Question about HP iPAQ rx1950 Pocket PC
Appointments off by one hour after DST
My computer automatically sets to DST. When I synched my ipaq to the computer I noticed all the appointments I had already scheduled for the following week were an hour later on my computer on Outlook. I then tried manually setting my ipaq to the DST to match the time my computer had but when I synched with the computer again, the ipaq went back to the regular time AND the appointments I had corrected for the following week were once again one hour ahead. If I leave the ipaq set at the regular time and have my appts in at the correct time, the computer has the appts all one hour ahead. Any ideas how to fix this? Thank you!
  • 2 more comments
  • Brigadoon Mar 16, 2008
    No, I didn't. How do I get that?
    Oh, okay. I see. Obviously I still have a lot to learn. At any rate, I went to that setting and clicked on Update. What results should I expect to see?
    Thank you!
    Well, that's something new to me. I didn't even know that. At any rate, my computer set itself to DST last week but when I just did the update, nothing changed with the problem with the PDA having one time and the Outlook having another time. The appts in my PDA are at the correct time although the time on the PDA is an hour earlier than what it should be given its DST. The time on the computer and thus on Outlook is DST but the appts are one hour later than they should be. Is this just something I will have to live with? Not the biggest problem in the world, though, is it?
    Originally the appts were set prior to DST kicking in but the same thing happened when I set new appts for the following week. I'm wondering what you mean when you say an update from MS. Are you talking about something other than what you originally told me about by going to the Time Zone in the Control Panel or something else and if something else how would I do that?
    Genius:
  • 3,587 Answers
Did you get the update for the new DST shift that happened a week early this year?
Posted on Mar 16, 2008
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels Mar 16, 2008
    well...it's not something you get..it's a manual adjustment in your settings under date/time, which your computer looks at from all your applications
    control panel
    date/time
    time zone
  • Patrick Michaels
    well..usually it is automatic, but the US Govt decided to shift it one week or ten days, for energy issues. Did your time reset?
  • Patrick Michaels
    well..were those appointments set prior to DST kicking in? Sounds like an update from MSoft might do the trick..it's usually programmed in, but with political decision, it's not as usual
My Dell Axim X5 pocket PC reverts to wrong date
Duh... I figured out that my PC had the date set a month ahead! Not sure how that happened. The Axim was dutifully synching up w/ the wrong date, and so the November appointments didn't register. Thanks for checking.
Nov 27, 2008 | Dell Axim X5 Pocket PC
Appts on iPhone do not synch to computer
you need to set your preferences in itunes to sync properly
Nov 17, 2008 | Apple iPhone Smartphone
IPAQ 6965 problem
Go to \Windows\StartUp and delete the offensive program.
May 13, 2008 | HP iPAQ hw6965 Smartphone
Problem synching after Daylight Savings Time
I have this problem too. The only way I can correct it, is by removing the battery, reinstalling it and letting it boot up again. Then I plug into the USB port for iPAQ and it seems to connect to ActiveSync. It's a real pain.
Mar 10, 2008 | HP iPAQ rx1950 Pocket PC
Error message while syncing Ipaq
open Activesync on your PC. Click on Tools, Options. Double click on calendar. On this screen is it set to sync 2 past weeks and ALL future appointments?
Sep 14, 2005 | HP iPAQ H5550 Pocket PC
Time off by one hour
a pocket PC that still runs. wow. a blast from the past, 2000.
16 years it works ok , then today it fails?
you need to set time zones. and if you have DST , day light savings time in your unstated locations.
finding a manual on anything that old is problematic to you and most other helpers,
good luck with that.
Apr 12, 2017 | HP Jornada 548 Pocket PC
Date & Time of calendar
Sounds like your PC is not set to adjust for daylight savings.... the ipaq automatically adjusts for daylight savings but the PC does not. On your PC double click on clock, click on Time Zone tab and then on that screen you will see the box that needs to be checked. also check that both PC and IPAQ are set to same time-zones.
Sep 12, 2005 | HP iPAQ HX4700 Pocket PC
IPAQ rx3115 calendar synch 1 hour off
The pc clock needs to be set to daylight savings time. To do this right click on the time on you pc go to the time/clock settings and then click on the time zone tab and below the clock is the box that says automatically adjust for daylight savings time make sure that is checked and then re-sync the iPAQ.
Sep 08, 2005 | HP iPAQ RX3115 Pocket PC
Unresolved Items when synching
Try the following.... Open Active sync on your PC. Double Click on Calendar. Change the settings such that it syncs only 0 past and 0 future appointments. SYNC (this will clear all calendar items on the IPAQ) Now go back in to those Calendar settings, and set it back to the default which is 2 past weeks and All Future appointments. SYNC (this will now reload all appointments into your Ipaq)
Sep 08, 2005 | HP iPAQ H2215 Pocket PC
Calendar question RX3715 / Windows 2003SE
yes the default is that the ipaq only keeps the past two weeks. To change this, open Activesync on PC, double click on Calendar.
Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ rx1950 Pocket PC Logo
71 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
