Question about Garmin nuvi 350 GPS Receiver
Cannot switch off the gps 350
I was using the unit and al was working fine. Subsequently, when i turned off the car, the unit went to the battery mode adn said would switch off in 30 secs and it didnt.
The power off button on the top of the unit does not turn off the unit either adn the reset button just does the soft resets and reboots but still doesnt help in switching off of the unit
    Scholar:
  • 174 Answers
Do you feel a light click when you push the power button?
If not the switch is probably defective, If you do feel a click, hold it there for several seconds. It should switch off.
Posted on Jun 12, 2008
SOURCE:
Nuvi 350 I got it from someone else, already used, it does not connect with the GPS or the antenna. Is the antenna in it or in another car?
the antenna is on the back of the unit. it needs to be flipped up in order for live gps tracking to work. when it is flipped down, it will only work in simulated mode.
Dec 07, 2009 | Garmin Nuvi 350 Car GPS Receiver
I cannot use the GPS unit while in charge mode(NUVI 350)
Are you using a USB cable & charger to operate the GPS?
If so, you should stop and use the supplied cradle / power cord to power the GPS instead. The USB cable is used to transfer data to and from the GPS and on other models (maybe your 350, too) to slow charge the GPS battery when completely discharged. Powering with the USB cable will power up the GPS, but does not allow navigation, mapping, etc.
Oct 12, 2009 | Garmin Nuvi 350 Car GPS Receiver
Gps 350
Press the Power button on the top right corner of the case.
If unit will not power on, battery may be dead. Try connecting car charger or power adapter to unit.
To charge battery faster, leave unit connected to power adapter or car cord. Press and hold Power button to turn unit off. Screen will show "Going into charge mode."
Jul 25, 2009 | Garmin nuvi 350 GPS Receiver
Garmin 350 cannot charge and nav at the same time
Your battery is faulty. Did it come with an AC Charger? Ac chargers do a better job than the car Dc which really only manages to maintain a reasonable level of input. i suspect your internal batter is critical and either needs a thorough charge or replacement
Jul 25, 2009 | Garmin Nuvi 350 Car GPS Receiver
Set the date on nuvi 350
April Fools day!
If you are turning the GPS OFF by master switch this information will be lost always.
If just using the front buttons then it will remain as you set it There is no spearate power memory for when the unit ges flat from main battery or having a separate memory battery
Jul 23, 2009 | Garmin nuvi 350 GPS Receiver
Garmin c550 GPS-Won't turn on at all.
push and Hold the power button down while you push reset, keep power button pressed til it boots again. If it does not, and it's in warranty ship it to garmin. If it's out of warranty, have someone open it up and remove the battery for a couple of minutes.
Jun 29, 2008 | Garmin nuvi 350 GPS Receiver
could the battery be dead? Leave it to charge on the wall charger for several hours. Then try again. There is a way to do a hard reset....
Jun 08, 2008 | Garmin nuvi 350 GPS Receiver
GPS Won't Turn On
www.batteryship.com
look up tomtom 510 - or whatever model you have
Order the battery..........comes with manual and tools to fix it
only 20.95
it works
cheaper than sending it in!!!!!!
These are genuine replacement parts!!
Laura
Jan 30, 2008 | Tomtom GO 510 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
