Question about Philips 43P8341 43" Rear Projection Television
Changing coolant I'm kinda new at this whole TV maintence thing. What type of coolant do these units use? Is it readily available? Are there any special tools to use when you change the coolant? I have read that there are certain parts inside the TV that can contain large amounts of stored electrical current and that those can really knock you on your ***. What do those look like? If I decide to replace the coolant in the blue CRT, I plan on doing it the red and the green as well. What other components would you recomend to be "maintenanced"? I really appreicate your time and effort in all of this. Thanks again Matt
  • Philips Master
  • 8,617 Answers
I would recomend the service manual as they explain how to change the coolant, then re-align everything once your done. I would change the blue and green. Red never seems to have an issue with the coolant . I believe it has to do with the color spectrum. You wont need any special tools. The service manual will explain the safe way to discharge the CRTs as they can store energy till they are properly discharged. I will psot a link where you can get the service manual emailed to you if you would like. I work for that site and the service manuals are great, cheap prices and they offer free tech assistance. I am one of their techs. Let me know if you would like the link.
Posted on Mar 17, 2008
I just bought a 2005 Prius..what are some tips for a new Prius owner? Things I need to know? Also can I turn off the beeping when in reverse?? Its annoying! Thanks
you have two coolant systems on a hybrid. both systems should of had the coolant changed (due @100k). Spark plugs should of been changed (due @120k). those re the two high mileage maintence items I would be sure were done. Toyota dealer can change the beep to a single beep instead of a constant beeping.
Mar 14, 2017 | 2005 Toyota Prius
I CANNOT UNLOCK MY TOSHIBA MP3 PLAYER
Can you be more speisific about your problem?
Jun 27, 2008 | Toshiba Audio Players & Recorders
We have a hitachi ultravision model # 50vs810 made in 2005 our problem is when we turn it on the screen seems as if the whole thing should be kinda blue but the corners are kinda black then when we play...
Your TV has a defective optical block which should be replaced by a TV technician only. Due to the cost of the part and labor, it is almost less expensive to replace the TV. The part number for the optical block is UX23751 and is available at the following web site. I hope that helps : )
http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/50VS810/Hitachi+Ltd/Hitachi/UX23751/New.aspx
Jul 25, 2011 | Hitachi Televison & Video
I believe I only need the cap that flush mounts on the back of the pmp 3000, not the whole interior fuse holder.
Sorry, but the fuse "boat" is not readily available. You USUALLY have to buy the whole holder... the whole thing is around $3 from Digikey.com. Many are manufactured by SCHURTER.
Feb 23, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
How do connect my speakers so that i can hear them for the TV?
To hear the TV system through your Sony unit you will need to connect a RCA type lead from the AUDIO OUT sockets on the back of your TV to the AUDIO IN sockets on the back of the Sony unit. These types of leads are readily available in lots of stores and usually have a red, white and yellow connector on each end. You will only need to connect the red and yellow leads and they should be clearly marked on both units.
You will also need to set your SONY unit to AUX mode but you will not get proper Surround Sound.
Jan 23, 2011 | Sony BRAVIA DAV-HDX267W Theater System...
Someone recently backed into my car, I have a 2000 Jaguar S type, and they broke the glass cover of one of the headlights on the passenger side. Im wondering where I can get a new one and if I order it...
Headlight unit, as you sit in the car looking forward this is right hand - left hand side of the car for ordering the correct side unit. You will have to replace the whole unit as the lens is polycarbonate and bonded onto the reflector. Try to get one from a car breakers ( they are readily available on-line) as it will be considerably cheaper and also not stand out so much as a brand new unit. good luck - hope this helps
Dec 30, 2010 | 2000 Jaguar S-Type
Hi I have a 2002 360 modena ferrari does the cooling system take a special antifreeze or can i just use regular coolant
The label on the expansion calls for Glyco Shell coolant.
I have a stable of european vehicles each one asks for their own antifreeze type. I fill everyone of them with regular coolant. Buy extended life coolant labeled as compatible with all types, which is readily available.
Oct 27, 2010 | 2003 Ferrari 360 Modena
I have a Viore TV and I need the remote tv codes.
Most UPC's do not include the Viore, it is a non standard set. Some codes from others may work it
like 0092 316(tivo)
here is a response from the manufacturer.
Unfortunately, there would not be a remote code for this unit in your existing remote. The code would have to be already manufactured in the the remote that you have. This is a brand new unit from a new factory which has a whole new set of remote control information. We have provided our code information to several companies that maintain universal remote databases. There is a lag period before the remote with the new information can be manufactured and provided to cable TV customers. The only universal remote that would have our remote information readily available is a PC-programmable universal remote that allows the customer to download the code information (not a remote code) from the internet directly to the remote. Thank you for your inquiry.
Viore Technical Support
1-866-278-5900
Plese rate my help++++Thanks for using FIXYA
May 23, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
2002 7 Series: what type of coolant specification do i use for 20...
Coolant type is for all of the world BMW cars used freon-free
R134a for fill
May 18, 2010 | 2002 BMW 7 Series
Philips 43P8341 43" Rear Projection Television Logo
56 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
