Question about ASUS A7V8X Motherboard
Pc upgrade !
My pc has the following spec- ASUS Nforce2 A7N8X motherboard with AMD athlon XP 2400+ processor , 512mb ram and NVIDIA GeForce2 Integrated GPU (GeForce2 Integrated GPU) - NOT sure but does this mean that my graphis card is integrated with the motherboard?
My plan is to upgrade the processer ,Ram & graphics card .
The new processor will be -
AMD Athlon™ XP 3200+, 2.2 GHz (AXDA3200DKV4E) OEM which has Front Bus frequency =200MHZ and clock multipler = 11 BUT exsisting
OLD 2,4ghz chip has a front bus frequecency =133 mhz and clock multiplier = 15 will these differneces be automatically taken into account by the new chip and motherb or will i have to make some physical adjustments to either or the software?
Are there any stepping codes you know of that i should avoid?
The RAM i have NO problem with but the Graphics card if the old one is integrated how do i switch it off and when i place the new
one in which will use the AGP cons and will be DDR2 will their driver setup disc lock after it's instalation or will i need to do any thing else?
HELP!
IAN.S
    President:
  • 2,351 Answers
IAN.S
Where you need to be is on Asus web site. Your board can handle ONLY; Athlon XP 3200+(400 MHz FSB)(Model 10)(Barton), AXDA3200BOX
With that CPU you must also have bios version 1004.
Check PCB and BIOS versions before flashing BIOS!
asus A7N8X supported CPU click here; http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=A7N8X
Since you seem to need your manual. Click the link:
http://dlsvr01.asus.com/pub/ASUS/mb/socka/nforce2/a7n8x/e1859_a7n8x.pdf
You do not have an intergrated video card. You have a 1.5v 8x
AGP video slot.
I suggest you call Asus & make sure your CPU model AXDA3200DKV4E will be supported over model AXDA3200BOX.
You can call Asus tech M-F EST at 812-282-2787.
Good luck & Have a great day!
Posted on Mar 16, 2008
Greetings. I wanna upgrade my processor from amd sempron 3200+ 1.8 ghz to athlon 2 x2 260 processor. But when I put the athlon 2 x2 260 proc, it didnt work.
Did you check to see if it would handle that type of upgrade? Maybe that's your problem, it's not compatible. Research and see if it can handle it, then we can find a solution if it can.
Jun 03, 2012 | AMD Computers & Internet
The AMD xp1500 processor is slow. Its need to be faster than it is. Need to know. Cheers!
If your computer has less than 512MB of RAM, then that is one "bottle-neck" that hurts your computer's overall performance.
Consider adding 512MB or 1024MB of RAM.
Or, your motherboard probably will accept other AMD processors in the "Athlon XP" line. Take your computer to a computer-store, and see if they can sell you a '2600+' or '2800+' AMD CPU that will be compatible with your motherboard. That upgrade will make your CPU almost _twice_ its current speed.
Oct 22, 2010 | AMD Athlon XP 1500+ , 1.33 GHz Processor
How to upgrade processor on ASUS A7A266 motherboard?
looking at this old motherboard the 2400 is unlikely to work, the motherboard has a cpu fsb support of 133mhz and supports the duron processors.
offhand, 2400 wont work.
Mar 18, 2009 | Computers & Internet
HOW CAN I UPGRADE MY SYSTEM
it depends on how big the ram and the hd is. the bigger the hd and ram the more expensive it is except for their transfer rates. if your planning on upgrading because of games, you will need atleast 7200 rpm for the hardisk which costs more than a typical one. but for all i know thats the default for a desktop. there are 10,000 rpm also which are more expensive than the bigger hd's. same with the RAM. you can check ebay for the price. but the price depends on the country you are in if your buying it from your place.
Feb 06, 2009 | AMD Athlon XP 2000+, 1.67 GHz Retail...
Cost of game hardware in india
2GB RAM should be about $100, the same for installation. Your current graphics card meets the specs you provided. An upgraded video card will be about $200 for one that will work, $300 for one that will work well.
Jan 19, 2009 | Computers & Internet
Memory +cpu upgrade
No to the cpu you selected. Board would not support that cpu. The RAM you selected would probably work but for how long I couldn't say. With prices pretty low right now it would probably be better to purchase a new motherboard, cpu, & RAM. Hope this helps.
Jan 10, 2009 | MSI MS-6367 Athlon XP 266FSB MicroATX...
Memory dump.
It dumps coz you havent enough of memoy, instal at least 512MB more and you will get rid of that problem
Good luck to you
Dec 30, 2008 | MSI KT2 Combo-L Motherboard
Installing extra memory causes freezing + closing down of pc
Check these specs for your board.it will support 2gb but only if its pc2700.anything greater will not boot or become unstable quickly.here are your specs.also i am enclosing an ASUS link for any and all manuals etc. for this board.asus a7n8x-vm motherboard
Specifications www.microsoft.com/Genuine"] --> CPU Socket A for AMD Athlon XP
Thoroughbred/ Barton Core Support Chipset NVIDIA nForce2 IGP
NVIDIA nForce2 MCP Front Side Bus 400/333/266 MHz Memory -Dual Channel Memory Architecture
-Supports up to 2GB of 2700/PC2100 DDR memory
-2 DIMM sockets Expansion Slots AGP8X (1.5V only)
3 x PCI VGA -Integrated GeForce4 MX GPU
-Integrated TV encoder
-NVIDA nVIEW dual-display architecture
-Support DVI (AGP-NV-DVI) and TV out (AV/S) cards Storage/RAID 2 x UltraDMA 133/100 Audio Realtek ALC650 6-channel CODEC
S/PDIF in / out interface LAN Integrated 10/100 Mbps LAN controller + Realtek PHY USB Integrated 6 USB2.0 ports Special Features Power Loss Restart
Support S/PDIF in / out interface
ASUS MyLogo2
ASUS C.O.P. (CPU Overheating Protection)
ASUS EZ Flash Back Panel I/O Ports 1 x Parallel
1 x Serial
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x VGA
1 x Audio I/O
1 x RJ45
4 x USB 2.0/1.1 BIOS 4 Mb Flash ROM, AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI, ASUS EZ Flash, ASUS MyLogo2 Industrial Standard PCI 2.2, USB 2.0 Manageability WfM 2.0,DMI 2.0,WOL by PME,WOR by PME, Chassis Intrusion Support Disc Drivers
ASUS PC Probe
Trend Micro™ PC-cillin 2002 anti-virus software (OEM version)
ASUS LiveUpdate Utility Accessories User's manual
UltraDMA cable
FDD cable
I/O shield Form Factor microATX Form Factor, 9.6"x 9.6"(24.5cm x 24.5cm)RICHARDM69
Dec 15, 2008 | ASUS A7N8X-VM Motherboard
Processor
This are the compatible with this motherboard : Compatible Processors - Athlon, Duron, Athlon XP , Processor Socket - Socket A , Chipset Type - NVidia nForce2 400 , Max Bus Speed - 400 MHz .
This is the complete specs for this motherboard , check this link http://www.shopping.com/xPF-Asustek-A7N8X-X-Socket-A-LAN-nVIDIA-Audio
Don't forget to rate the solution FIXYA thank you.......
Oct 18, 2008 | ASUS A7V8X Motherboard
Processor upgrade
Need to look at the motherboard specs along with the processor "Socket". It will usually be a 754 or 939 depending on what your motherboard says. I wouldn't try too fast and set yourself up for disappointment. I would upgrade the RAM before the processor.
Mar 22, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
ASUS A7V8X Motherboard Logo
134 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
