Question about GE WDSR2080D Top Load Washer
Ge timer on washer is broken
Hi - the timer knob was turned incorrectly and it has broken the little plastic teeth on the timer assembly. Can I just replace the plastic wheel with the teeth? Or do I have to replace the entire timer assembly?
  • Anonymous Mar 14, 2009
    where do I get the part?
    Scholar:
  • 178 Answers
If it no longer clicks, the timer assembly will need to be replaced. If just the knob broke off, the timer should be good.
Posted on Mar 16, 2008
The control knob is stripped & I removed that; also found that the plastic part with teeth that the control knob operates is also stripped. Where can I find both parts and what is involved in...
Used to be that you could buy the ratcheting coupler piece for 5 or 10 bucks for the old GE machines. Alas, no more. The newer GE timer must be replaced if the teeth are stripped.
Be careful not to damage the indicator dial when doing this repair as it is about $20 for a round piece of plastic and a tiny steel clip. Pry this off using opposite points of the dial (grab it at the 9 o'clock and the three o'clock positions with as many fingers as possible) and pull gently so as not to set up any fractures in the dial's hub.
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Washer-Parts/Model-WCSR2090D1WW/0432/0153200/G0503026/00001?blt=06&prst=&shdMod=
Unplug machine, remove knobs, end panels. Remove remaining screws that hold the control panel and tilt forward. Removing the fascia will reveal the screws that hold the timer on.
Sears PartsDirect wants about $80 for the timer.
Good luck from Detroit, MI.
Jul 11, 2011 | General Electric WCSR2090D Top Load Washer
GE WASHER MODEL #WBSR3140G0WW: TEETH ON CONTROL
I suspect that a mounting tab has broken off the timer. Take the four torx head screws off the back edge of the top of the washer and open up the backsplash to confirm this. I manufacture a make shift Z shaped metal part to hold the timer in place without having to replace the timer.
Mar 25, 2010 | General Electric WBSR3140GWW Top Load...
Wash cycle dial wont turn...will still push in and pull to start
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing the knob turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you will get easier access to the retainer clip. You can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Jul 26, 2009 | GE WJSR4160DWW Top Load Washer
Broken knob on GE washer
There are four separate parts that make up the knob dial. You can pull off the knob if you use a screwdriver/pliers to remove the clip holding it on. Check if the mounting areas appear stripped or broken. There should also be a compression ring in the mounting hole on the back of the knob. That's what may be broken or stripped. These are all parts that you can get from a local parts store (check the phone book) and you can do it yourself. Any of those parts should cost less than $10. The bad news is if you stripped the pole coming out of the timer assembly. You would need to replace the entire assembly which costs about $130. If you call a GE repairman, you are looking at $89.95 or more just to have them show up. If it is still under warranty, there is no charge. You can call them to verify this:
1-866-383-3933
May 03, 2009 | GE WWSR3090TWW
Washer control knob just spins
The knob is prob stripped, very common for this washer.
Get it off and look at the teeth. To remove the knob you need a pair of surgical pliers. Reach behind the knob and yank the retaining clip out. If the teeth are smooth you need to replace the knob. Oil the timer so it will be easier to turn by the way. To put the new knob you simply slide it in place with the clip on it. So easy you won't believe it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 03, 2009 | GE WBSR3140DW Top Load Washer
Timer switch on GE washer
You don't state your exact model number, and the number off the timer is not the actual part number (it's some sort of part stamping number). Most likely what has happened is a plastic tab on the timer housing (which normally goes into a slot in the metal, and thus holds the timer at that point) has broken off. The fix is to replace the timer, but instead of buying a new timer, I usually fashion a Z type piece of metal which I can put one screw though into the metal and the other side holding the timer against the metal. Takes a little work, but it's a lot cheaper than a new timer.
If you want to take the timer knob off, you have to pull it out and use a thin tool, like a small screwdriver, to push the plastic clip off the shaft behind the knob, allowing the knob to then come off the shaft. Push the clip back on the knob when off, so that all you have to do to reinstall the knob is push it on and it will lock on the shaft again.
Dec 08, 2008 | GE WBSR3140DW Top Load Washer
Ge washing machine pull knob
Replace the knob...The teeth on the back of it have broken.
Dec 01, 2008 | GE WBSR3140DW Top Load Washer
GE top load Super Capacity 16 cycle washer (one year old)
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing it turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Dec 18, 2007 | GE WBSR3140DW Top Load Washer
GE WDSR2080D Top Load Washer Logo
637 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
