Question about RCA P52960 52" Rear Projection Television
Flyback what does the flyback look like in an rca p52960 does it stick out
  • RCA Master
  • 8,617 Answers
Its a large transformer with either 1 0r 4 large red wire simallar to a spark plug wire coming out of it. Depends on chassis number wether it has1 or 4 red wires coming from it. Let me know if you need more info or a link where you can get a service manual.
Posted on Mar 16, 2008
Need flyback for rca model#p52960 tv?
You can get one from www.tvrepairworld.com you need the 239111 Flyback transformer for that model.
Nov 10, 2012 | RCA P52926 52" Rear Projection Television
Tip
Do i have to worry about getting zapped when resoldering the flyback transformer...
FL231. FUSE.... The RCA ITC222 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and green shadows? Does it have bowing in affect on the top and bottom of picture? when you turn it on does some thin red green and blue line bow in from the top then go away. The main question to determine if you have the fl231 fuse problem is if you go into customer menu then setup do you have the "CONVERGENCE' option. If you do not. then i suspect you have this problem. In the manufactering of these sets Lead free solder is used. now there is great debate over the use of lead free. connection tend to be more brittle. cracks develop around the solder connections of the high voltage flyback transformer. this very small crack set up oscillations in the cuicit with a 400 milliamp fuse. THis fuse cant take it. When this fuse blows the processor then does not know its a projection tv with three projection tubes. it thinks its a crt tube tv. and crt tube tv dont need "convergence" so it removes the convergence from the set.
TO REPAIR... 1. Warning. this set can generate leathal dangerous voltages even unplug do not attempt if you have no experence with electronics.
2. Remove the back. there a number of torx 20 screws.
3. what you will see is a number of circit boards There will be one on the right and one on the left. the one on the right is the small signal board. the one on the left is called the power deflection board. it has a large black part with a big red or black wire coming from the top, this is the flyback.Next to the flyback on the right of it there will be three small rectangular componets tan or brown in color. these are fuses. the one in the middle is the fl231 fuse.
4. getting to this fuse can be difficult. these two cuicit boards sit on a tray that is removable. to remove this tray it is pulled out and up. BUt watch the wires.loosen the wire tyes.
5 when you get the tray up the bottom side of the board can be accessed
you will now have to unsolder that fuse. one side of this fuse is under a plastic part of the tray. i have found the easest way is to cut away the plastic to get to it. if you dont want to do this you will have to remove the board. only remove half of the plastic brace
6. REPLACE FUSE RCA PART 259213
7 RESOLDER FLYBACK CONNECTIONS simply heat up and add a little solder
8 reassemble set. make sure you examine the set for loose connections.
9 and remember "BE Careful'
on Jun 30, 2009 | RCA R52WH73 Projection Television
Rca rear projection model # P52960..will not come on and makes a chrip sound
Replace the flyback transformer and HOT tarnsistor. You can get the Repair kit from www.tvrepairworld.com which has the Flyback and Hot
Oct 11, 2011 | RCA P52960 52" Rear Projection Television
My rca projection 52" tv
http://www.partstore.com/OpenSearch/Model/Thomson/RCA.aspx
Jul 07, 2011 | RCA P52960 52" Rear Projection Television
Tv wont turn on p52960
Still sounds like the flyback. Rca has had issues throught the years with flybacks failing especially that model.
May 12, 2008 | RCA P52926 52" Rear Projection Television
Rca p52960 wont turn on
Humming or singing can be Shorted horiz out transistor
and bad fly back transformer........need service # off back of
set for part #'s.........T.
May 12, 2008 | RCA P52960 52" Rear Projection Television
Rca P52960 with the ptk chasis
It sounds like the flyback is actually defective. The set wont power up at all correct?
MODEL - P52960 RCA
You have a flyback and horz output bad,price for this repair should be around 150.00 to 175.00,you also may just have a loose connection on the main board,if so price would be much less,because the flyback would not need replacing just the output
Jan 20, 2008 | RCA P52960 52" Rear Projection Television
Television set wont turn on .
labor and parts are around 200.00 us dollars.
Dec 23, 2007 | RCA P52960 52" Rear Projection Television
Tv will not turn on with remote or when I press the power button on the tv.
The P52960 uses the PTK195 series chassis. The most common cause of that set not starting up is a shorted flyback transformer. It is quite easy to test and replace the flyback transformer in that chassis, but that should be done by a qualified tech experienced in RCA projection sets.
Sep 18, 2007 | RCA P52960 52" Rear Projection Television
RCA P52960 52" Rear Projection Television Logo
82 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
