Question about Refrigerators
Fridge kitchenaid refridgerator leaks
    Scholar:
  • 54 Answers
Clean the door seal and ensure that there are no gaps between the sealing surfaces of the door seal and the refrigerator, if there is, relatively warm moist air will continually feed condensible moisture to the cold gap in the seal and the condensed water will drip on the floor. If the door seal its self is broken or torn it will have to be replaced to stop the drip.
Hope this helps.
Posted on Mar 16, 2008
SOURCE:
Kitchenaid ktrs22khwh00 feezer ices up and water leaks onto fridge shelves
not defrosting, bad thermstat
bad heating element
bad defrost timer
Aug 30, 2014 | KitchenAid Refrigerators
Kitchenaid superba leaking icemaker at quick connect
Go to Home Depot and get 1/4 Inch brass fittings from the plumbing section they will work better.
Nov 09, 2013 | KitchenAid Refrigerators
I keep getting water leaking at the bottom of my KitchenAid Fridge
Fridge has a design issue. Duckbill drain valve clogs. They have a new ptrap drain replacement but you have to ask for it, as customer service will deny a problem exists. Here is the service bulletin which was supposed to be for internal use only! https://docs.google.com/file/d/0BzIiBNwRIV4NNWJNNmx0andROGs/edit
Apr 12, 2013 | KitchenAid Refrigerators
Finding water at bottom of fridge
Most probably the water can be the overflow from the drain tank of the fridge to which the auto defrost condensation flows. Also if there is any leak onthe tubing from the evaporator tray this can happen.
So remove fridge forward and check,
Sep 22, 2010 | KitchenAid Refrigerators
Underneath the freezer side, way in the back there is a constant drip coming from the tubing there, it then fills the catch pan underneath which then leaks onto the floor why it this tube suddenly...
Assuming you have the KitchenAid fridge depicted, it has cold water and ice-cube making facilities installed, have you had these plumbed in to the water supply?
Obvious thought is a leak on the pipeline or control valve-gear, which I think is located to the rear lower left of the unit (looking from the front.
Otherwise all ‘frost-free’ fridges have a drain pipe from the refrigerator compartment drain trough inside, to a plastic container clipped to the top of the compressor. Here the condensate from the fridge is evaporated off due to the running heat of the motor. Check that this pipe is plugged in where it should be and that it is clear of any debris, old food-stuff etc. Some fridges had a fold of foam ‘cloth’ somewhat like a ‘dishwashing wipe’ stood upright in the plastic container to better evaporate the fridge run-off.
If the fridge is only now making excess condensate look at the door seals and run your hand all around when closed to see if you can feel any cold air loss from a particular area. It is sometimes worth running a little silicone grease down the seal on the hinge side of the door, to ensure it slides easily and doesn’t get creased.
Sep 13, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Freezer not getting cold
Call local Repair shop, No Fix possible, leak in the coils, can't repair.
buying new fridge.
Mar 22, 2009 | KitchenAid Architect® Series II KBRS22KT...
Ice maker not working/ water leaking from bottom
turned out the filter had a leak. So first shut of the water valve that made the connection to the fridge then twisted the filter counter clockwise and replaced it with a new filter.
Jan 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
133 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
