Question about Olympus Stylus 700 / 700 Digital Camera
Olympus 700 all-weather 7.1 mp
I have the same problem with Louise..
When I turn on, the lense came in and out so on and so fort..
The Screen is blurry and sometimes display the last picture taken
Can I have the best solution please send it to [email protected]
thank you very much.
Please help me coz this cam is not mine, I just borrowed it
I was shocked because I did'nt expect that it,s as sensitive like this..
  • n1414r Aug 08, 2008
    The lense of my camera goes in and out many times when power is on. Screen is also blurry. I try to take a picture and picture is blurry. It worked well one day then this started happening the next day.  I thought it was the battery so I made sure it was charged and same problem. Can't seem to come up with a solution. Went to menu and didn't help much. I do not have my guide with me because I am in vacation. Can you help me? Respond to [email protected] Thanks!
  • 4 Answers
Try turning to the guide and it will change the settings for you, as you step through the settings it offers.
Very smart camera!
Posted on Apr 17, 2008
SOURCE:
I can't turn my camera on,I press the power button,it gives me a whirling noise,the lenses come out(but not all the way),the picture on the screen is blurry,and I can't make a shot,and after2 seconds the...
sounds like it might have got a bang,you'll have to take it to the shop,make sure you get a quote before you get any repairs done,camera repairs can be expensive.
Mar 18, 2010 | Olympus Stylus 700 / 700 Digital Camera
I would like a manual for my digital camera
http://www.retrevo.com/s/Olympus-700-Digital-Cameras-review-manual/id/203ci155/t/1-2/
You can find it there, please download the pdf reader here www.adobe.com if you want to read and print the manual, Thanks and rate
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 22, 2009 | Cameras
The camera may be faulty or it needs to be reset to the factory settings.
Try removing the battery leave it out for at least 1/2 hour, then replace the battery.
If it doesn't work then you need a new camera.
Nov 27, 2008 | Olympus Stylus 700 / 700 Digital Camera
OLYMPUS DIGITAL ALL WEATHER
1) Make sure that the batteries are in good condition
2) Check and clean any dirt or corrosion from the battery terminals.
If the power supply voltage suddenly drops during initialization,
or when the lens is trying to extend itself, it could produce this
kind of error.
3) Make sure that the lens extension tubes are not mechanically
jammed.
4) Remove the batteries, turn the unit ON and wait for it to fully
discharge any internal capacitors, then put the batteries back
and try to turn the unit back on. This should fully RESET the
internal CPU.
Generally this kind of error means that the camera's internal
computer is trying to activate the lens zooming motors, but
the motors fail to move as expected.
Other causes could be:
a) burned out ZOOM motors
b) burned out motor drive circuitry
c) bad motor positioning sensor
d) defective computer components
e) failed internal firm-ware.
none of these cause are user fixable.
Hope this helps
Martin
Nov 10, 2008 | Olympus Stylus 700 / 700 Digital Camera
OLYMPUS STYLUS 740 ALL WEATHER
If it works, use it as long as you can.
Fixing snap-shooters is generally not worth it,
since digital cameras evolve rapidly and lose
value even faster with age.
Martin
Nov 09, 2008 | Olympus Stylus 700 / 700 Digital Camera
My camera an olympus stylus 700 all-weather 7.1 megapixel, isn't turning on. When the on button is pressed the zoom comes out/in/out making a grinding sound, the screen shows a none focused image until a...
If the camera is still under warranty then return it.
If it is out of warranty then replace it
There is not a likely repair option
Though Olympus Customer support may advise another remedy
Jul 30, 2008 | Cameras
No sound when making video clips
Yes there is an option to turn the sound off, so you can take up less space on the memory card. Try turning to the video clips on the dial then push the menu button for options!
Nov 05, 2007 | Olympus Stylus 700 / 700 Digital Camera
Blue screen error code
the lens open halfway, the picture on the LCD is blurry and one second after the lens close and an error appears of the screen saying "D: 5f08 5e02". what does this mean??? can you help me fixed this one??
Oct 13, 2007 | Olympus Stylus 700 / 700 Digital Camera
Camera screen turns blue when turned on
Return it anyway if you have proof of purchase. Definately a dud camera to fail this early
May 09, 2007 | Olympus Stylus 710 Digital Camera
Olympus Stylus 700 / 700 Digital Camera Logo
143 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
