Question about Video Game Consoles & Games
My hdmi isn't working can you help me - Video Game Consoles & Games
  • Anonymous May 19, 2009
    I had my HDMI cable hooked up to my 32 inch 1080P Panasonic TV from my PS3, it worked for a little and then the screen would blink off and on. It got worse that the screen blinked off and stayed off. I tested the theory on my 32 inch tv downstairs and plugged it up as well. The screen did the same thing. I changed out the cable and still had the same problem. I changed out the cable 3 times. I hooked it back up with my universal HDTV cables and it works fine. I believe my HDMI port in my PS3 is bad
HDMI isin't working for Ps3
Posted on Dec 03, 2009
Why isn't my HDMI port working on my Acer Laptop?
Either there is motherboard damage or the system drivers are not loaded for the motherboard.
Feb 18, 2016 | Acer Computers & Internet
HDMI no longer working as pass through for Comcast and Tivo
sounds like your digital board is going bad. Is the unit still under warranty?
Jul 29, 2013 | Marantz Audio Players & Recorders
Vga isn't working
what component input did you use in the tv, the hdmi or vga port?.might not compatible video resolution of the pc to the tv.
Nov 28, 2012 | Protron PLTV-32 Television
My ps3 console signal isn't working but the sound works but there is no signal! not even a hdmi cable works help!
Try these tips to fix the so-called "black screen of death".
Tip 1: The main reason of HDMI black screen problem due to HDMI cable may be damaged and not properly connected to the PS3 console. Please follow below step to troubleshoot PS3 HDMI cables problem:
1) Restart your PlayStation 3.
2) Look for loose cables.
3) Try to unplug all cables except the power cord, and plug them back in. If you found out that your HDMI cable is damaged, borrow a friends cable and try it. If your friends cable works fine, and the black screen error disappears. Then you can buy a brand new HDMI cable for a replacement.
Tip 2: Only try as last resort. There is a possibility you'll lose all data on your PS3's hard drive. If tip 1 didn't work, you will need to go a step deeper and reset your console. Most PS3 gamers are not aware that Sony actually included a black screen of death troubleshooting method and other HDMI problems in the PS3 manual, you can find it under the troubleshooting section - topic "console reset".
If you do it correctly, the console reset fix will allow you to reset back your PS3 to its default HDMI settings without impacting your gamer profile, and other storage data on the hard drive.
You will need to perform the following steps:
1. Place your PS3 in stand-by mode.
2. Hold down the touch power button until a series of beeps are heard.
3. Listen for one long beep, followed by two shorter beeps.
4. Release the power button.
5. Follow the instructions on screen.
If it works you should be good to go.
May 20, 2012 | Sony Playstation 3 (PS3) Console
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
I cant get my mic too work in the rear port ..any suggestions ?
are you sure it is plugged into the "Green" jack? Doublecheck, and make sure it isn't muted in Volume control
Aug 30, 2011 | ASUS M4A88TM LE AM3 AMD 880G HDMI Micro...
I am streaming netflix from my Nintendo Wii to TV. Is there an after market HDMI cable that I can run from Wii to Denon Stereo to get sound through receiver?
Hello, although there are not official wii to HDMI output cables, there are in fact some cables that are provided by third party handlers that will work.
For instance THIS product is a simple little converter which you put into your wii output and connect a regular HDMI cable.
KEEP IN MIND: This isn't a HDMI cable, you need to have a HDMI cable or buy one to use it with this product.
Jun 14, 2011 | Nintendo Wii Console
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
Cannot connect my PS3 to Panasonic TV via HDMI, my PS3 will connect to other HD TVs using HDMI but not Panasonic
Does your TV work on VGA, it maybe worthwhile getting a HDMI---VGA lead and try that as it sounds like your TV isn't working, and you've tried the obvious. Do any other HDMI devices work on your TV, like DVD HD/SAT?
Apr 22, 2011 | Televison & Video
Video Game Consoles & Games Logo
844 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
