Question about Canon PowerShot A510 Digital Camera
Camera stuck, can't retrieve images
I dropped my camera. Before I dropped it, I took pictures all day with no problem. When I dropped it, it was on and the lens was out, and I was about to take a picture. Now, when I turn it on, there is a loud buzzing and then a grinding noise, and the screen says "Canon" for about 10 seconds, then goes dark. The lens won't move in and out. I just want to move the pictures from the camera to my computer but ZoomBrowser EX, which came with the camera, doesn't recognize the connection between them when the cable is plugged into both. What can I do to retrieve the images?
  • 3 more comments
  • moirakulik Apr 03, 2010
    There is a memory card in my camera. I had erased all of the pictures that were on the camera before I took it out for the day. I don't know where my camera automatically stores images. I just take pictures, plug the cable into my camera and my computer, turn on the camera, put it in "play" mode, and ZoomBrowser Ex automatically pops up and gives me the option of retrieving the photos. The memory card holds 128 MB and I probably had about 20 photos on the camera before I dropped it.
    I had already tried all of these suggestions, and I don't have a memory card reader. That's why I posted the question. If there's nothing else I can try, I guess I'll have to find someone with a memory card reader I can borrow.
    I'm not a pro, that's why I needed to go on the internet to find a solution. Thanks for your help. :)
    How can I tell whether they were saved on my memory card? Guess I need to get a memory card reader...? I don't want to pay some camera repair shop more than the thing is actually worth just to tell me that the pictures can be retrieved with a cord that costs less than $20. :)
  • Angelito Rabago
    Angelito Rabago May 11, 2010
    1. Do you have memory card on your camera? 2. Where did you save the pictures? on camera built in memory or on your memory card?
    Genius:
  • 1,035 Answers
1. If the pictures were saved on your memory card then you can just transfer them to your computer.
2. If they were saved on the built in memory of your camera then you need to fix your camera first before retrieving them.
3. There might be short circuit inside your camera that's why it can't communicate with your computer.
* you need a camera technician to fix your camera then when it is fix that' the time you can get yur pictures.
Posted on Apr 03, 2010
    Brigadier General:
  • 11,967 Answers
Use a separate card reader to download the pics. Also, try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
  • Ty Price Apr 03, 2010
    A memory card reader is something you should always use instead of your camera. A pro would never use the camera for downloads. This one costs $13 at Walmart and can read 32 different kinds of cards.
SOURCE:
Sanyo camera vpc S880 digital recover deleted pictures free
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download this photo recovery software
http://www.facebook.com/pages/Asoftech-Photo-Recovery/126127714100611?sk=info
Install and open the photo recovery software, select the memory card, and click 'Start' button.
Jul 22, 2012 | Sanyo VPC-S880 Digital Camera
I have been using the CANON SD750 Camera for 2 years now. I just came back from moemorial day vacation yesterday. I realised the camera does not allow me to review the photographs. Of over 1600 pics I...
Try to retrieve the files from the memory into your computer, if you can't see the pictures after they are moved, they might have been corrupted while you were using the camera.
In theory, you might have placed the camera near a strong magnetic field, like a speaker. This could explain the files being corrupted if that's the problem you have.
May 31, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
Hello, i took some pictures a few days back, but theres some problem while retreiving some of the images....the image for the particular pictures having problem shows a blue blank screen with file...
Best way is to download the pictures to a computer through a card reader (optional). The blue blank screen could be deleted images using the garbage can icon. Retrieving those images can be done but it cost to have a recovery program used and there is no grantee that the images can be extracted because the card my have been written over or formatted. Once you have your images saved to a computer the memory card should be loaded bak into the camera and the memory card formatted to give a clean working surface for the camera to write new files to.
Dec 28, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
I took pictures, and the camera instead of recording them to the chip, recorded them to the camera memory. I don't have special cord from the camera port to USB to retrieve the picture to the computer....
Go into playback mode. In the camera menu is an entry for copy image. It gives you the option to copy the contents of the internal memory to a memory card.
Sep 08, 2010 | Pentax Optio S5i Digital Camera
Having problems with memory card/camera. it says no image when i want to look at the photos i took, but i no i didnt delete them, does this mean i've lost the pics i took last night
Did you remember to format the card in the camera before trying to use it with this camera? Anyway, if indeed pictures exist on the card, take it to a store like Walmart that has a Kodak picture maker machine and it will be able to retrieve your pics. You can print them or even make a cd of them.
Nov 23, 2009 | Fuji FinePix A345 Digital Camera
Striped pictures
The sensor chip on which focused light falls has a failed connection. The image is 'read' via a matrix that is scanned to retrieve the image and one of the paths of this matrix is broken.
Oct 14, 2008 | Kodak EasyShare Z760 Digital Camera
Retrieve photos
Don't Panic just check memory card. It might have come out bit. Just put it back properly and you will get the images back.
May 07, 2008 | Fuji FinePix A500 Digital Camera
Lens error on brand new G9
i got the exactly same problem!!
i bought it on 16th/Feb, next day,17/Feb not more than 20 pictures i took, the issue comes (lens won't action while shift the zoom lever, but it's working ok while switch on and off the camera)
so i bing it to the shop with my angry, they just said to me that you must dropped the camera.
--but i sware i didn't !!!
now they took the camera to Canon base for the exam...
Jan 20, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
I dropped my camera and now the pictures are funny...
What you describe is the symptom of a stuck shutter. The shutter is inside the lens and must close in order for the image sensor to properly record the image. Yours is stuck open, and that is why you see the lines across your images. When a stuck shutter results from an impact it usually requires full disassembly and manual re-setting of the delicate shutter blades. This problem would require professional repair. Unfortunately damage from an impact is not covered by your factory warranty. You can find good repair services on the internet who can service your camera. David Millier Advance Camera Repair
Dec 17, 2006 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Canon PowerShot A510 Digital Camera Logo
144 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
