Question about Refrigerators
Samsung cooltech SRL551DP
Hi, did u solve this problem cause I have the same problem and I replaced main pcb and probes.Thanks
  • xmanrox Mar 18, 2008
    Yeah it,s got me stumped! Done the same as you in changing parts. Checkeg cooling fans etc.I even paid for a samsung agent to fix it and guess what ..zip.He couldn,t fix it!.
    I'm now thinking it must be a fault in one of the wiring looms off the main pc board that are hard to get to without taking the rear panel off and the insulation inside, may have a break or some corrosion.Otherwise its a new fridge for me and it wont be a Samsung
No i did not solve it, i changed the main pcb, probes ( all ) and the pcb in the door behind the display. i also disconeted the defrost heater and the other heater ( they are the brown and white wires up top going into your main pcb ) that did nothing either. as far as i can tell it happens every 10 -12 hours, no one on this site has been able to help? if you find out what it is could you let me know, im over re-seting it but used to it now.
Thankyou.
Posted on Mar 16, 2008
Canon np 7161 photo copy machine error code 010
  1. If Cause of connector
All are The connector if not connected then Reconnect it.
2. Cause of Power Supply PCB.
Turn on the power switch. Set the meter
range to 30 VDC, and connect the probes to
J209-4 (+) and J209-3 (-) on the DC
controller PCB. Is the voltage about 24 V?
Suggestion:
See
"DC power is absent.Power Supply PCB is faulty
3. Cause Of Main Motor(M1) or DC controller
Replace the main motor. Is the problem
corrected? If no..Then
Replace The DC controller
Jun 30, 2016 | Canon Office Equipment & Supplies
Hi there I have a Samsung model SRL551DP upside down fridge. Recently our whole block had a power outage. When power restored fridge did not resume. Refrigerator door panel blinks the letter d only?
modern fridges do not like power surges as it burns the electronics
call in a technician to check it out and put a surge protection in the power supply cord
Apr 18, 2016 | Samsung Refrigerators
Samsung cooltech needs reset to keep cooling
HI.JAMES. shot in the dark.it might work for a quick cheap fix.ok 1-get a 24 hour ac plug in timer.plug fridge into it.set timer to run for 4 hours and off for 10 minutes.it might work.let me know if it does.better then PCBs and sensors etc.good luck.ali
Jun 19, 2012 | Refrigerators
Error 36
The error message 36 may happen to come in your Brother printer due to some physical damages. Thus, you can solve the issue by replacing these damaged parts of the printer. You need to replace the maintenance unit with a new one. It is good to upgrade the carriage PCB, head or carriage unit and carriage motor, if these are causing the issue. The main PCB of the printer may also get the issue and you need to replace the main PCB. You may also need to replace the power supply PCB if it is damaged.
Sep 13, 2011 | Brother DCP 165C Compact Color Inkjet...
Error message: "Unable to print
The machine is jammed internally.
Open the printer and look for a foreign object such as a paper clip or torn piece of paper. If it is not this then there is a mechanical problem that need to go to shop for repair.
Look on page 157 of the owners manual. Let me know if you need the manual.
Let me know if this help.
Feb 27, 2011 | Brother MFC 6490CW InkJet Printer
Hi, I have Samsung freeze model No SRL551DP >both freeze and freezer. is not working.both has light, it flashes. If I turn main switches on and off it works again for four hours freeze and...
check the evaporator how much frost build up. if it build up block air way. the heat element or defrost thermostat is bad . otherway check the condensor make sure clean
Jan 10, 2011 | Refrigerators
When i print using my docuprint 203A fuji xerox, the printout result paper was cover with black all over. what does this mean?
This is a rebadged Brother Printer.
Possible causes for a solid black output:
1 Corona failure
Is the corona wire dirty?
Clean the corona wire with the wire cleaner.
2 Corona wire broken?
Replace the drum unit
3 Are the charge electrodes between the printer body and
the drum unit dirty?
Clean both electrodes.
4 Harness connections?
Is the laser unit connected to the main PCB correctly?
Connect the harness between the laser unit and the main PCB
correctly.
5 High-voltage power supply PCB failure
Is the problem solved after replacing the high-voltage
power supply PCB?
Replace the highvoltage power supply PCB.
6 Main PCB failure
Is the problem solved after replacing the main PCB?
Replace the main PCB.
7 Laser unit failure
Is the problem solved after replacing the laser unit?
Replace the laser unit.
Good Luck!
May 12, 2010 | Fuji Xerox® DocuPrint C3055DX Laser...
Error261 in canon copier
E261
0000 The intervals of zero-cross signals deviate from the tolerance range while
the fixing heater is supplied with power.
Main cause The wiring is faulty (short circuit, open circuit). The main power supply
PCB is faulty. The DC controller PCB is faulty.
Making Corrections
1. Connectors
Are the connector J205 on the main power supply PCB and the connector
J308B on the DC controller PCB securely connected? (zero-cross signal:
J205-7 <-> J308B-1)
NO: Connect the connectors securely.
2. Main power supply PCB, Main controller PCB
Try replacing the main power supply PCB. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Feb 22, 2009 | Canon NP 7130 Black and White Copier
Cooltech super xflow not circulating
hi
there is problem with x flow motor which is located inside the ref temp. assy. in frige section.this problem dosen't affect the cooling of fridge.this problem can resolved by replacing the x flow motor
yours
sandesh
May 15, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
SRL551DP, fridge stops, display on door flashing.
You most likely have a problem in the freezing/cooling circuit. Check your condenser, evaporator fans to see if they are running okay. Most likely it may be the condenser fan.
Dec 17, 2007 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
331 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
