Question about Goldstar MV-1526 Microwave Oven
Need parts for instalation
How do i order the instalation kits for my goldstar mv1526 microvave
  • Goldstar Master
  • 9,174 Answers
Call 1-800-243-0000 (Monday ~ Friday, 7 AM ~ 8 PM CT;
and Saturday, 8 AM ~ 5 PM CT) and choose the
appropriate prompt from the menu; or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
6ya staff
SOURCE:
How do you install a goldstar mv-1310w I think I have all the parts, but I'm not even sure of that.
The installation guide is online here. It should show you what parts you'll need.
You can order LG parts from Encompass here or you can call them toll-free at 866-779-5835.
Sep 28, 2011 | Goldstar MV-1310W/B Microwave Oven
I need istruction on how to install this microwave
Installation instructions are here. Owner's manual here. Repair manual here.
You can order parts Encompass here or you can call them toll-free at 866-779-5835.
Aug 20, 2010 | Goldstar MV-1501 Microwave Oven
My Goldstar Microvave (model MV-1526W) is not heating. Everything seems to be working except the heating. I can set the time cook, and turn it on -- when I do the lights and fan both turn on, the timer...
You probably don't want to hear all this, but:
Microwave ovens are generally not a fix it yourself item. You need the proper test equipment and knowlege in order to service them safely.
(if, for example, the bleader resister inside the high voltage capacitor fails, the capacitor can hold a 400+ volt charge long after the unit has been unpluged, which can be hazardous) A guess without being able to work on the unit would be that the magneton tube (6324W1A001A) has failed, which does carry an 8 year part warranty on that part (for your model), but labor is not covered beyong the first year. The unit has to come off the wall, and the outer case removed just to get to the mag tube. Of course you could have a bad capacitor, rectifier, high voltage transformer, or a bad motherboard. I'd recommend calling a local repair shop to see what they would charge for a repair estimate if you brought the unit in.
(by the way, we are unable to respond back to comments on premium questions)
Dec 06, 2009 | Microwave Ovens
Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
Aug 29, 2009 | Sharp R-1870 Convection/Microwave Oven
Goldstar model mv1526.Sometimes the fan comes on by itself and the only way to stop it is to unplug it for a few hours. The fan off on button does not stop it even though it reads fan stop.
Contact the manufacturer (Goldstar) about that--it sounds like your microwave definitely needs to be repaired, especially since you've already tried unplugging it (which is the first thing a technician would suggest that you try). Usually, the manufacturer can tell you how to get your microwave repaired or replaced, and if it's still under warranty, the repair/replacement may even be free!
Goldstar's phone number (according to their website, www.goldstarappliances.com ) is (800) 243-0000
Good luck! :)
Aug 26, 2009 | Goldstar MV-1526 Microwave Oven
Microvave will not heat
Same problem others have reported.
To test this you need to see if you have 110 volts on the primary of the heat transformer. You likely do not.
You then have to find out why. It could be a relay or a bad timer.
Jan 14, 2009 | GE JVM1870 Microwave Oven
Goldstart Microwave Model #MV1526 1000w Everything works, but does not heat up. Goldstar MAL 783W Same problem as for another Goldstar I saw here. light comes on, turntable turns, and to answer the...
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
The service manual can be downloaded here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics. You'll probably have to call them.
Dec 27, 2008 | Goldstar MA-782M Microwave Oven
Part Needed
If you're referring to the roller wheel assembly, the part number is 5889W2A011A.
You can order this from www.microwaveglasstrays.com
or call toll free 1-877-894-0035
Sep 03, 2008 | Microwave Ovens
I have a Kenmore Elite Speedcook Microvave model #363-63673200. The selector dial is not working so I would like to order a new part for this. In addition I need to find a how to site to figure out how I...
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 26, 2008 | Kenmore Microwave Ovens
Goldstar MV-1526 Microwave Oven Logo
65 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Mike
Gerry Harvey
Gerry Harvey
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
