Question about Kenmore 78812 / 78814 / 78819 Gas Kitchen Range
Ignition two of my burners wont lite but there is an obvious spark both heard and seen but if i use a match theyll lite
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Common problem on most gas stoves these days. Burners all light for a few years then one or two won't ignite then eventually all. It's an easy fix. Check the model number of your stove to find its location but usually it's on the bottom of the stove under a metal cover plate or attached to the rear of the stove under a metal cover plate. You can trace the usually orange colored wires going from the burners also. You're looking for the igniter module. Just a small plastic square box with four or more wires plugged into it. Mark which wires go where before removing it. You can research ways to test it on various sites but the most recommended is quite dangerous. It's a $40.00 part in the local parts place or cheaper on ebay. I was so happy to finally get off the matches again. This is more then likely your problem. Good luck.
Posted on Apr 25, 2016
  • 53 Answers
when you have the burner head on the stove look at where the igniter (sparker) is, in line with that should be a hole in the burner head, make sure that is clear. also make sure the burner heads and caps are lined up properly with the igniters.
Posted on Mar 30, 2008
SOURCE:
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Igniter works gas kicks on after igniter stops if it would spark a little longer it would lite I can lite it with a match
Check igniter! You don't have the right spark? Lots of times it will short out & you can see the sparking elsewhere other than just at the gap at top of the igniter. The other thing to check is ensure that the orifice is completely clean at the pilot burner. A clean pilot orifice and the proper spark will ignite the heater.
May 19, 2014 | Pentair MiniMax 100 Natural Gas Swimming...
Cooktop burner do not ihnite
Hi hgodoy2 - Is the electronic igniter aligned properly? Ensure that tip of spark igniter is aligned with metal point or "nib" located on underside of burner cap after the burner mounting screws have been tightened. (Not all burners having mounting screws). When the burner control knob is set to the "LITE" position do the igniters spark? Can gas be heard or smelled coming from the burners when the control number is turned on? However, if you smell gas, I highly recommend turning the unit and the gas off if you can reach it and contact your gas provider. The range itself does not have a switch or regulator to relight it. Keep in mind that it may be experiencing an issue with the spark module, electrodes, wiring or EOC.
Nov 24, 2012 | Frigidaire 36 in.GLGC36S9E Gas Cooktop
Burners on top of stove does not ignite. You smell gas and you have to lite with match. The ports are clean . thanks
what's the model number?if you smell gas and it doesn't lite you could have a bad spark module,when you turn the knob to lite does it click,check to see if any spark is coming to ignite the gas
May 14, 2011 | Kitchen Ranges
Some of my burners will not lite...i see a small spark. It will light if i use a lighter. what part will solve the issue?
There is likely a buildup of crud inside of the gas unit - this can best be cleared with a toothpick poked into the gas jet holes - specifically the holes in front of the igniter. It is also likely the igniter is sparking, but not enough to light up the gas. Theoretically, very little spark is needed to light propane - but I think we've both seen that as not such a practical theory!! If cleaning out the holes ( I would also remove the burner and shake out the crud ) doesn't work, then I would consider replacing the igniter. It is not difficult to replace and your local BBQ store should have igniters in stock. Take the old igniter with you to match it up, to be sure you get the right configuration for your Q. Best of luck in this and Merry Christmas - AND thanks for using Fixya!!
Dec 16, 2010 | Ducane 30400040 Stainless Steel Grill
Top left burner (propane) does not seem to be receiving gas when trying to ignite it with electrical igniter (control knob). However the burner can be lit with a match when the control knob is turned past...
The igniter usually sparks for all burners on the stove at the same time. Usually a little water or gravy, or such has gotten on the little spike that stick up and throws the spark to the burner. If you will take a small brush, like a tooth brush and carefully clean around the little spike it normally starts sparking again. As it is right now, you should be able to see the spark on all the burners whenever you start any of the burners. Check to see on the one that is not lighting, I think you will find that it is not sparking at all right now.
Sep 21, 2010 | Microwave Ovens
98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
Apr 19, 2010 | Dometic RM2652 Refrigerator
All of a sudden all four of my stove top burners do not lite electronically. I do not hear the clicking made by the electronic ignition. the gas comes on and can lite with a match. What happened?
either your spark module is out or you have a short at a burner switch.Go first and check the spark module for voltage out to the burners. Please Rate This !
Jun 09, 2008 | Amana Kitchen Ranges
Kenmore 78812 / 78814 / 78819 Gas Kitchen Range Logo
138 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
