Question about Samsung HCN5527W 55" Rear Projection Television
Picture adjustment?? I have a lady who is trying to sell me her Samsung HCN5527W for $75. However, she says the picture needs to be adjusted.... Any idea what that means?? Is that something they all have to have done or is it gonna be a costly repair? ANY help is greatly appreciated....
You may need to adjust the convergence check to see if you can move the alignment squares
Posted on Apr 09, 2008
What are the best picture calibration settings for the sony 4k xbr65x850a tv
Brightness to 40 > 50%, Contrast to 65 > 75% & Color to 30 > 35% must give a good picture. First, try to adjust a good B/W picture, by adjusting the brightness and contrast. After you have got a good picture in B/W, then advance the color intensity, according your viewing taste. Gopakumar Gopalan Google
May 30, 2014 | Televison & Video
How can I adjust the height of the HP LP2465 24" LCD Monitor?
MOST OF THE TIME THEY WILL NOT ADJUST UP AND DOWN. LOOK FOR A SMALL LEVEL AT THE BOTTOM OF THE BASE OR JUST BEFORE THE BASE. I JUST GOOGLE IT AND FOUND PICTURE OF IT.
May 21, 2014 | HP LP2465 24" LCD Monitor
Samsung tv calibration
You're asking about the picture settings to this TV; I assume, and posts this solution. Just set it to user mode; in terms of picture; set the Color to minimum (0); Contrast = 70 ~ 75%; Brightness to 30 ~ 40%. In this way, just set a picture in Black/White first. If you see that the contrast or brightness level should be adjusted to get a good B/W picture, do it according to your viewing taste. After set this, advance the color; and compare the skin tone of a news reader at the studio.
In most cases, this must be the perfect adjustment. If you wish to get more details to picture, advance the Sharpness control. Do not set it too more. Less than 30% will be sufficient. If the broadcasting system is NTSC, you have to adjust the Hue too.
Apr 18, 2014 | Televison & Video
Samsung model number HCN5527W THE PERFECT FOCUS ONLY GOES UP TO 4 PERCENT THEN STOPS THE PICTURE IS HAZEY
You have failed convergence IC's, Have the convergence IC's replaced on the convergence board, Replace them both they are the Large Black IC's mounted on large heatsinks usually mounted on a seperate board above the bottom main boards, The Part # for the IC's are STK-392-040
Nov 23, 2009 | Samsung HCN5527W 55" Rear Projection...
The picture does not fit the screen. The top and bottom of the picture go beyond the screen
you may need to adjust the aspect ratio of the picture, there is typically an "aspect" button on the remote that will adjust the picture from widescreen, super widescreen 16:9 ratio and sometimes you can zoom in. try that
Sep 20, 2009 | Samsung Televison & Video
Samsung wide screen HCN5527W tv reset
My Samsung model PS42P3SX/XWU has no sound coming from it from the Sky+ box, just picture. Was working then stopped. DVD connection is ok.
Jun 21, 2009 | Samsung Televison & Video
Bowed picture and color misalignment
Replace both STKS ICs Ck low ohm resistors 2.7ohms most of the time there will be 2 of them bad.
Jun 11, 2009 | Samsung HCN5527W 55" Rear Projection...
12 yr. old 25" G.E. picture fading
I gotta love it when people make up answers. There is no such thing as a "contrass module". I'm assuming the poster meant "contrast". The trouble is your 12-year-old picture tube. It's gotten weak and isn't getting as bright or sharp as it used to. Picture tube manufacturers estimate the useful life of a tube at about 7 years today. There are adjustments inside that might help some, but you need a new picture tube. It's going to cost a lot more than $60 to $75 for that. You're better off replacing the TV.
Apr 22, 2009 | GE 25GT240 25" TV
Picture Bowed
Try replacing the convergence IC's w/Panasonic STK392-040 for durability,then perform servicer mode convergence alignment procedure.Last,check customer adjust conv. alignment.
Apr 15, 2007 | Samsung HCN5527W 55" Rear Projection...
Samsung HCN5527W 55" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
