Question about Tech Solution TS-4500 Shredder
Only runs in reverse
My shredder will not run when paper is fed. It won't even hum. The reverse works just fine though.
  • Anonymous May 28, 2008
    I just experienced the same problem--however, it runs for about 2 seconds in forward, then stops. I only used the machine for a total running time (with intermittent breaks) of about 5 minutes. How can this be? I didn't overload it. Any help would be appreciated...
    Thx..Lin
If you take the unit apart you probably will find that the plastic housing for the blades is broken. It will run in reverse, but binds when forwarded. I'm looking for parts but probably will have to dump the shredder in the landfill. I've used it more than Lin, but haven't over-used it. Ask Andy in Colorado.
Posted on Nov 05, 2008
    Scholar:
  • 102 Answers
This is an issue with the paper feed sensor usually located in the center of the paper feed slot. If it is mechanical you need to jiggle switch in and out to free possible interference behind switch (piece of paper or debris) if it is an electronic sensor you more than likely have a bad sensor or pc board. You will need to contact manufacturer for any further assistance.
Posted on Mar 21, 2008
My shredder worked fine but now when I turn on it does not stop running and does not shred paper ?
Most shredders will have a shred and a reverse setting. Is it running in reverse? Has the bin been emptied? With the power off, you can remove the bin and manually pull excess shredded paper jammed in the cutting heads -watch out, sharp metal . Once cleared run single sheets for the first minute to help clear rollers.
Jan 05, 2015 | Shredder Office Equipment & Supplies
Shredder won't shred. can't hear motor in the forward setting only in reverse
Silverfox007:
There is a paper sensor at the throat of the machine that turns the machine on when it is activated by the paper when the paper is inserted. Something has happened to that sensor. Unplug the machine and remove the shredder head from the basket. Use a screwdriver to remove the screws at the bottom of the shredder head and open the shredder head. Look where the paper is fed into the machine and you will see the sensor. It may be unplugged/wire broken/sensor flag broken off... You'll know what to do when you identify the problem.
Sep 06, 2012 | Office Depot ATIVA DX120P Shredder
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
I have a simple Royal paper shredder. Got paper stuck in it. Going back and forth the paper appears to be gone, and it grinds normally in reverse but going forward the green light is on but nothing will...
Does the machine even run in reverse???? Have you ever oiled the machine.???
Put some "shredder oil" onto the cutting blades while it is running in reverse then try running it forwards.
If you can hear the motor running but the cutting blades dont turn you will have to open it up to see what is broken.
For parts assistance you can contact Royal at 1-800-524-0799.
Nov 19, 2010 | Royal VF1012mx Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
It will not grab the paper; need to press forwared
May 24, 2010 | Quartet gbc Shredmaster 6550X...
Our Aurora AS1712X paper shredder is jammed in a couple of places with paper so badly that we cannot free the jam and the tooth wheels cannot turn freely. Is there an easy way to clear the jam?
May 20, 2010 | Aurora Electronics AS882C (Cross-Cut)...
VF1000MX Shredder: Shredder works briefly in reverse, but won't run f...
Try cleaning the "eyes"....if they get dirty they can act erraticaly...if that dosn't fix it you may have a pcb prob....you can give Royal a call at 1-800-524-0799 for parts information and advice.
May 16, 2010 | Royal VF1000MX Shredder
I have been using my shredder heavily in the last 30 minutes. I have had to stop twice for it to cool down. It was working fine, and now it won't accept paper. The cutters are turning fine. It is not...
Most shredders don't recommend use for more than 20-25 sheets in a session. Try using the reverse setting; even though you can't see paper, it's possible that there's some still in the feed channel. If after switching to reverse paper comes out, inspect the feed channel for more paper and clear any you find before trying to feed more sheets. Also in the future, constant use as you've described will burn out the motor.
Nov 16, 2009 | Tech Solution TS-4500 Shredder
Tech Solution TS-4500 Shredder Logo
397 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
quennie732
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
