Question about Akai PT4298HD Rear Projection Television
Akai pt4298hd picture is to bright
Picture is weak and color is washed out
  • 53 Answers
Sounds like dirty lenses to me. Do some research on optics cleaning for RPTVs. AVS is a good place to start. Also try this:
http://www.keohi.com/keohihdtv/learnabout/generaltips/screenoptics.html
Posted on Mar 19, 2008
SOURCE:
Mi televisor no enciende solo se prende el foco rojo y parpadea en donde dice timer
bueno tengo una television pt4298hd akai el problema no enciende parpadea el foco de timer 10 o 9 veces y no enciende destape la tapa de atras y desconecte un cable rojo que tiene el nombre de screm y la television enciende pero no se mira como debiera porque se mira el color verde y el rojo pero como si le faltara el color azul mi televisor es una dlp akai de tres lentes y quisiera saber cual es el problema
May 02, 2011 | Akai PT4298HD Rear Projection Television
The screen shows a double print in red
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 24, 2010 | Akai PT4298HD Rear Projection Television
My Akai Rear Projection Televison has a good
I'd like you to turn the color all the way down and let me know if the over-all picture looks Black&White or as we call it gray. Did this just happen or has it been changing over time?
Feb 28, 2009 | Akai PT4298HD Rear Projection Television
Akai PT4298HD..Please help!!
Normally, yes.
Make sure you get the CG Board Part number:
BP94-00155A
There are other boards in this set that say convergence, but, they are not the boards you want.
Available at:
Andrewselectronics.com
Easy to replace.
Any questions, reply to this post and I will respond.
Jan 13, 2008 | Akai PT4298HD Rear Projection Television
Akai
yep you need convergence amp replacment for your set..very common prob call experienced repair person for this job use original replacements....john
Jul 31, 2007 | Akai PT4298HD Rear Projection Television
Akai tv
have a good tv guy repace you convergence amp's john
Hourglass shaped red
I need to see a picture of the TV set. send a photo to [email protected]
Jun 05, 2007 | Akai PT4298HD Rear Projection Television
AKAI PT4298HD
If you have a good picture except for a missing color all the various circuits are working OK. Most likely you have a bad solder joint or component in the red circuit. This would also be indicated by the fact that ocassionaly the red pops in. If you have the experience remove the boards and inspect for cracked or cold solder joints. Resolder anything that looks suspicious. If this does not fix it you will have to troubleshoot the red drive circuits from the CRT back to the video IC. Another possibility is that you have a bad/intermitant red crt. I doubt that you have the equipment to check this but you can test it by moving the green crt board to the red crt. If it now works the red crt is OK. If all this fails you will need to find a reputable repair shop to look at it. If the unit is more than 5 years old it may not be worth fixing. Good luck.
Jun 02, 2007 | Akai PT4298HD Rear Projection Television
My tv
If the colors are red,blue,and green, then look for you convergence controls in the menu or off remote. If problem is more intense, then the convergence amps maybe needing soldering or replacing.
Apr 30, 2007 | Akai PT4298HD Rear Projection Television
Akai PT4298HD Rear Projection Television Logo
66 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
