Question about Bosch 23 in. SHU33A Built-In Dishwasher
PROBLEM WITH WATER CYCLES MODEL SMI7056US
Every time we put the dishwater on we have to vacuum the water from the pan so that it begins the cycle. At the rinsing cycle, we repeat the same procedure until it ends the complete cycle. We have already changed the water inlet valve a few times and the floating switch as well. The control pcb panel smells burnt at times. We have the new board and would like some guidance as to how to replace it. If you have other suggestions please fell free to inform us.
  • zeus_2 Mar 16, 2008
    we are interested in buying the service manual. However we want to be sure that it is the one for our model SMI7056US
    Genius:
  • 3,587 Answers
Sounds like the relays are cooking on that..does the underside of the machine look clear?
the top panel is easy to remove, and the board is simple too..
make sure power is off, of course
I'll check for resources for service information
Posted on Mar 16, 2008
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels Mar 16, 2008
  • Patrick Michaels
    when you go there, you'll be able to enter as much information as you have...I have nada to do with these folks, but there seems to be some good stuff there..
  • Patrick Michaels
    sounds cool..call em too to find out about the serial number..thankya for using fixya
Stuck in drain cycle
Hello Vicki. If the drain pump sounds like it is running and will not shut off, you are on "flood mode" There is standing water in the bas pan of the dishwasher. sometimes water can get down there due to an overfill, or not draining completely between cycles. You can either wait for 2 or 3 days and the water will evaporate and should run normally. You can remove the bottom access panels and either vacuum out of dry the water (REMOVE POWER FIRST !) . If it does not clear on its own or if removing the water manually does not work, then the float switch will need to be replaced that activates the flood mode. There is a small possibility you have a bad control .
Apr 09, 2014 | Viking DFUD142D Built-in Dishwasher
Reset dishwater
No fill..no water..
Check the problem on the filling section...
The machine should fill first of all and after this to run in any of the cycles.
Can be..solenoid for fill.
the water line is close :)
the drain solenoid is broken and all the water is draining
Good luck
Jun 30, 2013 | Bosch Dishwashers
What doesn't my dishwater finish its cycle?
What is the make and model number
Jun 09, 2013 | Dishwashers
What is the float switch
I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
Feb 21, 2012 | Beko 24 in. D3421F Free-standing...
No water during any cycle.
if no water is coming in how is it agitating?is it filling at the beginning,then it starts to wash the clothes,now does it drain and then it won't fill again,send the model number and more info,
Jul 02, 2010 | Kenmore 24032\24036 Top Load Washer
My refrigerator leaking water its filling up the water
the water pan is a catch for the defroster.When the defrost timer cycles it heats an element in the freezer that thaws ice bulid up and a drain hose deposits the water in the pan.
Dec 23, 2009 | Whirlpool Refrigerators
WHY DON'T DISHES DRY? MODEL ADW1100N10WW
water tempt too low . use longer cycles like pot & pans . if d/w has a heater turn it on . always run tap at sink till water is hot then start dw . this is a common problem it's probably not the dishwasher . but how ou are setting the cycles .. mm hope this helps . feed back pls ..
Dec 22, 2009 | Dishwashers
Inch of water left in bottom of dishwater after done running
check for blockage starting at air gap and disposer.trace back and clean
Dec 31, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Dishwater odor
Lots of ideas,,, Try cycling the dishwasher without dishes on the hottest setting and about 10 miutes into that cycle..stop it and add 2 ups of white vinegar to the water.. let it complete the cycle..
The problem is that standing water with food byproducts will begin to smell as they break down. Like all dishwahers, there is always a small amount of water that remains in the drain system at all times so it is important to clean the filter trap and to periodically air it out or use the white vinegar method..
Hope this helps you...
Sep 23, 2008 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Not enough water in tub
Mderford, on a normal fill, the water should be just above the filter screen. 1.8 gallons first fill, 1.7 on all other fills. Don't think it would be a siphoning problem as you are not having this on the pots/pans. Check the float, make sure it is not sticking. You can check the inlet valve filter screen to see if it is not plugged. Run it through the diagnostics cycle by pushing high temp-air dry-high temp-air dry. Some models it's heated dry-normal-heated dry-normal. It will run through a self test for about 20 minutes. See if any error codes come up. Fill time should be approx. 1:30 to 1:40 seconds. If any of the aformentioned doesn't turn up any results, then it's possibly a faulty fill valve drive circuit on the control itself...Catriver..post back.
Oct 02, 2006 | Whirlpool 24 in. DU900PCD Built-in...
Bosch 23 in. SHU33A Built-In Dishwasher Logo
164 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
