Question about Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 500 "Radio Boy"
No AM and SW just humming. FM works fine.
  • Bill Narey Mar 16, 2008
    Does this model have fuses?
  • Bill Narey Mar 24, 2008
    I got the problem fixed. I'm not that keen on this kind of radio. I talked to a guy that said to turn the AGC / MGC knob to the AGC until you hear the click. It worked. I have AM/SW/FM now.
    Runnynose
2 Suggested Answers
rolltape
  • 58 Answers
SOURCE: I have a Grundig Satellit 500 "Radio Boy"
If you sent it in 3 times, then I would suggest getting a new one if you know for sure that other's work in that area. If other's don't work, then then you have some type of interception between the radio waves and your radio. There is nothing I can do about that, and probably nothing you can do.
Otherwise, you should get a new radio.
Posted on Mar 16, 2008
Benimur
  • 6966 Answers
SOURCE: Grundig Satellit 500 "Radio Boy"
Offhand, can you pls try and do a reset. This model don't have a reset button, but you can try removing the batteries for say an hour or so. The idea is to reset the microprocessor if the problem is software/firmware. Preset/memory would be erased as well as any personalized settings if you do this. But the unit will be back to factory default.
If the reset doesn't work, then your particular version/model has a slight offset resulting to the "humming sound". This is a known problem and many in the "ham" world have written corrective procedures which would require an insulated tuning/alignment screwdriver or at the very least a jewellers screwdriver and doing a bit of alignment by "ear"
If you are adventurous to give this a try, pls post back. Otherwise your best bet would be to seek the services of a qualified ham radio technician.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Grundig Satellit 800 LCD display doesn't work correctly
If the radio uses memory batteries, try changing these with new alkalines. The microprocessor needs this power to drive the display.
Jan 30, 2010 | Grundig Satellit 800 AM/FM/SW Radio
Mar 16, 2008 | Audio Players & Recorders
Can u give me the pincode of that area
Feb 04, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Looking for manual
HI,
DOWNLOAD PDF FILE FOR 800 SATELITT
GO TO GOOGLE ENTER SAT 800 GRUNDIG PDF
YOU WILL GET A MANUAL FREE OF CHARGE....
Nov 13, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Mar 16, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Repairing Grundig Radio receiver Satellit 3400
GRUNDIG SATELLIT ST 1400 SL
Diodo Zener ST601 Volt ?? (SU ALIMENTAZIONE)
HELP Simon
Feb 27, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 500 loses reception
Hi
I had such a pb.
IC 103 CX7961 stopt to oscillate after ~30s ...
so the plls ref was out
I changed it without results
In fact the plastic trimmer C138 (4-20pf) was bad???( insulation?)
Since changing (10 years ago) : no problem
Good luck
Dec 13, 2007 | Grundig Satellit 800 AM/FM/SW Radio
Loses sound
It is soppoused to seek when pressing search and scan and scan buttons If you dont like the idea of that for now on only use tuning up and down dial or buttons.
Nov 20, 2006 | Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 800 AM/FM/SW Radio Logo
71 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
