A new chain pump kit definitely cheaper than a new saw $15.00. Below is a link with the kit for the saw Poulan 2150. Provided to you as reference I don't garrantee site or lowest price. If this has been helpful please rate answer. Good Luck and have a great day. Jeff
Part #530071259
If you perform the labor repair likely <$20 (<$9 for pump, <$1 worm gear). Compare replacement cost to 34cc± replacement, your call.
A link to a Poulan 2150 Gas Saw Type 7 follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2150-Gas-Saw-Type-7/75.2150-Gas-Saw-Type-7.1.59.1.html
If the link is not your saw it can be found here.
The IPL (exploded parts list) for your saw is the only detail for the oil system and it is sketchy at best. Oil components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
The oil pump is under the outboard clutch, this is helpful with removal.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
