Question about BenQ S2W 5300U Color Scanner
Lost Disc 2 for setting up my acer scanner
Is this scanner even compatible with a Mac note book?
  • Anonymous May 05, 2008
    benq color scanner 53
Code [ffff:0027] be occured when we are making scan page & others option, plz solve this problem
Posted on Jun 09, 2008
SOURCE:
I can not intall my acer 320u scanner in win 7
Scanner seems to be very old - Here are orginal specs - Hope this helps
  • Brand Name: Acer
  • Model: 320U
  • Hardware Platform: PC, Mac
  • Scanner Type: Flatbed scanner
  • Form Factor: Desktop
  • Scanner Interface: USB
  • Media Size Maximum: A4 (8.25 in x 11.7 in)
  • Color Depth: 36-bit color
  • Maximum horizontal resolution: 300
  • Maximum Vertical Resolution: 600
  • Media Type: Plain paper, Bulk objects (such as books)
  • Media Load Type: Manual load
  • Minimum system requirements: Apple MacOS 7.0 or later, Microsoft Windows 95/98
  • Width: 12 inches
  • Depth: 18.1 inches
  • Height: 3.3 inches
  • Sep 13, 2011 | AcerScan 320U Flatbed Scanner
    Lost install disk for Mac book pro My 13" Mac book
    You will need some install disks to even begin working on your issue.
    Your options:
    • Find someone with the same model MacBook Pro and borrow the disks.
    • Buy a copy of Leopard (10.5) or Snow Leopard (10.6) and use them. If you are going to buy a set you might as well update to Snow Leopard (10.6)
    • Check eBay for install disks but make sure they are for the same model MacBook Pro.
    • Contact an Apple service center and purchase a replacement set of install disks.
    Once you have a install CD, I would recommend backing up your system by making a disk image of the hard drive to an external drive. Then doing a clean install and then using the Migration Assistant to restore your user files to the clean install on your hard drive.
    Apr 23, 2011 | Apple Computers & Internet
    Canon 9900f scanner not recognized by Adobe Photoshop
    According to Canon it is not supported.
    Issue: Does my product support Mac OS X 10.5 (Leopard)?
    but here is a link to try.
    http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=8743#DownloadDetailAct
    Solution: Mac OS X 10.5 (Leopard) Compatibility information (Non-Compatible Scanners)
    Mac OS X 10.5 (Leopard) Compatibility information (Non-Compatible Scanners) Unfortunately, the chosen scanner model is not supported with Mac OS X 10.5 (Leopard). For models that are supported, please see the information below.
    Compatible Scanner Models Drivers to support Mac OS X 10.5 will be available for the below models. Visit the Canon download site for the most up to date versions of the product's drivers and software.
    4400F
    9950F
    LiDE 70
    8400F
    LiDE 25
    LiDE 90
    8600F
    LiDE 35
    LiDE 500F
    8800F
    LiDE 60
    LiDE 600F
    • Scanner models released after 2007 will be compatible unless otherwise noted.
    • For scanners missing from the list above, if it was released prior to 2007, then it will not be supported in Mac OS X 10.5 Leopard.
    Aug 01, 2009 | Office Equipment & Supplies
    How to scan with mac
      1. Connect a compatible scanner to your computer. A list of compatible scanners is available in technical document 107203 "Mac OS X 10.2: Scanners Compatible With Image Capture "
      2. Install any necessary software drivers that came with the scanner.
      Note: Not all scanners require the installation of additional software drivers.
      3. Turn on the scanner.
      4. Press the scan button on the scanner. See the documentation that came with the scanner for specific instructions. Image Capture opens automatically and a preview scan appears.
      5. Select the area of the image you want to scan.
      Figure 1 Preview image with area to be scanned selected
      6. Click Options in the toolbar to adjust settings specific to your scanner.
      Figure 2 Options icon
      7. Adjust any settings in the drawer that appears.
      8. Click Scan.
    The scanned image is saved in your Pictures folder in your home directory and opened in Preview.
    Note: These are the default options. They can be changed in the Image Capture toolbar.
    Jul 16, 2009 | HP Photosmart C6280 Printer
    For Mac OS X, UMAx 3450 does not work
    After visiting their officail website and calling the customer support it was made clear that UMAX 3450 is not compatible to MAC OSX. Therefore I would suggest not to try third party drivers as the company says its not compatible.
    You may want to visit their site
    http://www.umax.com/download/index.jsp
    Mar 19, 2009 | Umax Astra 3450 Flatbed Scanner
    Mac compatibility
    scaner driver acer prisa 640 driver windows xp
    Jan 04, 2008 | Acer ScanPrisa 640P Flatbed Scanner
    Set Parameters Failed
    I have the same problem with my Acerscan 620U flatbed scanner which I have used for years, even with XP home SP2 & 3, after I reloaded the Operating system on the same machine, (after a crash) It would not work properly, so I searched for new drivers and softwareafter not finding anything useful here, I went to driverguide.com and found 2 files for the 620U. A zipped file containing the original (Win 95-98) install disks - 2Megs, (pasted from Driverguide);
    Model Acerscan 620U Manufacturer Acer info_icon.gif Operating Systems Win95, Win98 Device Type Scanner File Name disk1and2.zip
    Uploader Notes This is the install softwarefor the AcerScan 620U, which is the USB model. I wasn't able to find itanywhere on driverguide.com and when I tried to download the latestversion off of the Acer website it didn't work, crashed my graphicsprograms. This one worked perfect.How it works
    Unzip disk1and2.zip.
    This will give you disk1.zip and disk2.zip
    Unzip disk1.zip to a folder called disk1.
    Unzip disk2.zip to a folder called disk2.
    Runthe 'Setup.exe' file in the 'disk1' folder - halfway through it'll askyou where 'disk2' is. browse to wherever you've unzipped disk2 andthat's it!
    I also downloaded a 14 meg file "mirascanv403u10.exe" (<a href="http://members.driverguide.com/driver/detail.php?el=1&driverid=128406">Acer AcerScan 620U Driver</a>) which is supposed to work with W95-98, ME, W2000, XP (with mixed reviews)and Mac-OSX, I haven't tried either of these yet although I will try the Mirascan file first. For many users the difference may be that when setting up an XP machine you have the option to use a FAT32 file system or an NTFS partition, it may be that the software doesn't work with the NTFS partition/filesystem.
    If you send me a request to [email protected] I will send you either or both of the files as an attachment until Jan 10 2009 then I delete them, (or you can get them from Driverguide) I'll also let you know what worked for me.
    Sep 07, 2007 | AcerScan 620U Flatbed Scanner
    BenQ S2W 5300U Color Scanner Logo
    263 people viewed this question
    Top BenQ Office Equipment & Supplies Experts
    jasbo
    jasbo
    Tom Chichester
    Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
