Question about Yamaha HTR-5550 Receiver
HTR-5550 will shut-off after an hour of operation
The protection circuit kicks in after one hour approximatly even if it has been used at very low output power. It is certantly not too much current drawn by the speakers. What electronic components could be at fault. I know a bit the electronics and I could repair the faulty component if I could know what it is. I have no circuit diagram to refer to. Faulty capacitor?
  • 1,512 Answers
Hi Guillot
I would be checking about the regulator and power output stages for dry solder joints. With the progressive heating of the unit from operation, failing solder joints may be causing a condition to occur that operates the protection circuit. Careful inspection under good light is required. You may find soldering around outputs, drivers and other devices mounted on heat sinks or other devices that run hot to have circular fractures in the solder about the lead to be commonly responsible for the problems you are facing., if you have a soldering suitable iron, and the time and patience, go for it. I have included a link to a soldering guide here.
Good luck, thanks for using FixYa, and a rating of FixYa would be great for my time to address your problem. Cheers
regards
Graeme
Posted on Mar 16, 2008
My HTR 5460 won't stay on
try pressing power while holding the 'fm/am' and 'input mode' buttons. This will tell you what part of the circuit is making it shut down. It should show something like I PROTECT, PS PROTECT, etc.
Jan 10, 2013 | Yamaha Audio Players & Recorders
First My sister inlaw has a 3/4 recirc line. used the by pass h&c under last faucet to use cold as recircu line. Note acutal 3/4recirc is in kitchen but even thou closer to water htr. it is last for...
I don't understand everything being asked, so add a comment any time.
Problem1 is excessive electric bill.
Suspect is new 120Volt Taco recirculation pump.
Look at motor nameplate for amps and watts and HP. Taco pump is usually robust 1/3 HP which is 252 watts or same as running four 60 watt light bulbs.
If pump runs 18 hours per day x 252 watts = 4536 watts or 4.5 Kilowatts per day
Buy a kill-o-watt meter that plugs into outlet, and plug Taco pump into the meter for 48 hours.
This will give you total watts used for that time period.
1000 watts = 1 kilowatt.
Electric bill is probably 12 to 20 cents per kilowatt.
So if Taco uses 4.5 kilowatts per day, that is $.54 to $.90 per day multiplied by 30 days.
So cost is $15 to $30 per month.
Problem2 is Taco runs too long.
Taco operates either by thermostat or by timer. You choose which mode by using slide switch that is usually located under the timer dial. Set switch to TIMER to use timer, and ON to use thermostat, and off to turn TACO off.
If Taco is set for thermostatic operation, the Taco might be defective. Or there could be crossover problem at single handled faucet.
Another problem could be air in the water line: install air vent.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/How-to-set-timers.html
Jul 17, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
Speakers work at low volume. Around -39 db, receiver shuts off.(protection mode) Tried moving speaker wires, alternating red and black. No go. When powered back up, display says ck sp wires. Once I...
Decibels correspond to the output voltage being sent to the speakers. In your case, the voltage is reached at -40dB is the threshold that causes whatever is happening to operate the receiver's protection circuit. You might have a bad speaker, with a voice coil that shorts at the higher voltage. Below that level it's okay, but at the magic point the insulation breaks down, and that's when the receiver sees trouble.
You might try connecting only one speaker at a time using a short length of wire other than your current ones. If the trouble occurs on one speaker only, you've found the culprit. If the receiver operates normally on each speaker, try reconnecting one speaker at a time to determine if one of the speaker wires may have a short somewhere. There might be a weak spot in the insulation, not causing any trouble until the voltage is high enough.
If the receiver still goes into protection with just one speaker, there's an internal problem. Some part in the amplifier may be breaking down at that voltage. Or a part value has changed, causing the protection circuit to kick in even though there's really nothing wrong. Bad solder connections may have developed. Unfortunately, this kind of problem usually needs the services of a shop with the equipment and circuit information to figure out what's happening. If you can find a Yamaha-authorized warranty servicer, they might already know some typical causes if they've seen units with the same trouble.
Try the speaker test first. Then let a shop tackle the receiver if it looks like that's where the fault is. Good luck and thanks for using Fixya!
Jun 03, 2011 | Yamaha HTR-5830 Receiver
Htr 5630 shut off in 2 sec.
Sounds like you have a bad amp IC or transistors.
When these go bad they almost always put roughly 40 volts dc from the amp power supply to the speaker terminals. The protection circuit senses this dangerous (to your speakers) dc voltage and disconnects the speaker terminals from the amp via internal relays (the ones you hear click) and puts it into protect mode. If it didn't the dc voltage would quickly toast the voice coils of the connected speaker.
Apr 18, 2010 | Yamaha HTR-6130 Receiver
Yamaha htr 5550 stereo receiver blank display. It
I would suggest a quick resoldering of the flatcable connectors, both on the display board as well as on the main board. That should fix the problem.
Oct 20, 2009 | Audio Players & Recorders
Turns off after a few minutes
Sounds like a possible power short, especially if you have speaker cables connected to the receiver but not to speakers -- leaving the ends more likely to short (even via a single thin copper strand across a millimeter or two, when the voltage peaks). The receiver's message says "Check Spkr Cables," right? (They do mean the Speaker Cables!) Most receivers have a built-in power overload detection/protection shut-off circuit to save you from such mistakes.
Jul 18, 2009 | Yamaha HTR-5850 Receiver
Hd 52w59 how to disable shutdown protection circuit
You never want to disable protection circuits. They are designed to detect malfunctions and prevent further damage by shutting down the power. Trying to defeat this may render the unit useless or a fire hazard. Have unit serviced
Aug 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
HTR-5550 will not stay on.
jerry ...
question??? before you stored the unit, was it working fine?
are you using the same sets of speakers like before?
Mar 15, 2008 | Yamaha HTR-5550 Receiver
Shuts off everytime i turn it up pass 4.
Speaker wire contact with each other is the problem. Check the back of ALL SIX speakers including sub-woofer. You should find wires contacting each other. Fix that and your problem will be solved.
Barry Scholles
Strasburg, OH
Sep 04, 2007 | Yamaha HTR-5240 Receiver
Yamaha HTR-5550 Receiver Logo
171 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
