Question about Refrigerators
On electronic control panel and water/ice despensor the ice cube door keeps opening and closing and the buttons on the panel do not respond tempratures of fridg and freezer keep flashing. Tried unplugging and re = plugging with no luck.
  • jshassinger Apr 08, 2008
    A similar problem. The control panel has the temps displayed (but you can't adjust them), green light for ice is on and working (but you can't change to water). In fact, none of the buttons work ... panel is stuck with what was programmed, before the failure. Refrigerator is working normally with temps, etc.
    President:
  • Refrigerators Master
  • 2,651 Answers
You have a maytag ice and water in door 3 door refrig???? if so you needs a new high voltage board, its gone bad. locatdon back wall behind the refrig. only resolution is to replace the board..
Posted on Mar 16, 2008
6ya staff
SOURCE:
GE ice maker crushed ice selector does not work. It does work for cubes and water. Pushing the door button when cubes are selected causes the assembly in the back of freezer that moves a rod to open the...
Crushed ice makers have a tendency to freeze up the mechanism. So you might want to deinstall your ice maker and let it defrost for a day or two.
That would be where I started, but if that didn't fix the problem I would move on to the electronics/
May 06, 2012 | Refrigerators
HAVE A KENMORE FRIDGE M.#106.74253400 WATER DESPENSOR STOPPED WORKING AN CAN HEAR IT HUMMING AN ALSO THE ICE MAKER WORKS SO I NO ITS GETTING WATER? THANKS
my kenmore did the same thing, It had a duel water solenoid on it and one that let water into the door water dispenser went bad. also my ice cube started to get smaller, the rubber in the other side of the water solenoid was dry rotting and eventually ruined the ice maker. I replaced the duel solenoid and ice maker and had no more problems.The solenoid is on the back of the fridge, it is what the main water supply connects to.
Dec 31, 2011 | Refrigerators
Helo I have a KitchenAid KSBS25FKWHOO which is like this one. My problem is there is a push button for ice cubes or crushed ice and as of now no matter which button i push it gives crushed ice. How can I...
It sounds like your crushed ice flapper might be stuck.
Open the freezer and remove the ice bin by pulling toward you. Dump the ice into a container if you wish to save it.
Turn the bin upside down and look at the opening in the front that the ice drops out. There is a white flapper door that is controlled by a metal rod going all the way to the back of the ice bin. If you move the metal arm up and down from the back you should see the flapper door open and close. Open is for cubed ice and closed causes the cubes to travel through the blades and be crushed.
The most common failure is ice or frost build up around the flapper door that causes it to stick shut and not move to the open or cubed position. You can unthaw by running warm water through it in the sink. Dry completely before returning it to the freezer. Clean out any ice chunks from the chute in the door that might be slowing down ice. That should fix the problem.
Apr 18, 2010 | KitchenAid KSBS25IN Side by Side...
Water and Ice despensor stopped working last night.
You have a little control valve in the right lower back of your ref.It should be at the bottom.If it is bad you will not get water to your ice maker.If that is not it your ice maker is bad They are not that hard to replace.Cost for little control in back is about$30.Ice maker is about $90.
Aug 21, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE Side by Side only dispenses crushed ice
remove the ice cube tray assy, remove all the ice, save the cubes, wash the assy with warm water dry the assy, be sure the lever in the rear of this ice cube assy is moving and spring loaded, move the lever and it should snap back and return if so you know the unit is ok(the cube assy), now with the assy still out of the freezer close the freezer door and select crushed ice and push the pad where the glass normally hit to activate the ice cubes,if the operates and you here a thump and snap and hum most likely your ok,if not you could have a defective auger motor assy,but if you here all the sounds as decribed oped the freezer door and select cubed ice push actuator on despensor door with the freezer door closed, reopen and install the ice cube assy tray bucket assy,push it in firmley, and try it with some ice in the bucket you should be fine,if not replace auger motor assy..
nbcrca:)
Apr 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Door panel doesnt work
Check circuit fuse,electrical connections,check your door circuit & buttons.
Feb 21, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Ice despenser in side by side door, kenmore does not work
Pull the grill cover off near the floor and look to see if any of the wires have been cut. I found that the grill cover wore on the wires controlling the door functions. First the crushed ice function went, then the water dispenser went. I had splice the wires back together and am leaving the grill cover off. No problems since.
Jan 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frididaire Gallery series side by side with ice and water in the door
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Oct 14, 2007 | Frigidaire FSC23F7D Side by Side...
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
