Hi ,
i bought GE refrigerator 2years ago.
model no is: GSH25JSRF
Suddenly one day water flow is stopped from the dispenser.
I changed the filter, still no use.
What is the solution.
Hope u guys reply me.
Thanks.
Kris.
I ihave a side by side samsung rsh1dbbp with ice and water dispenser but the water has stopped working i was wondering if you could tell me how to get the front panel off to check the switches
Modern refrigerators utilize a dual solenoid one for the ice maker and one for the water dispenser so it is possible for one to fail while the other still operate the way to check this is to disconnect the water dispenser supply line (on the refrigerator side of the solenoid valve)and verify that water is released when the water dispenser button is depressed. If not then check to assure that the solenoid is receiving 110v power when the switch is depressed if so you have found the problem if not you will need to check for continuity at the micro switch in the door panel. If the solenoid operates properly and yet when you reconnect the water line you still receive no water at the dispenser its possible that the reservoir that cools the line before dispensing the water has frozen. Food freezing in the crisper section would indicate that this is likely, its also possible for the line to freeze in the door if the insulation around the line has shifted and left a portion exposed. Hope this helps.
I have the same issue....were you able to fix it?
