Question about HP LaserJet 2200D Printer
My printer is not printing anything
Every time i want to print something it will just come out with a blank piece of paper
whats the solution
  • Anonymous May 06, 2008
    I have a printer that has the same problem but it's on a network and some users are printing ok, others will only print blank pages. Any suggestions?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 194 Answers
Check the properties of the printer , or any errors showing in the printer
if its not come check the cartridges in the properties panel sometimes it show ok but it will not print problem with the head
Posted on Mar 16, 2008
3 Suggested Answers
SOURCE:
  • 101 Answers
SOURCE: I have to hit print twice for printer to print document
Try to install new cartridges, possible ends inks.
Since level of the ink is specified for orientation aproximately
Posted on Mar 07, 2009
SuperTech-11
  • 1591 Answers
SOURCE: The printer will print out
If test pages are working but print jobs aren't, it's almost always a driver issue.
Uninstall and reinstall the printer driver.
If it's still not working, and you're running windows 7, turn off the bidirectional communication mode.
post a reply here if you need further help or if that doesn't work.
Posted on Feb 27, 2011
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
Hp 2280 wont print says no paper or ink
Start by uninstalling the printer software... then re-install the newest software from the HP website. Always works for me...
Jan 25, 2012 | HP DeskJet F380 All-In-One Printer
When I try to print anything the paper will load half way then it will say I have a printer jam. It wont print anything and does this every single time I try to print anything.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Nov 23, 2010 | Dell V305w All-In-One R840635AU InkJet...
Every time I try to print a paper, it always says that it has a paper jam. I have took out the paper, and did everything it said to do, but it still jams. What should I do?
Usually if it says a paper is jammed, there "is" something in there that got missed. You just have to keep digging until you find it. You did't say if it actually starts to print first, or if it says it right off the bat from the previous print attempt. It may require further disassembly to find the problem, ...it could be something very tiny if a piece tore off when you were unjamming it before. It could also be "mis-feeding" ...reply with a liitle more info if you don't find it.
Jun 12, 2010 | Dell 926 All-In-One InkJet Printer
The PGBK cartridge doesn't print anything
Do a selftest on the printer. If the Selftest prints out something, uninstall the printer Driver and reinstall it again. If it still did not work checkin the printer to a qualified technican to have a look at it.
May 12, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Mfc 8420
Hello there This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
All The Best: Pineworks
Apr 27, 2010 | Brother MFC-440CN InkJet Printer
Canon BJC-3000. Paper goes through but is blank.
Hello there
Mar 24, 2010 | Canon BJC 3000 InkJet Printer
My printer will not print
I have a feeling Your Scanner is Locked, Their is a scanner release switch , make sure the scanner swithc hasn't been moved, these move in away that they could accidentally lock the scanner when you remove paper and stuff.
Mar 06, 2009 | Office Equipment & Supplies
Producing blank pages
repeated nozzle cleaning (6 times) which almost emptied the cartridges but it is now printing
Jan 03, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Print out blank pages after clearing a paper jam
Have you checked the obvious things? Such as pulling the tape off the new cartridge? Also make sure the transfer roller under the toner cart. is in securely.
Jul 04, 2007 | Canon imageCLASS MF6530 All-In-One...
HP LaserJet 2200D Printer Logo
50 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
