Question about Lands Phones
My new touch voice dial is not so good. so i bought msvc1.6 from handango. it loaded properly and performs all functions with bt except 1! it recognizes names in contacts perfectly but will not dial them. i tried everything ms said and a few of my own. any ideas? this phone also replaced my 4th 6800. yes 4th i love the touch but this is something ineed to work better than it does whether its the original or msvc. can you help? Eugene Opp
  • eugene_opp Mar 20, 2008
    dear robotek and graeme
    lots of good advice. since this i had to get another phone because of btooth failure!!
    i have people to do the registry work who are qualified. my phone is an alltel touch.
    (the 6800 was a previous bad baaad exp.)
    thanks Eugene Opp
  • 1,512 Answers
Hi there
You say the device can find numbers but wont dial them. Have you enabled the auto dial functions? Doing some more research, back soon
regards
Graeme
Posted on Mar 16, 2008
  • 1 more comment
  • Graeme Ross
    Graeme Ross Mar 16, 2008
    What type of device are you using the msvc with?
  • Graeme Ross
    hhmmmm I have found a lot of info regarding problems with the 6800 / vc1.6 hookup. Mostly relating to voice commands to call a number not being given when using a bluetooth headset. There does not seem to be any easy solution at this time as there appear to be so many people trying to get the software/devices working together properly.
    Is it using a bluetooth headset where you are having problems?
  • Graeme Ross
    I have found a solution for your problem... so long as it IS an xv6800 you are using. It involves some registry changes to be made on your phone... a little complex, but is a fix for your calling problem if you want to try it!!
    Installing Voice Command on Verizon XV6800
    1. Cyberon's Voice Speed Dial software is embedded with the OS and not
    as an addon through the Extended ROM. The only way to disable it is to
    delete the shortcut in the \Windows\Start Menu as well as the
    SDDaemon.lnk file in the \Windows\Startup folder. Note: If you've
    already installed Voice Command - don't delete the Voice Command
    shortcut - just delete the SDDaemon.lnk. This points to the new
    software!
    2. Install Microsoft Voice Command normally. You may be prompted with
    an erroneous error message saying it's going to install in Main which
    is fine. Just continue with the installation. Note: this didn't happen
    with me.
    3. The installation will reassign the Messaging button to Voice
    Command, but you probably want to give that back to the Messaging or
    other favorite applet. Reassign the Voice Speed Dial button to launch
    Voice Command. Note: The XV 6800 doesn't have this button - Voice
    Command goes to the email button in the upper left - you can leave it
    there or change it with the buttons settings.
    4. Lastly, you must modify this registry entry in order to use your Bluetooth headset with Voice Command:
    HKEY_LOCAL_MACHINE\Software\OEM\VoiceCommand\
    Path = "\Program Files\Voice Command\VoiceCmd.exe"NOTE: Create the entry if it does not exist.
    Clearing out the traces of Voice Speed Dial
    1. In these registry locations:
    HKEY_LOCAL_MACHINE \ Software \ Microsoft \ Shell \ Extensions \ ContextMenus \ Contacts \ Main_ContextMenu
    HKEY_LOCAL_MACHINE \ Software \ Microsoft \ Shell \ Extensions \ ContextMenus \ Contacts \ Main_Tools
    ContextMenus \ Contacts \ Summary_ToolsRemove this key entirely:
    {2C0E9904-F32D-4f53-875F-479F5CA81E18}
    2. In this registry location:
    HKEY_LOCAL_MACHINE\ControlPanelRemove this key entirely: VoiceTagCPL
    3. In this registry location:
    HKEY_LOCAL_MACHINE\Software\OEM\VoiceCommandChange this value:
    Path="\Program Files\Voice Command\VoiceCmd.exe"
    (It probably points to SDDialer.exe now.)
    4. In this folder: \Windows\Startup Remove this file: SDDaemon.lnk (you
    should have already done this if you followed the instructions above.
    5. Reassign the Voice button in Buttons applet under Settings to Voice Command.
    Now, soft-reset your device and that should do it. Cyberon's Voice
    Speed Dial is out of the picture. That is, until you hard reset, then
    it all comes back.
    The trick was that the phone had to have the built-in HTC provided
    Cyberon Voice Dialer disabled according to the above instructions. Once
    I did that, I could push a button on the headset and the bluetooth
    connected and could recognize my voice command and dial a number out of
    my contacts. All the other hacks and stuff weren't needed and, in fact,
    didn't work properly - probably because of interference from the
    Cyberon ****. I also followed advice and turned of the confirmations
    for the phone number dialed. I haven't tested it yet with them turned
    on. It does repeat back to you the contact name it thinks you wanted.
    I'm using a Blue Parrot Truckers Premium Bluetooth headset and like the
    loud earpiece and sensitive full boom mic in front of my mouth - but
    some people don't like getting their hair messed up by the
    over-the-head design.
    To do the registry changes - I downloaded a free registry editor
    CeRegEditor by Mdsoft - and a big thanks to him/her! This is a tough
    one if you aren't a geek, though as it's dangerous to fool around with
    the registry if you don't know what you're doing.
    Good luck... happy dialing :)
    regards
    Graeme
How to activate voice dial phone feature
Touchscreen phones simplify the wireless world, especially when combined with voice activation. Although making calls using voice commands was an option before touchscreens became available, the method used to set up this feature is different than it is for non-touchscreen units. It can take time to master the set of procedures that will get the feature working.
Step 1
Create a voice tag. Touch "Contacts" on the today screen. This opens the list of contacts on your phone. From here, do one of three things: you can hold your finger on the desired contact and then tap the "Add Voice Tag," you can select the desired contact, tap on "Menu" and then "Add Voice Tag," or you can tap the desired contact to open their personal screen and then hit "Menu" followed by "Add Voice Tag."
Step 2
Record the voice tag on your phone. Touch the phone number to which you wish to add a voice tag then touch the "Record" button. Record your voice tag for that contact. An icon will be displayed to the right of the number when the voice tag is complete. You can listen to your voice tag by touching the "Play" button on the screen or you can delete it to record a new one.
Step 3
Make a voice tag for a program. Tap the "Start" button on the phone. Go to "Settings" and then the "Personal" tab followed by "Voice Speed Dial." Choose the program for the voice tag and record the voice tag in the same manner as you did for the contact. To open the program with the voice tag, tap "Start," "Programs" and then "Voice Speed Dial."
Step 4
Launch a program or make a call. Make a call by tapping "Start" followed by "Programs" and then "Voice Speed Dial." You will hear a beep. Say the voice tag you recorded for the person you wish to call. You can open a program via the same procedure (by speaking the voice tag created for the program).
Step 5
Check the voice tags you created. Tap on "Start," "Settings," "Personal" tab and then "Voice Speed Dial." A voice tag tab appears and displays a list of your voice tags.
Jun 20, 2016 | Cell Phones
I bought a sharp 903sh online through YesAsia. On my pc it shows up a sx833. I can't make or receive calls but it will send and receive texts. System sounds eg text arriving,are fine but the voice...
Dear Amaxeen ,
Well It Seems the configuration problem ,you should have to configure your phone properly for that ,if you wanna to use its aal features you need to download proper drivers and manual ,so that you can use it smoothly.
You can download all stuff for your Sharp 903 , from this link:
http://www.sharp-phone.com/country/downloads/downloads.php?country=GB&lang=en&product=903
Cheerup and Be Happy Always
Mar 07, 2008 | Cell Phones
How to retrieve messages when not at home? Model 26976GE 1A
REMOTE ACCESS
This section explains the remote access process for use with any touchtone
phone.
1. Dial the phone number for the answering machine.
2. After the answering system answers, press any numbered key on the
touch-tone pad to bypass the outgoing announcement, or wait until
the announcement finishes.
3. Enter the security code after you hear the tone.
4. Follow the voice menu to use the answering machine's remote functions.
The remote feature enables you to perform the following functions:
To Press this button
Review message 1
Play back messages 2
Stop message play back 2
Erase message 0
(during message playback)
Skip message 3
Turn off/on answerer 4
Review voice menu options 7
No valid dialing tones for 15 seconds will hang up the telephone line.
You can get the manual on the link below if you need page 31.
http://www.home-electronics.net/USER-GUIDES/26976_DOM_ES_CL_IB.pdf
Good luck
Dec 04, 2010 | GE Spacemaker 26976 Cordless Phone
The touch-screen of my phone is not working. The four keys on the bottom are working. I can receive calls thru on key but can not dial a number except the lasr dialed or received. Even the accept / reject...
The touch-screen of my china phone is not working. The four keys on the bottom are working. I can receive calls thru on key but can not dial a number except the last dialed or received.
Jun 29, 2010 | HTC Touch Diamond Smartphone
I left my Vtech phone in New York, left for Europe and forgot to set the answering machine on. When I call in I get a factory recorded announcement that I'm not available, etc. I have my PIN # with me,...
Can you please specify the exact model of the phone? Because the steps in accessing it remotely varies from model to model. Anyway, you can try to follow the steps posted here and then test:
Remote operation allows you to control the functions of the Answering System when you
are away from the Base,and call from an outside telephone line. The Answering
System cannot be accessed from another telephone on the same line. You can access
many of the Answering System functons from a remote location, such as listening to
messages, changing recorded announcements, and recording memos.
Remote operation can only be accessed from a touch tone telephone. If the remote phone
is set to pulse dialing, switch it tone. If tone dialing is not available, you will not be able
to access the Answering System.
Note: All function codes should be entered within 2 seconds in order to activate Remote
Operation.
To Activate Remote Operation From a Different Telephone Line
1. If the Answering System is OFF, you can dial your telephone number and wait for
the Answering System to answer your call after 10 rings. An announcement, "Please
enter your security code" is given, and you enter your security code to use remote
operation.
2. If the Answering System is ON, it will answer your call and begin playing the currently
selected announcement (as with any incoming call).
3. Enter # followed by your 2 digit security code during the announcement. The
default security code is 19.
4. Once the security code is received, a double confirmation beep will be given, and
you are in Remote Operation mode. You can then control the Answering Machine
functions using the telephone keypad.
5. The user can also enter the Remote Operation mode during message recording. The
procedure is the same as step 3. The recording will be stopped after entering the
valid security code "s#xx " and the incomplete message will be deleted. If " 0s"
is entered, the Answering System will release the line, but the recorded message
will still be retained.
6. If the user enters a wrong security code, the system will release the line.
Playing Messages Remotely
1. Press " #1 ", " #2 " or " #3 " on the touch tone keypad to play the messages in the
corresponding mailbox.
2. The system will announce "Mailbox X. You have XX new messages and XX old
messages" and the system will playback the new message only. If there are no new
messages, the system will announce "Mailbox X. You have XX old messages. On
the other hand, in the absence of old messages, the system will announce only the
number of new messages.
Repeat Messages During Playback
1. Press "#4" once during message playback to repeat the current message.
2. Press "#4" twice within 2 seconds to skip to the previous message.
Skip Messages During Playback
1. Press "#6" once to skip forward to the next message.
Stop Message Playback
1. Pressing "#5" during message playback will stop playback.
Deleting Messages
1. Press "#9" once during message playback to delete the current message.
Note: Playback will pause if "#" or " " is entered. Answering System will wait for the
command in the following 2 seconds. If no further tone is entered, playback will be resumed.
Memo Recording
1. Press " 8".
2. After selecting the mailbox by entering command "1", "2", "3", You will hear, "Now
recording", followed by a beep.
3. Enter "#5" to stop recording when you have finished.
Change OGM Remotely
1. Enter " 7" to record a new OGM. You will hear, "Now recording", followed by a
beep to signal start of recording.
2. Press "#5" to stop recording. Your new OGM will playback automatically.
Check OGM1 Remotely
Enter "#7" to review OGM. You will hear playback of OGM followed by a beep.
Turning Answering System ON or OFF
Pressing "#0" toggles the Answering System ON/OFF. "Answer machine on", or "Answer
machine off" will be announced, followed by a beep.
Voice Menu for Remote Operation
The system provides two pre-recorded voice menus to help you during remote operation.
Press " 5", and you will hear the simple voice menu.
The simple voice menu is as follows:
• Press "#1" to play mailbox 1.
• Press "#2" to play mailbox 2.
• Press "#3" to play mailbox 3.
• Press "#5" to stop.
• Press "#4" to repeat the message.
• Press "#6" to skip the message.
• Press "#9" to erase the message.
• Press " 5" for other functions.
(To advance voice menu)
The advanced voice menu is as follows:
• Press "#7" to review outgoing message.
• Press " 7" to record outgoing message.
• Press " 8" to record memo.
• Press "#4" twice to repeat previous message.
• Press "#0" to turn the system on or off.
• Press " 5" to return to the simple voice menu.
Pressing any function code will stop the voice menu, and perform the corresponding
functions.
Exiting Remote Operation
1. Enter " 0" on the touch tone keypad to exit remote operation mode. The Answering
System confirms your action with a long beep and then disconnects.
2. The Answering System also automatically disconnects if no key is pressed within 20
seconds during remote operation.
Oct 17, 2009 | Vtech Two Line Digital Answering Machine...
I have a panasonic Cordless phone and can't remember how to remote access it?
Using the answering system
remotely
Dial your phone number from a touch
tone phone.
2 After the greeting message starts, enter
your remote code (page 59).
LThe unit plays back new messages.
LAfter playing back new messages,
the voice guidance starts.
3 Follow the voice guidance as
necessary.
4 When finished, hang up.
Note:
LYou can ignore the voice guidance and
control the unit using remote commands
Voice guidance
During remote operation, the unit’s voice
guidance prompts you to press {1} to
perform a specific operation, or press {2}
to listen to more available operations.
Operations are presented by voice
guidance in the following order:
– Play back all messages
– Play back new messages
– Record your message
– Erase all messages
– Record your greeting message
Note:
LIf you do not press any dial keys within
10 seconds after a voice guidance
prompt, the unit disconnects your call.
LIf less than 3 minutes of recording time is
available, the unit announces the
remaining recording time after the last
message is played back.
Remote commands
You can press dial keys to access certain
answering system functions without
waiting for the voice guidance to prompt
you.
Key Remote command
{1} Repeat message (during
playback)*1
{2} Skip message (during
playback)
{4} Play new messages
{5} Play all messages
{7} Recording a greeting
message
You can download the full manual at
http://www.retrevo.com/support/Panasonic-KX-TG5776-Telephones-manual/id/1074bh748/t/2/
Please make sure to rate this solution. Thanks.
Jul 23, 2009 | Panasonic KX-TG5776S Cordless Phone
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
Apr 14, 2009 | Lands Phones
Program one touch button to send fax to multiple numbers
Setting one touch numbers:
press function 72
set
press 1 for one touch numbers
press a position on the soft pad example 01
enter fax number with round buttons
set
enter name with soft pad letters
set
continue with more numbers or press stop to end.
For GROUP DIALING
Setting Group Dial:
press function 73
set
choose group dial
set
press program 1
set
name the program such as field offices.
set
press the one touch numbers you entered in the first step for this group,,,,01,02,05,08,17 etc
press set
press stop
load document in feeder, press Program 1 key, START
Jan 23, 2009 | Panasonic Panafax UF-890 Plain Paper Laser...
Need to find out how to set up caller id on supertooth 3
Hi Kazgear,
Voice Dial:
Important: Be sure your phone supports the voice dialing function and that it is activated. Record at least one voice tag. (Please refer to the instructions in your phone’s user manual.) Note: Voice dialing entries must be stored in the phone’s memory, not on the SIM card!
1. Press the Accept Button (1) for 1 second.
2. A voice dial beep will be heard on the kit to prompt the user to say the voice
tag of the contact to call.
3. Say the voice tag exactly as how you recorded it.
4. The voice will be played back to you, and then the phone will dial the number automatically.
Her's a .pdf file of the user manual, which you can save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Nov 29, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Unable to connect voice dial
Hi marrick,
Voice Dial:
Important: Be sure your phone supports the voice dialing function andthat it is activated. Record at least one voice tag. (Please refer tothe instructions in your phone’s user manual.) Note: Voice dialingentries must be stored in the phone’s memory, not on the SIM card!
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Nov 21, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Lands Phones Logo
104 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
