Re: Maytag over the range microwave rattles during...
Microwave works fine. During operation there is a rattle sound. The table moves correctly, only problem is the sooud of a rattle. It appears to be on the right side, lower area.
My built in microvewave over my stove is a 2004 model. It is heating the food and the turntable is moving correctly but it is making a loud rattling vibrating noise. We have replaced the carbon filter and it is still making that noise. Please help.My built in microvewave over my stove is a 2004 model. It is heating the food and the turntable is moving correctly but it is making a loud rattling vibrating noise. We have replaced the carbon filter and it is still making that noise. Please help.
You can't post conmments that contain an email address.
Many factors at play here. Are you cooking on the range? Are you using the microwave? Is the light on?
There is very little current going to the touchpad and if there were a short in it the touch pad would not work. It is just heat from another source. Don't worry about it.
Make sure you tighten all the attachment screws that may have loosened during long term usage. Make sure the fan is running properly and not causing undue vibrations. Use WD 40 on the fan.
This may sound a bit nuts, but remove the glass tray and support ring. Clean the wheels and ring. Also clean the glass and microwave surface where the wheels run. Any tiny bit of debris will stop the wheels from turning, and make a rattling noise. If that doesn't help, you may need a new turntable motor.
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Sorry!
It could easily be a bad line fuse and/or line filter. To access you will need to unplug the unit and remove the outside case. Inside the unit, where the A/C power cord comes in, there should be a small circuit card (part #237068) located somewhere with a fuse mounted on it. This is your input line filter board with line fuse. Replace the fuse, first and see if this fixes your problem. This is a 20amp appliance fuse that you can purchase at any hardware store. Make sure you place the cover back on the unit BEFORE you plug it in. It is not safe to have this area of the microwave exposed with power applied. High potentials in the 4,000 volt range are present! If the fuse does not correct your problem, the circuit card runs about $26.00. Good luck and hope this fixes your problem.
