Question about Lands Phones
I have a desk phone without the operators manual and all of a sudden it has pulse dialing instead of tone dialing how do i change it back
  • Anonymous Feb 08, 2009
    On a per call basis, touch the * key and then you will be able to dial in tone mode.  There is a key combination to make the switch from pulse to tone.  I cannot remember what it is.  Occasionally our phone resets to pulse.
    Scholar:
  • 148 Answers
There is switch back in to ur phone u can change the dialing mode there is sometimes figure. if u dont have try using one by one by changing
Posted on Mar 16, 2008
I have a Serene CL-60AP phone. It receives calls but I can't get it to dial out. I hear it dialing like an old rotary phone but then the dial tone comes back.
You need to change the dialing mode to tone rather than pulse.
If you would like to know how to do this refer to page 26 of the instruction manual
50. DIALING MODE SETTING (TONE OR PULSE)
page 15 on the pdf file below
http://hearinglosshelp.com/store/wp-content/uploads/sites/2/2015/02/CL60Ausermanual.pdf
Depends on what your telephone exchange accepts as a dialing signal. Strange thing is phone is factory set to tone but it seems to sound like your phone is on pulse.
Mar 11, 2017 | Lands Phones
How do I change pulse to tone dialing?
Are you sure about the phone model number?
Tone/pulse is set in the common equipment (KSU) configuration, not the individual set.
Press Feature 9*80 to see the system software version.
Jan 27, 2015 | NorStar M7324 Telephone
How to get phone back to tone dial instead of pulse dial
Since you declined to specify the model of your Uniden cordless phone, I can only suggest you select it from the list beginning here to download a copy of the manual. The manual will explain how to switch between tone and pulse dialing.
Jan 19, 2011 | Uniden Cordless Phone
Model UNIDEN UCIS-225 - Phone suddenly dials like a rotary phone. Does anyone know how to make it return to the non-rotary dialing?
two places<br /> 1. Manual switch on back of phone Tone or Pulse<br /> 2. Menu-Set Dial Mode - DTMF (tone) or Pulse
Aug 05, 2010 | Uniden Lands Phones
Phone went from touch tone to pulse. . .
Read the manual to reconfigure that option. (Look for Setup button on the phone) I can't guess what model you have. On older phones one could find a switch on the the phone to flip between Tone and Pulse.
Sorry I could not be of much help.
Sep 04, 2009 | Uniden Cordless Telephone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
I need to find out how to return to a normal tone
There should be a button on the phone labeled 'tt/pulse'. The button should be moved to the 'tt-touch tone' position.
Apr 16, 2009 | Lands Phones
Changing from pulse to tone dial
For the GE electric 2.4 GHZ phone where there is no switch, you have to press the program button and hold until it beeps (talk button will start flashing), then press the tone (star) button and program again. It will beep for confirmation
Dec 12, 2008 | Lands Phones
I HAVE A UNIDEN DECT 6.0 PHONE THE HOUSE AND IT WITH NOT DIAL OUT OR LET INCOMING CALL COME IN PLEASE HELP ME WITH THIS PROBLEM ! MY NAME IS JULIUS C FREDERICK MY NUMBER IS 803-741-0511 EMAIL IS...
Dial Tone comes back even after I dial the phone!
Question:
Why does my phone allow me to dial a number, hear the numbers being dialed and then go back to a dial tone? Help me I want to call out!
Answer:
Sir the you are dialing on needs to have the other dial mode in operation. You have the ability to change dial mode on your phone. Instructions to change dial mode are usually at the beginning of the manual under install /set up the phone. If you are currently using pulse, please change the mode to tone. If using tone please change the mode to pulse. Doing this will allow you to call out.
answer found on www.uniden.com
Sep 07, 2008 | Uniden 5.8GHz Dual Cordless Phone
Tone Pulse
yea.. this happeneded to me aswell.. here's what you do: (this is in the manual btw) TONE/PULSE SETTING 1. Make sure the phone is OFF (not in TALK mode). 2. Press the program button. 3. Press * tone button for tone or # pause for pulse selection. 4. Press the program button again. You will hear a confirmation tone.
Feb 28, 2007 | GE 27990GE3 Cordless Phone
Lands Phones Logo
193 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
