Question about Sony Playstation 3 (PS3) Console
Connection Problems I'm trying to play online, I have a connection, And i'm hooked to a wireless router. I can get in and challange a player but i can't connect to play.
  • Anonymous May 11, 2010
    did you tried to use not wireless router
Wat if we don't have a connection
Posted on Mar 16, 2008
SOURCE:
I play NHL09 online with my PS3. I have Comcast
I think you may find that this will be entirely your isp. do you have a particular broadband cap and have you used it all? have you tried it with any success with any other online multiplayer games? One thing you can try is to hardwire your ps3 to your router and see how you go
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
Connection interuptted wen playing online!
I am guessing the PS3 is hooked up through a router, either wired or wirelessly. You need to browse the router setup for the IP address of the PS3, then put the IP of the PS3 into the DMZ, also in the router setup. This should clear up any connection problems
Feb 11, 2009 | Sony Playstation 3 (PS3) Console
Connection lasts about 5 minutes
Basically if you do a connection test on the ps3 and it comes back as NAT3 then you will have problems. You need to forward some of the ports of your modem to get to NAT2. You will need to assign static ip addresses to your PS3s so that you can set up port forwarding
You may have interference from a nearby cordless phone (keep these away from router), could be interference from neighbor, try changing channel you use on wireless router.
Some people have reported success just by turning off SSID broadcast in the wireless router.
PLAYSTATION®Network Guide
Jan 26, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Problems hooking up a Linksys wireless router
Please disconnect the USB cable that connected from the modem going to your PC. Now connect the ethernet from your cable modem to the Internet port of your router. Run the setup CD, that should guide you and will make you up and running connected to the router.
Nov 20, 2008 | Linksys Wireless-G WRT54GS Router...
Wii connection issues.
You can check if the problem is with the internet connection going to the Wii or just the wireless connection.
When you loose connection, check the Wii's ip address. If it does not have an ip address(or ip is 169.xx.xx.xx) that means that the Wii is disconnecting from the wireless network. You can then try other wireless channels on your router.
If the Wii is still getting an ip of 192.168.x.x, that means that the problem is the internet from the router. You might need to forward ports on the router for your Wii.
Mar 13, 2008 | Linksys Wireless-G WRT54GS Router...
Hooking up xbox live
Well, it's very possible if you are using a wireless router that your connection may not be strong enough. XBOX Live and most online gaming requires a steady. strong, high bandwith connection. A weak singnal, OR someone else using up the bandwith (i.e. someone downloading music on another computer connected to your router) can cause the problem.
If you're using a wireless connection, try moving the router and wireless game adapter closer to each other.
If you're using a hardwire connection from one of the routers outgong ports then make sure other's aren't on the internet (Or at least aren't using alot of bandwith) while XBOX Live is being used.
Please remember also that if you have a wireless network and you haven't implimented wireless secruity (i.e. WEP or WPA encryption) then your network is "Open" and anyone within range can connect and use up your bandwith,
Feb 24, 2008 | Belkin (F5D7230-4) Router (587009)
No internet connection on web browser
The problem may be in the router itself, prehaps a faulty product. But I am more inclined to think it is the outdated copy of windows 2000 which you use. In my view 2000 was second to Windows ME in terms of faults, errors, recoginizing hardware, and what have you. I would take the router back to walmart and test with a new one, but if that does not help, then it may be time for you to upgrade. Have you tried getting the ps3 online even without the computer having an active connection? Give that a shot and if for some reason the ps3 grabs the signal then it is time to give in for sure man. And watch the router when you try to connect the ps3 to see if it even attempts to grab the wireless connection, the wireless light will start blinking rapidly if it does.
Jan 25, 2008 | Linksys Wireless-G Broadband Router
PS3 Internet Connection/Upgrade System/Online Play
Do an internet connection test. Your NAT type should be either 1 or 2. If not then there are some restricted ports on your router.
I find that putting your PS3 in your router's DMZ (demilitarized zone), solves all connection problems.
Dec 11, 2007 | Sony Playstation 3 (PS3) Console
Connecting online Madden 08 ps2
I experienced the same problem. I have the ps2 slim. The problem was so bad that i had the slim for about 3 years and still could not play any ea games online. About 2 months ago i finally got it to work though, allowing me to play madden ncaa and many other sports games from ea. I also have dsl broadband just like you. I do not have a router though. I just hooked my ethernet cord straight into the back on the ps2, my computer is really close by. I would reccomend a router though.
Enough of this bs though. Now solving the problem. There was actually a firewall keeping me from connecting to ea servers. Which in turn meant no ea account and no ea play online. Go onto your computer and turn your FIREWALLS OFF. This still may not work though. I done this and an unknown firewall was still blocking it. THERE WAS A FIREWALL IN MY MODEM.
CALL UP YOUR INTERNET SERVICE PEOPLE AND TELL THEM TO TAKE THE ******* THING OFF SO U CAN ******* PLAY. I ALSO FOUND THAT LIMEWIRE WOULD NOW WORK ON MY COMPUTER AS WELL.
By doing this you will open peer to peer connections with other programs and players online.
Nov 10, 2007 | Sony PlayStation 2 Slimline Console
X box 360
You can't get an IP address on the Xbox that way. You need to get an IP address from a device that works as a DHCP server such as a residential router. Connecting the Xbox to the PC will do nothing for you.
Nov 08, 2007 | D-Link DI 514 Wireless Router (DI-514)
Sony Playstation 3 (PS3) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
