SkyScan 86709 Atomic Wall Clock Logo
Posted on Apr 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a sky scan atomic clock model 86715. it does not adjust when we have the time change. What can I do to correct the time.
Anonymous
Level 3:
President:
  • Master 2,761 Answers
  • Posted on Apr 04, 2010
Anonymous
Master
Level 3:
President:
Answers
2761
Questions
Helped
933534
Points
7369
If this model has a DST switch on the back, make sure that it's turned ON. If there's no DST switch you can force a manual change by changing the time zone setting, but you'll need to do that twice a year. Also note that if the clock is more than two years old, turning the DST switch ON will make the clock conform to the old DST changeover dates.
Bill B
Help setting time and date on Model # 86715 atomic clock
My father-in-law and his caregiver had a problem with one of these atomic clocks. They could not figure out how to set the time. I studied it and found the time zone setting on the back. It was very tiny printing and he could not see it. They had set it to Mountain time accidentally. He is eastern. I moved it to Eastern and it took the clock about 10 minutes to completely move around to the correct time. Other than changing the time zone there was no other way to set the time.
Nov 09, 2018 • Home
How do I reset the clock following battery change.
Please go to your browser and type in the information line Atomic Clock directions. All of the companies that produce this type of clock are listed. I believe SKY Scan has its directions ready to be opened when clicked on! GOOD LUCK!
1helpful
4helpful
2answers
2helpful
AI can't figure out how to set the atomic clock
This clock will set it's self in a 24 hour time frame. You need only set the time zone your in.
If it does not correct it;s self change walls and location in your house.
The transmitter is located in Fort Collins, Colorado. this station transmits the time codes and is best received at night.
Hope this tip helps.
R/
David
1helpful
How to adjust settings on skyscan atomic clock model 86715
I just fooled around with the settings on the back of the clock and now I think I have it. It may or may not work.
41helpful
3answers
How do I reset my skyscan 86715 atomic clock?
SkyScan 86715:
>Press "SET" once,
>>press "+" until you see your time zone;
-4 ATL-Atlantic
-5 EST-Eastern
-6 CST-Central
-7 MST-Mountain
-8 PST-Pacific
-9 ALA-Alaska
-10
-11
-12
-6MT-?
>Press "SET" once,
DST ON/Off
>Press "SET" once,
US - duh, huh
F - MER-Mercredi, French
E - MIE-Miércoles, Spanish
>Press "SET" once,
>>press "+", for correct hour
>Press "SET" once,
>>press "+", for correct minute
>Press "SET" once,
Range 00-20; 09 = 2009
>Press "SET" once,
Month
>Press "SET" once,
Day
>Press "SET" once,
Day of the Week
>Press "SET" once,
12 or 24 hour
>Press "SET" once,
Fahrenheit or Celsius
>Press "SET" once again - DONE!!!
The clock should now display "month/day/day of the week/moon phase/Temperature"
NOTE: Moon phase and Seconds will correct on first reception from Coordinated Universal Time (UTC)
Lastly,
Press "+" once,
Temperature changes to seconds
>>Press "+" once,
Temperature returns on right-most panel and
seconds replaces day of the week.
>>Press "+" one last time and you are back to done!!!
Thanks,
[email protected]
1helpful
Atomic clock sky scan model 87801
Press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time. kindly gave your rating after you read this.
Top SkyScan Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a SkyScan Home Expert? Answer questions, earn points and help others
