Question about Toshiba Libretto 100CT Notebook
LCD vertical lines
I have a Libretto 100ct, and the LCD has vertical lines running up and down on one side, with one red line running on the left side, each line is 1 pixel wide and however many pixels from top to bottom of the display.
  • fdsman Mar 17, 2008
    how would I go about removing the connector?
Hi fdsman,
I had the same problem. Usually if its a bad connector you would have intermittent problems. Try hooking your laptop up to an external monitor. If the screen on the external is clean, then chances are that it's your LCD. Good luck.
Posted on Mar 18, 2008
Hi fdsman,
I had the same problem. It was the LCD. Usually the connector would display a wider band. Try to connect your laptop to an external monitor. If the external monitor shows a clean screen, chances are that its your LCD. Good luck to you. By any chance is your screen a 17" widescreen?
    Champion:
  • 238 Answers
Hi, all the LCD cable contact pins to be cleaned, if still invain then u will need to replace the LCD..
Posted on Mar 16, 2008
Lcd tv vertical line
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 26, 2016 | RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV...
How do I get the red line off the left side of center of the screen? It runs vertical !!!
HI
if the line is temporary then re connect the cables in side the tv but the line is permeant then change the panel because this kind of line is in side the panel & not removed.
thanks
Jan 17, 2016 | Sony BRAVIA KDL-60R550A 60" 3D 1080p...
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Have sony model KdL 40S2000, now has colored thin lines going up and down on the left side. Anyone know the cause.
Line faults & possible causes to LCD screen is given with illustrations.
Jul 29, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
LCD TV - RED LINE
I have a thin red vertical line on the left side of my Philips LCD TV
Feb 25, 2008 | Televison & Video
Permanent Red Line Down the left side of the screen
This can't be repaired, the LCD panel is a sealed unit. if you can't live with it then you need a new monitor
Feb 20, 2008 | HP Pavilion F1703 17" LCD Monitor
Red line across top half of screen
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Dec 02, 2007 | Gateway MX6438 Notebook
Libretto 100ct
Está desliogando sozinho.... o que fazer?
Oct 25, 2007 | Toshiba PA2502U - Libretto 100, 110,...
100Ct
Hi, Depends on what OS you are using. For this particular model (Libretto 100CT), it is probably either Win9X or RedHat (or some Linux variation). In Win9X, you might try F8 & run it in DOS and run: Scandisk c: /autofix /surface; Scanreg /fix If it is beyond repair you have to have access to the OS installer CD. Sometimes Win9X installer is also saved in the HD. Try checking if it is inside your HD and run setup. Hope this be of some help. Pls post again how things turn up. kind regards.
Jul 24, 2007 | Toshiba Libretto 100CT Notebook
Toshiba Libretto 100CT Notebook Logo
253 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
