Question about KitchenAid KESI901PBS Electric Kitchen Range
KitchenAid electric oven model #KES1901PBS
All four burners and broiler on at the same time and the oven shut down. Checked fuse box nothing happened. Oven is not even two years old. Is there a reset button. Should I unplug and plug back in or let it rest or am I going to have to pay for a service call.
  • KitchenAid Master
  • 2,651 Answers
This is a pretty non user friendly machine for the genaral public, i would suggest calling in an authorized whirpool servicer for this one.( reason i state auth whirpool, just in case theres apart warr issue they can handle for you). sorry!
Posted on Mar 16, 2008
Oven keypad is completely black but inside oven lights work. does keypad have a separate fuse?
Yes. Many of these have a display thermal fuse that is part of the wiring harness that connects to the board... it should have continuity. WP4451042. Almost all models have what is called the "oven shut-down thermal fuse" which is on the back of the machine ( you have to pull it out of the wall and remove the back panel) and looks like this KitchenAid Range Stove Oven Thermal Fuse WP9759242
Dec 06, 2014 | KitchenAid KEBC208 Electric Double Oven
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
KEBS 278 DWH6 After self cleanng (Top oven) everything shut down. There is still power to the ovens and I have shut off breaker for a long time to see if computer reset. I read that the problem might be...
The thermal fuse is in back of the oven. This is a design flaw of the oven KitchenAid won't admit. Everytime you use the self clean feature this will happen.
The oven has to be taken out to reach the fuse in the back and replaced. The fuse costs about $40+, but the labor will probably run around $300+ unless you feel confortable doing this yourself.
I am about to replace mine for the 2nd time, good luck!
Jun 13, 2009 | KitchenAid Architect® KEBS277S Electric...
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
A Bad thing happened..
Honestly cant think of anything magor that could have happened.. there are saftey thermstatsin key locations around the unit turning the unit off of a runnaway temp is detected.. altoughthe broilerwas "on" for 4 hours im sure it had been cycling on and off for that time not constantly on.Figure your self cleaning cycle lasts for 3hours and om sure attains a much higher temp then just running broiler.. NOW all that being said,a call to a local servicer to inspect for possible damage couldnt hurt for the piece of mind!!!!
Mar 16, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Kitchenaid double oven shut down!
The problem is they overheat because hot air is drawn in by the blower and overheats the outer chamber of the oven where the thermo fuse link is. The one or two fuse links are blown simple replacement but have to remove oven (two person job) remove outer shell and find it (them) in the back of the oven. Also the fuse link wire going into the main processor is probably blown.
Sep 06, 2007 | KitchenAid Architect Series KEBC208KSS...
KitchenAid KESI901PBS Electric Kitchen Range Logo
167 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
