Question about Canon PIXMA MP170 All-In-One InkJet Printer
Alarm is flasing
I had a paper jam, after pulling the jam out, the amber alarm light is flashing, I have tried everything in the manual from turning it off, to unpluging it from the electricity and removing the USB port.
thanks.
  • Betsysue May 20, 2008
    Yep, it was broken, thanks anyway, is gone now.
    Genius:
  • 2,785 Answers
I think you have to open the printer and check for any parts dislocated or broken
Posted on May 19, 2008
SOURCE:
Printer will not print in black was the first problem and now after less than a minute after turning on it has the light for 'on' flashing green and amber constantly
Try this:
1- Pull the cartridges out, restart printer then reinstall the cartridges again
2- The blinking can mean any of these: paper out, paper jam, cover open, printing error. Please check that there is enough paper, no paper jam (sometimes even the smallest piece of paper will cause that error, then restart both (the printer and the computer)
Best of luck
Jun 12, 2010 | Canon BJC S300 InkJet Printer
Everything was going fine for 5 years. Today, I
The lights you describe indicate a "CPU Runtime Error",.. unfortunately this may mean a trip to the shop for the printer. You can try to clear any obstructions and turn off and then unplug the power for about 4 minutes,.. plug the power back in and turn on the printer. If this does not have any affect (most likely it will not,.. but its worth a try before servicing), then you have a mainboard problem and will require parts and labor to fix.
Sorry to be the bearer of bad news,.. but without the news you will spend a lot of time trying to correct a problem that requires a repair.
Feb 08, 2010 | Brother HL 1240 Printer
ALARM light flashing, wont let me print.
hold down stop/reset button for 7 sec. If that doesn't work try holding it down for 14 sec.
Dec 10, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I have a acanon pixma mp210.. amber alarm light
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
The alarm light is blinking. We have unplugged it and it's still on.
alarm flasing can be more than one thing. check to see if alarm is representing a symbol on fax machine. It can be jammed paper inside, or toner/ ink run out.
Dec 15, 2008 | Canon Office Equipment & Supplies
Not printing
There is probably a paper jam in the tray feed path. The other situation is that the tray paper pick up roller has become hardened/polished, or the paper tray paper is greasy. First step, take the paper from the tray, and fan it out, so each sheet is separated from the next. try it with jut a dozen or so sheets, change the paper.
Thoroughly check the paper feed path.
If not working, then check/clean the rollers.
Jan 20, 2008 | Kyocera FS-720 Laser Printer
Canon PIXMA MP170 All-In-One InkJet Printer Logo
123 people viewed this question
Clive
Clive
old marine
old marine
Ekse
