Question about Philips Magnavox DVD/VCR Dual Player
STUCK IN PROGRESSIVE SCAN MODE
THE SCREEN STAYS BLUE
CAN'T CHANGE IT BACK
  • Anonymous Apr 08, 2008
    same problem with a Zenith....800 number no help at all
  • Anonymous Apr 13, 2008
    the dvd turns on the screen goes blue and it says progressive scan mode you can hear the dvd but have no picture
Open the disc hold stop and your screen should pop up it is not a bad company as long as you talk to the right person
Posted on Sep 18, 2008
Ok here you guys go if ever this arises - heres THE fix...
Make sure a dvd is already playing...Press Play Once...
Wait like 1 second, Then Press and hold Play...After aprox % Seconds...the P. Scan Should Turn Off...
Posted on Apr 12, 2008
    Problem Solver:
  • 15 Answers
Been a while since I fixed one of these. I seem to remember a service code entered via the remore, or by turning it on while holding down a combination of buttons, that would reset it to default settings. You can call their Service Center and actually get help. Phillips is one of the few that will respond. They can also send a firmware update disc that resets EVERYTHING back to its original state.
Posted on Mar 16, 2008
2 Suggested Answers
SOURCE: Magnavox MDV560VR DVD Player Stuck in Progressive Scan
it worked for me too.
make sure that you see the word stop on your dvd
Posted on May 04, 2008
I was playing with settings on my Zenith xbv342 and set the menu to progressive scan. I now have a blue screen with the words "progressive scan mode" I cannot get a picture and it is stuck in this m
Progressive scan mode is used by DVD players to artificially scale standard resolution DVDs to HD resolution, usually 720i. Is your set capable of receiving HD resolution? If not, that is probably why you are getting the blue screen.
Dec 18, 2014 | Zenith XBV342 DVD Player/VCR
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Progressive scan mode on screen
Your television probally does not support progressive scan mod. many do not.
Apr 12, 2009 | Zenith XBV342 DVD Player/VCR
Magnavox MDV560VR DVD/VCR combi
f you accidentally set Progressive Scan to ON (within
Analog TV), press STOP 9 for five seconds to restore the
picture to normal operation.
Aug 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Stuck in Progressive Mode
Had the same problem; here's what i did. Take DVD out of Receiver, close door to receiver and hold down stop button on receiver itself for five(5) seconds. changes should take effect and progressive scan screen should revert back to sanyo screen.
May 06, 2008 | Dual DWM-3900 System
Trun the DVD player on till you see the "progressive scan" screan. Hold the "stop" botton down for 5 seconds and the unit should reset to standard DVD play.
Worked for me, good luck.
Bill
Mar 13, 2008 | Philips Magnavox DVD/VCR Dual Player
DVD player
unplug it and plug it back in and press the progressive button to turn it off, should work. Yeah that blue screen sucks, i would have thought you can get to the menu no matter what but that's sanyo for you, well most other brands also...
Jul 21, 2007 | Sanyo DVW-5000 DVD Player/VCR
MY DVD / VCR PLAYER MADE BY GOLDSTAR IS STUCK IN A MODE THAT SAYS PROGRESSIVE SCAN MODE ,HOW CA I GET OUT OF THIS MODE I HAVE A GOLDSTAR MDL #GBV441 THANKS
Stuck in Progressive Scan Mode??? Remove the disc(s) from the changer, make sure TV is on Blue Screen...should say "Progressive Scan Mode".......Simply press and hold the stop button for 5-10 seconds and it will reset.
Apr 29, 2007 | Goldstar GBV241 DVD Player/VCR
GOLDSTAR DVD/VIDEO PLAYER
Remove any discs from the unit. Make sure your tv is on the blue screen. It should say "Progressive Scan Mode"....After removing the disc(s) from the disc changer, close the changer, press and hold the stop button on the unit, not the remote, for 5 seconds or more and it will reset to normal playing mode. Progressive Scan is typically only for TVs that use Progressive Scan....most normal TVs do not use progressive scan mode. Hope this helps...It worked for me!!!!
Jan 20, 2007 | Goldstar DV7411N DVD Player
Stuck in progressive scan mode
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Aug 29, 2006 | NexxTech ESDVD100 System
Philips Magnavox DVD/VCR Dual Player Logo
168 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
