Question about Compaq A3000 All-In-One InkJet Printer
Compaq a3000 all-in-one printer
My printer won't print and when i go into it, it says that status is offline, i've selected online but still won't print and i've already unistalled and installed it back again, what do i do.
    Genius:
  • 3,587 Answers
Try new drivers..stranger things happen with printer drivers..should be able find them here, under hp
Posted on Mar 16, 2008
SOURCE:
Printer offline wont print cant get back online
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Step 2:
If still you are facing issues, then update the printer driver. This should fix the problem.
For further precise instructions, please let me know the Operating Systems installed on the Computer.
Hope this helps..
Jan 12, 2014 | Canon PIXMA MX712 Wireless Inkjet Office...
My HP deskjet D4260 is offline. I have tried everything to resolve this but cannot find a way of etting it back online. Please help
Once you have added either a USB or networked printer to your PC or Mac computer, you can begin sending documents to print. However, on occasion, a print command will create an error on the printer and take it offline, which will prevent all future jobs from printing. To resolve this issue, you will need to change your printer settings from offline to online.
    PC Instructions - Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer. - Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open. - Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
    Mac Instructions - Open System Preferences by clicking on the icon in the Dock. - Go to the Print & Fax control panel under the Hardware category. - Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button. - Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Mar 02, 2011 | HP Deskjet D4260 Printer
Blinking green light< will not print. staus says it is offline
hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} · Step 1
· Step 2
· Step 3
Mac Instructions · Step 1
· Step 2
· Step 3
· Step 4
Aug 02, 2010 | HP DeskJet 3650 InkJet Printer
My printer says its offline how do I reconnect? I've already done a complete power off and it's still offline.
hi
just folow the step
Step 1
· Step 2
· Step 3
· Step 2
· Step 3
· Step 4
Jul 07, 2010 | HP Deskjet 6940 InkJet Printer
Printer says it is offline.
right click on the printer it have to select use printer online,
right click on the my computer icon select manage>device manager, check your universal serial bus controller it have not any error with yellow or red coler.
Mar 31, 2010 | HP DeskJet F380 All-In-One Printer
Printer won't print says it's offline
hi friend
this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
please try my solution and rate it
thanks
Apr 04, 2009 | HP Deskjet F340 All-In-One Printer
Printer status offline needs to be online
Do you mean it says "offline" under the printer icon in your PC's printer dialog box?
Right click it , then select "use printer online".
Please let me know
Apr 04, 2009 | Zebra 110Xi III Plus Thermal Printer
Compaq A1500 all in one
Did you trying going to printers and setting default printer? Also click online for the Compaq A1500.
Aug 24, 2008 | Compaq A3000 All-In-One InkJet Printer
Frequently changes its status to offline; have wireless connection
please perform the steps below:
Step 1:
Determine if the printer is paused or offline :
1.Open the printers folder, if necessary.
a.Click the Start icon.
b.Click Control Panel.
c.Click Hardware & Sounds.
NOTE: This step is not required when using Classic view in Windows Vista.
d.Click Printers.
2.Right-click the name of the printer and then click Open.
3.Click Printer.
4.Verify that Pause Printing and Use Printer Offline are not selected.
5.Press Esc to close the window without making any changes.
Step 2:
Check for the default printer and USe printer Online in the printers and faxes folder.
Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
Aug 12, 2008 | HP Photosmart C7180 All-In-One InkJet...
DEVICE STATUS OFFLINE
To solve this problem you'll need setup the printer up with LPR Protocol. Go to Devices and Printers. Right-click on the printer in question select Printer Properties. Go to the Ports tab. Find the port you've setup then click on Configure Port. In the block titled Port Name you'll need to enter the name of the Gigafast Print Server. It's normally 1P_PrintServ??????. The ?s are the last six entries of the print server's MAC address. Next, in the Printer Name or IP Address enter the assigned IP address, example (192.168.5.3). For the Protocol select LPR. LPR Settings: Queue Name: same as 1P_PrintServ??????. Lastly, check the box that says LPR Byte Counting Enabled. Now when you shutdown and restart the printer will remain online.
Apr 15, 2007 | GigaFast Ethernet EE171-PR Print Server
Compaq A3000 All-In-One InkJet Printer Logo
Top Compaq Office Equipment & Supplies Experts
Ekse
Damen Wong
Damen Wong
Thomas F. Schneider
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
