Question about Ezonics EZCam Plus Webcam
No sound for headset
I can't get my headset volume to work
    President:
  • 8,637 Answers
Go to Control Panel and click on SOUNDS and then SPEAKERS and change it to HEADSET and adjust the volume. Then OK, and it should work.
Hope this helps. Bud
Posted on Mar 18, 2009
My headset stopped playing volume, how do I get it reset?
Try another headset first to isolate the problem. If the other headset is ok then I would check the in line volume control if fitted or it could be the cable is broken at the plug end or the headset end. if the second headset does not work either then check volume levels on phone. does phone speaker work ok. Can also be headset socket on phone worn out ?!
Feb 04, 2015 | ZTE Cell Phones
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
The sound on my iPhone suddenly stopped working, it does not work for music like pandora, videos, youtube, police scanner, the ringer fully works and I can hear people talking when they call so I do n
Try resettin, hold home button and power button for about 25 seconds, if this doesnt work the speaker prob went out. they have two speakers, one u hear people on and the one u hear music from.
Nov 01, 2012 | Cell Phones
I have voice, but no sound
Plug the USB connector into an available USB port.
• Check your computer's volume level.
• Check if your computer's volume is muted.
• Check your operating system's audio input and output settings.
• Check the headset's volume and mute settings.
• Restart computer.
May 11, 2012 | Dynex DX-840 Headset
My headset was working fine but all of a sudden the volume will not stay at the level I turn it up to. It keeps rolling back down to barely any sound coming through. I try to use the button on headset but...
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to solve your problem. Your Logitech ClearChat Pro USB Headset's volume will not stay at the level you turn it up to, and as a result it keeps rolling back down to a lower sound quality. Your volume control button doesn't solve the problem neither. Well, when a problem occurs, you should first troubleshoot where it's coming from. We will use a method called "Process of elimination". Your headset's volume has two controls: one control is on the headset itself, and the other control is located in the sound settings of the device you have your headset plugged into. With this thought in mind, lets go up to the problem explanation above. You said that the volume control attached to the headset didn't make a difference, this means the you can eliminate the hypothesis that it's the volume control causing this. The problem is coming from the earphone portion of the headset. Either a mute setting has been activated, volume is turned down real low or your headset is not the default device to receive sound input. The first part of the investigation is done; now, to get further into the investigation, you will need to connect your headset to your computer. This is where troubleshooting and solving the problem meet. Step-by-Step, I am going to explain to you how to get audio presentations into your headset. This device works with two Windows Operating Systems (Vista and XP) and one Mac Operating System (OS X). If your computer's operating system is Windows, open your Control Panel. Under the Hardware & Sound link, click Manage Audio Devices (for Vista users), and the Sound & Audio Devices link (for XP users). If your coumputer's operating system is Mac OS X, open your System Preferences and click the Sound link. In Windows Vista, click the name of your device, then click Set Default. Click the Properties button and increase the volume slider or unmute the volume if needed. If applicable, click the Apply button, then click OK. If the Apply button is void, just click OK. Click the Recording tab and perform the same procedures as you did before, only difference is that this will make your headset microphone the default recording device. In Windows XP, click the Audio tab and set the headset as the Sound Playback and Recording device. Increase the volume or unmute it if needed. When finished, click the Voice tab and perform the same procedures as you did before. In Mac OS X, click the Input tab and select the headset as the input device. If you still can barely hear anything, increase the volume slider. When finished, click the Output tab and repeat the same steps as before; only thing, you will be making this the sound output device, meaning the sound of your voice will be outputed from the microphone. Increase the volume slider if needed. You should be able to receive sound in and out of your headphones now. If we succeded, through this experience we have: troubleshooted where the problem was coming from, found a way to solve it and fixed the problem! Thank you for choosing FixYa as your one-stop solution spot for problems, questions, concerns and requests. Visit our website again the next time you need assistance with something. Thank you and have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
May 27, 2011 | Logitech ClearChat Pro USB Headset
Genius HS-03U Volume Control Help
It's not fixable.
Set as default audio unit to "USB audio device", because Genius HS-03U control the volume only sound device by default.
Headphones improperly trying to adjust the volume of "alien" audio devices, such as second sound card, if it is selected as the audio output device by default.
Oct 20, 2009 | Genius HS-03U Headset
Logitech clearchat stereo won't work on my inspiron 1545...
try uninstalling sound card from the device manager and reboot the computer.
if the mic does not return you may be missing a driver contact your laptop manufacturer or download new sound card drivers from the websight to restore mic function.
Jul 02, 2009 | Logitech ClearChat Stereo Headset Headset
Need more volume for M H350 headset
There is also a setting in the phone for the headset volume. Under Sound settings.
Mar 10, 2008 | Motorola Mobility H350 Wireless Headset
No sound,no working mic...not even showing on my voice tab in control panel
Just a couple of questions that might help you solve your problem..
- Have you already installed the sound driver of your motherboard/sound card?
- Have you properly inserted the right color/jack of your headset to the computer?
- Have you check the volume control of the headset whether it is in mute or full volume?
If you have tried the above questions then you might have a defective headset.
To test if it is working, try playing some music & the sound recorder for you mic.
benson
Jan 29, 2008 | Logitech (980158) Headset
Ezonics EZCam Plus Webcam Logo
150 people viewed this question
Top Ezonics Computers & Internet Experts
micky dee
Wilhelm Lehmann
Rommel Balcita
Are you an Ezonics Computer and Internet Expert? Answer questions, earn points and help others
