Question about Lexmark X83 All-In-One InkJet Printer
Motor error Hi, when I turn my printer on it is okay for a minute then I get a message motor error and a piercing sound. Can anyone help with this problem. It gets stuck and I have to power down.
    Novelist:
  • 148 Answers
What has happened is the cradle has slipped a tooth on the belt or possibly has broken a tooth on the sprocket either way it will have to be looked at by a tech. This usually occures when the cradle has been physically forced from one side to another. take care .. Be mucho blessed... Mark
Posted on Jun 27, 2008
SOURCE:
Error 0xc05d0082
Remove cartridges,switch off the printer, dis connect usb cable & power cable.. wait couple of minutes..powering it wait till message appears for consumables.. install consumables., install usb cable.. check...for message.. Remove CMOS battery mounted on formatter wait for couple of minutes, power it then check..
Jan 31, 2012 | HP Photosmart C6100 All-In-One Printer
Printer Cartridge Error Message
Hi there
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
All the best Pineworks
Apr 03, 2010 | Lexmark X7170 All-In-One InkJet Printer
HP Premium C309 All-in-One Printer error message "C2FE0065"
I had a similar error (not the same! C2FE0100), and cleared it up with the following procedure:
1) While the HP logo was displayed on the screen, I unplugged the printer. 2) Plug the printer back in. 3) Immediately open the printer so you can see the ink cartridges. 4) Press the power button at least once. If yours is like mine, you see the error just by plugging in the printer, but it takes a minute or so. Pressing the power button for me just caused it to restart the boot sequence where I could get the error again. 5) Wait a couple of minutes. You should see the ink cartridge carrier move back and forth several times, and the screen will display a message telling you the ink access door is open (or similar). 6) I let it move the ink cartridges around for several minutes, but this probably isn't necessary. 7) Close the printer back up. 8) About a minute after closing the printer, it told me that I shouldn't turn it off by unplugging it, and that I should use the power button. 9) I pressed the power button once, and it shutdown. 10) I pressed the power button once, and this time it turned on without any error messages.
I was able to print a photo via bluetooth from my phone, and a short document from my computer, so it seems to be working OK.
Jan 08, 2010 | HP Photosmart Premium C309A All-In-One...
I have a error on my epson cx6400 and don't
the best way to solve the problem is to replace the printheads or
Turn the printer on and pull the plug when it starts its initialization process. Can you move the carriage by hand at this point? If not, sounds like you may have a carriage motor\belt issue.
or clear the error message.
Thanks,
Nov 18, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Error code 7410
Open the left side door, push in on the drum unit which is above the waste toner bottle until it clicks.
Turn printer off then on.
Jun 16, 2009 | Kyocera FS-2000D Laser Printer
Error message 010060
There is no mention of a fuse in the index.
I just read the manual and the SYSTEM ERROR 010060 is a Primer Motor sensor problem, Sensor might be bad, motor might not be turning, cable could have failed, or main PCA might be bad.
I uploaded the manual for you, here is the link:
http://rapidshare.de/files/47323187/HP_DeskJet_70-75-755_Service_Manual.pdf.html
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 19, 2009 | Office Equipment & Supplies
Epson Stylus Photo RX600 Error Message
It does mean that there is a problem, it may be caused by paper stuck inside, or cartridges not well placed, cartridge sensor dirty, or an internal fault.
  • Remove both cartridges.
  • Unplug printer powe cord and usb cable.
  • Wait ten minutes and plug back power.
  • After printer has cycled and is on plug back USB.
  • Start again procedure for replacing cartridges.
Check also that there is no paper inside, and that the cartridge contact inside the carriage is not dirty, in that case clean it with cotton and alcohol.
Jan 30, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
Error message on lexmark printer
900 Service RIP errors are usually a firmware failure. Upgrade to the latest firmware from Lexmark. This link is for the C52X network model:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Aug 07, 2008 | Lexmark C522n Laser Printer
Stepping motor error
Turn off the machine, pull the embroidery unit to the left a couple of inches and to the back a couple of inches. Don't force it if it won't go. Turn on the machine and see if it will reset. If does everything should be okay. If the problem is not solved, it's time for a trip to the Dealer.
sewman7
May 24, 2008 | Sewing Machines
My printer is not printing
My printer at work kept saying it was low on black toner. I finally replaced when I got the message Black toner supply error. I gave it a minute or two to adjust itself and when that didn't work, I turned off for about ten seconds and then restarted it. I've only had two problems with this printer and I have had to turn it off both times before it would work perfectly, if that helps anyone.
Nov 05, 2007 | Samsung CLX 3160fn All-In-One Printer
Lexmark X83 All-In-One InkJet Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
