Question about Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop
Monitor menu The menu for screen adjustment brightness control etc (on the monitor ) is always appearing and the buttons meant to operate them has stopped working. only way i can remove the menu is by switching off the monitor plz help
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 194 Answers
I think menu button has pressed on the monitor free the button it show free but it struck on internally otherwise remove the connection of frontpanel setting connection
Posted on Mar 16, 2008
    Genius:
  • 3,587 Answers
That's a control issue with the monitor...you may need to get and reinstall the video drivers for that one...check this link, follow hp icon to model number, for computer, and look for video drivers.
SOURCE:
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Apr 17, 2016 | Princeton Digital VL173 Monitor
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Adjust monitor
hi, most monitors have between 4 buttons or 8 to udjust picture. the 4 button MENU, PLUS, MINUS, OFF. when the menu button is pushed the screen will show a list of COLOUR, BRIGHTNESS, CONTRAST, etc,etc the plus is pressed to change the COLOUR, BRIGHTNESS, etc,etc. if you need to change the SCREEN setting BECAUSE THE ICONS ARE TOO BIG click on START go up list to CONTROL PANEL go to DISPLAY click on this and go to SETTINGS click on this and on the left. change to 1024 by 768 SCREEN SIZE (COLOUR 256). press APPLY wait press OK. gerry
Sep 10, 2010 | Envision EN 9110 19" Flat Panel LCD...
My screen is too bright and hurts my eyes. How do I dim it a little?
he on the monitor you can find small buttons ,, you can just go select menu button from there select brightness section,, all this appear on display screen,, once click on button.. where u can adjust
Oct 05, 2009 | Acer V193w LCD Monitor
The brightness adjustment bar appears on the screen all the time
Press the menu button on monitor select the brightness press the menuside button increases or decreases.after select exit oress the exit button on monitor.
Jul 13, 2009 | Compaq CV 7500 17" CRT Monitor
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Mar 12, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Brightness adjustment not very effective - XP-sp2
Alter your gamma,brightness,contrast,etc with your grapics card settings,
Mar 01, 2008 | Acer AL2016W 20" LCD Monitor
Dell m782 Brightness control???
Brightness is adjusted by using the 2 buttons on the left side of the front.
See instructions here:
http://support.dell.com/support/edocs/monitors/m782/En/controls.htm
Jan 04, 2008 | Dell M782 Monitor
OSD Locked
Press menu button for 5 seconds until the text "OSD Unlocked" appears on the screen.
Aug 28, 2007 | LG Flatron L1750S 17" LCD Monitor
Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop Logo
43 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
