Question about Sony Grand WEGA KDP-57XBR2 57" Rear Projection Television
QUEStion About Sony KDP57XBR2 57" rear projection High Def PiP 1080 TV>>>>
Okay, my
Sony KDP57XBR2 57" rear projection High Def PiP 1080 TV, went though a recent power surge. Now, Error code = LED, flashes 5 times....What do i need to do??
    Sergeant:
  • 395 Answers
5 flashes is IK or current to cathode. check the IC's on the crt boards, check the focus block, check the vertcal deflection IC since the IK pulses come from the verticl cicuit.
Posted on Apr 01, 2008
SOURCE:
I have a 51 inch hitachi projection tv! I need to
Go to settings in menu, and video labels/names.
Oct 05, 2014 | Televison & Video
My 57" Toshiba projection TV recently started having picture problems. The picture is distorted and wavy. The picture on the PIP screen is fine. is this a common problem and is it fixable?
First bypass the cable box and hook the tv directly to the cable to see if the problem goes away. if the problem persists you possibly have a bad input board.
Mar 13, 2010 | Toshiba 57HDX82 57" Rear Projection HDTV
We hooked our Sony kp43ht20 to dishnetwork. Now the screen is not full screen. How do we make it full screen again? And where is the ratio button to change to 1080?
Is this hooked to a high definition dish network? If so there is a format button on the remote to change the picture size. As far as changing it to 1080 it will only broadcast in what it sees if it is not in high def it can't broadcast in hi def.
Dec 16, 2009 | Sony KP-43HT20 43" Rear Projection...
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
I have a mitsubsihi ws-65907 and hooed up a sony blue-ray dvd player, I can only get a 480i resolution, is there a way to change it to 1080i?
Make sure the cables from the blue ray player are hooked up to the right 1080 high def input jacks on the back of the TV. There is two different sections, one for regular 480 inputs and another for the 1080i....
Dec 26, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Sony kdf-55e200 willony display high defination signals all other have audio only
If only high def comes through, you have a doubler problem. all inputs that arent hd need to be scaled to 1080 to be displayed. if only hd works, your problem is the double = b board
Dec 07, 2008 | Televison & Video
Can a hdmi port be installed to a panasonic TH42PA50A
No, besides your television can only do enhanced definition (852 x 480) High def is 1920 x 1080. HDMI is for high def only, however, if you have something with an hdmi output that you need to connect to your tv there are adapters available to make such conversion. Sorry for the bad news but hopefully this helps
Jun 28, 2008 | Panasonic Televison & Video
High def tv: We replaced the lamp unit, but don't know how to reset hour meter
turn the TV power on the projection display or remote control.while pressing the volume button on the projection display hold down the PIP or split button on the remote control simultaneoulsy for more than 5 seconds.
Dec 30, 2007 | Panasonic PT-43LC14 43" Rear Projection...
Colors Off with High Def Comcast Cable
check your cable connections between tv and box, especially the red connector, try unplugging and plugging back in the cables.
Jul 09, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Open Questions:
See all Sony Grand WEGA KDP-57XBR2 57" Rear Projection Questions
Sony Grand WEGA KDP-57XBR2 57" Rear Projection Television Logo
154 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
