Question about Samsung Digimax S500 Digital Camera
Camera powers off after seconds
When I power the camera on the green light comes on and the screen lights up but only for about 4 seconds and then it powers off
  • 3 more comments
  • RhapsodyPink Apr 07, 2008
    My camera is doing the same thing. I put fresh batteries in it and it continues to do that same thing. The lens also won't go back in.
  • malph Apr 07, 2008
    camera turns on for a few seconds then beeps three times and shuts off
  • Anonymous Apr 07, 2008
    My camara is doing the same...what should I do??
    Please help!!!
  • Samantha Browne Apr 11, 2008
    When turning the camera on the startup pictures shows but then turns off and begins to be 3 times. the lens never comes out. i've tried puttin new batteries in it but still... it never works
  • namoni May 15, 2009
    my camera turns on then beeps three times and shuts down plus the lens doesnt open
  • 75 Answers
Make sure that batteries are fresh and battery compartment is clean.
Posted on Apr 03, 2008
Not sure why this worked for me, but it did. Start the camera play mode (like your viewing pictures). Once the pic is up, press the silver photo shutter button (the one used for taking pics) down 1/2 way. My camera then extends and is fukky operational. Hope this work around helps!
Posted on Apr 17, 2008
The zoom's probably just a bit stuck (maybe there's a bit of dirt or dust in it). Pull gently on it to see if it unsticks. That worked for me.
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
Samsung digimax v800
The manual does not indicate what is wrong, when the green light is flashing, other than the flash is charging.
It could be the flash can't be charged, because the flash capacitor is defect, or the battery does not have enough power.
Try switching on the camera while not in automatic mode (M of so) or when in video mode. If the light on the main dial still flashes, I think you should look for another battery. But first try another battery, before you buy one. (Or test the camera with an external power supply. Don't forget to switch of the camera, every time you change the power supply.
Mar 14, 2014 | Cameras
I hit the power button and it turns green for a second but then goes out. The camera and LCD screen do nothing. So I have some sort of power problem. When I put the battery in the charger the charger light...
theres no choice your battery charger is may be out and try new battery and try the power cable from the charger and connect directly to the cam if you got the original power pack/ for the green screen it can go green or bleu when the battery go low, some time that is the video processor ic...
i hope for you it just the battery....
and good luck
May 13, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
Kodak easyshare M893 IS will not stay on. The battery has been charged and replaced, however, when the camera is turned on the green light comes on, the "Kodak EasyShare" screen appears for a second or...
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 23, 2009 | Kodak EasyShare M853 Digital Camera
My camera comes on (the green light blicks) for about one second then goes to red and won't come on. I have replaced the batteries several times
The camera turns on and there is a green light on the camera and instantly turns red
Try to use the KODAK Lithium Digital Camera Battery CRV3 There is a red light because the camera has insufficient power and also the lens assembly might be defective try to use the battery i recommend
Sep 23, 2009 | Kodak EasyShare C633 Digital Camera
Samsung L100 wont turn on
Samsung's have notorious problems with their lens-cap shutters malfunctioning. This seems to be the case with yours. It will have to be serviced, I'm afraid.
Mar 30, 2009 | Samsung L100 Digital Camera
Battery level
As Suzaku explained:
A battery icon will show up on the LCD screen of your camera when it is already low and needs recharging. It can be found at the lower right side of your LCD screen. The ready light of your camera will also blink red and your camera will turn off if the battery is exhausted.
NOTE:
The icon will not appear if the batery is sufficient and there is no TECH way of making the icon show until the batt needs charging.
Jan 04, 2009 | Kodak EASYSHARE M763 Digital Camera
NO LCD IMAGE / LENS STUCK
hi ban ive same problem bloody nusience lens wont retract what did u do with urs?
should i return it?
thanks leeanne
leeannehutchinson@btinternet.com
Feb 17, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Samsung Digimax S500 Digital Camera Logo
184 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
