Question about LG DLE5932W Electric Dryer
Dryer Hi our dryer take forever to dry the clothes now is there more than one heating element
    Sergeant:
  • 236 Answers
Things to take into account- are all the filters/ customer cleaning service parts clear?
is there good airflow and are you overloading the unit? there should only be 1 heater element controlled by a reduced heat switch.
Posted on Mar 16, 2008
Not catching lint or drying clothes
Hi Diane
Sounds like you have a clogged vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Bud
Oct 12, 2013 | Maytag Dryers
Cloths are not drying in one cycle and need to extend the time of the drycycle not sure how? Model no dcd330gy1wc
Hi demetriosqat...
Sounds like you have a Clogged Vent or Heating Element problem.
Heating Element
Cycling thermostat
Please take time to rate me thumbs up.
Sep 10, 2011 | Dryers
The dryer heats up but doesnt dry the clothes... what could be the problem
Hi rissa306
Clogged Vent
Heating Element
Cycling thermostat
This is a Free answer, Please rate me.
May 23, 2011 | Dryers
I have a Maytag Legacy Electric Dryer Model MED5570tq0. It turns, gets heat, but does not dry the clothes. It would take 2-3 cycles to dry clothes. Any suggestions?
Hi jamesholl456...
Heating Element
Cycling thermostat
Apr 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
Dryer takes forever to dry clothes. now it will not dry clothing
Clogged Vent
Heating Element
Cycling thermostat
Apr 11, 2011 | Dryers
My Frigidaire dryer has an error code of AD and is taking forever to dry our cloths. Please help.?
Hi
Thanks for using FixYa. Error code AD means air/auto dry. This type of dryer has no thermo fuse which is a fuse like part that tends to break disengaging the heating element, there for the dryer has a busted heating element, you’ll need to replace it then it should be good to go. Normally runs parts and labor about 150. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 28, 2010 | Frigidaire Dryers
My kenmore dryer heat element goes on and off. The clothes take hours to dry.
It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Dec 31, 2009 | Kenmore Dryers
The Dryer runs forever and the clothes dont dry
there are two elements on the back wall of the dryer and if one goes it will still get warm but not to dry all the way and will not trigger the heat sensor to finish
Dec 12, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
My dryer is a LER3624JQ1 it heats up but takes forever drying clothes. I have to run it 2 or 3 times. Help
Drying is too slow
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Good Luck!!
Thanks
Jul 07, 2009 | Whirlpool Dryers
Our dryer takes multiple cycles to get clothes dry. Eventually the clothes dry, but it takes forever.
If your dryer is taking more than an hour, check these. Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws. It overheats Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat (read about cycling thermostats in "Drying is too slow," above). It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But?if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork
Jun 12, 2009 | Whirlpool Dryers
LG DLE5932W Electric Dryer Logo
111 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
