pro Logic System...
PlasmaSync 42MP3 42 in. Television: i bought a anec hooked up speakers i cant get audi...
I dont' have the fix but I do have a work around. You can hook your source directly up to a surround sound unit if you have one using red and white audio cables to the aux input on the surround sound system.
May 07, 2010 | NEC PlasmaSync 42MP3 42 in. Television
How to hook old surround sound sound up to new lg
if your old surround has either optical or coaxial connections you should be fine. if not you'll have to go with the audio in jacks (video 1,2 etc.) you'll get sound but not true 5.1 sound
Oct 22, 2009 | Audio Players & Recorders
Surround sound hookup
Hook your satelite receiver to your TV. Then run from your TV audio out to your surround sound system. This should make your surround sound system work with anything your TV is playing.
Jan 04, 2009 | JVC TH-S5 System
Help! Surround Sound problems!
Since you have a surround sound system, you probably should just bypass the TV's audio.
Connect the red/white plugs from your digital cable box to one of the inputs on your surround sound system but not the Phono input unless the Phono input lists something aside from Phono, like Aux/Phono or CD/Phono.
Connect the S-Video or composite (yellow) video plug from your digital cable box directly to the S-Video or composite (yellow) video jack on your TV.
If your digital cable box does not have a S-Video (4 pins and flat rectangular hole) or Composite (yellow RCA jack) jack and only has the screw/push-on type cable with the pin in it, then leave the remaining connections as-is.
Now switch your surround sound system to the input you connected the red and white plugs to and turn on your TV. You should see picture from the TV, but hear audio from the surround sound system.
Apr 06, 2008 | Emerson EWF2004 20" TV
Proscan 32LA30Q & Surround sound
Make sure that your patch cables are cumming from the audio line OUT of the TV to the audio line IN on the surround amp. A common mistake on hook up is usually the problem.
Jan 14, 2008 | Proscan 32LA30Q Television
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Dec 31, 2007 | Sony DAV-HDX500 System
I have a Samsung HT-X50 Surround Sound, a LG 50" Plasma 50PC5D TV, and DISH Network Satellite.
How can I get surround sound to work on my tv. When I pull up my menu and go to audio the SRS Trusurround XT is not in bold so I cant figure how to connect it so I can have the surround sound coming from the system and not from the tv. Please help.
Dec 24, 2007 | Samsung HT-X50 System
Tv surround
It depends on what you currently have as equipment.
You'll have to have something that outputs in digital audio (coaxial or optical). Either your reciever (Cable/Satellite) or the TV. You'll just hook that up to the Surround Sound unit and then just turn on the Surround System when you want surround sound.
You'll have to connect the TV as you would normally with audio cables sicne you'll want stereo sound on the regualr channels.
Nov 22, 2007 | Sanyo DWM-2600 System
483 people viewed this question
 Grubhead
Grubhead
