Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
TV is cutting in and out of color
My tv is stuck on channel 3 and wont change. the color keeps going from color to gray and sounds like a soft popcron screen sounds. The box on the bottom with the favorite channel is completely clear and works perfectly. HELP PLEASE!!!!!!!!!!!!!
  • Hagnela Apr 26, 2008
    I have not picture on the top half of my screen. teh the bottom half is fine? It won't change channels or anything. HELP!
My sony Trinitron TV just shows a padlock on the screan.Please help me unlock it.
Posted on Mar 17, 2008
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
Ge 20gt610 tv
It sounds that the degaussing posisor resistor at the circuit has failed. dd297058-fa58-4c22-9e19-4c58832b6fca.jpg42497af9-8189-4bdc-99ba-85f3aca519fd.jpg
It will look somewhat like this.
Jun 05, 2013 | Televison & Video
Can't get "no signal" off
Hey cthaemar, it sounds like it may have been switched off the correct channel. If it is hooked up with a Coaxial cable it will be on channel 3 or 4, and if it is hooked up with an AV cable then it would be on one of the inputs.
If it's channel 3 or 4 try pressing the gray TV button on the remote and changing the channel. If that doesn't work you may need to use the TV's remote or the TV itself.
If it's on an input press the same gray TV button and then try pressing Input. With this you can also try the TV remote or the TV itself to change those if our remote doesn't change it.
Let me know if you have any other questions or concerns!
Tommy Faust
DISH Network
Jul 12, 2011 | DISH Network 322 DTV Receiver
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
WHEN I TURN ON MY L32 I GET NO PICTURE. I GET BLACK SCREEN THEN LOTS OF COLOR, REDS ,BLUE ,ALL COLORS IN DIFFERENT PATERNS THAT KEEP CHANGING. SOUND IS PERFECT AND I CAN CHANGE CHANNELS AND VOLUMEAND...
It sounds to me like it's stuck in service mode.There is a button combination with the remote to return it to normal. I would call Vizio support and they should be able to help you.
I think it's a combination like [volume -], [channel -] and power but I could be wrong.
Dec 19, 2009 | Vizio L32 32 in. LCD HDTV
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
Tv stuck on channel 2, need channel 3 for converter. remote nor buttons on front will change channel
Unplug the tv. Before you do a channel search make sure that you have the converter box plug in and turn on.
Nov 27, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
I have a JVC tv, model number AV-29RS and i have this problem that there is the channel number that comes up on the top right hand side of the screen in a gray box and wont go away. The only way i can get...
this happens as the wrong code on the remote control is ther
cab you reset it and authomatically change it into another code
try other code Phylips may do as Itt also
try and buy another remote comtrol as sometimes other works better as it seems your is getting stuck
Sep 27, 2009 | Televison & Video
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
178 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
