Question about Mitsubishi WT-46809 46" Rear Projection Television
Fine Yellow Lines
In addition to the bowtie effect that others are talking about, I have fine yellow lines running across the screen. Any ideas as the the problem and the solution? Will repairing the convergence issue also take care of this?
  • 373 Answers
The lines I believe are retrace lines (if I interpert correctly) and may or may not be corrected by turning down the screen controls red green and blue. But first I would see if the 200V source that feeds the video outputs on each crt board is there or low. If so the problem would be a resistor or 200-250V capacitor that feed them. (200V source usually off the HV transformer secondary.
Posted on Mar 16, 2008
Horizontal black and yellow lines across pages any mode
I have the same issue. It would be great if someone had an idea how to address, as Samsung has no idea.
Feb 15, 2014 | Samsung CLX-3175FN Color Laser All-in-One...
Gv471 fhdtv10a
help my pliss
Feb 07, 2014 | Televison & Video
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Blue curved line at top of screen and yellow curved line at botto
Do you by chance have any speakers sitting on top of the tv or right beside it. Speakers are unshielded and will cause this effect.
Feb 03, 2009 | Televison & Video
Hp 5550dn ( I am getting a 49.2fcc and 49.4b1a error
Upgrade firmware on the printer as a first step, 49 errors are often an issue with firmware
Nov 12, 2008 | HP LaserJet 5550DN Printer
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
Thin red horizontal lines across screen
replace the focus block or try to adjust the screen control on the focus block for red only. this will affect the white balance of the set so adjust it carefully. the focus block is located on the front inside the set. remove the speaker cover then the 4 screws on the front plate. the focus block is 3" x 2" black box with 6 adjustment posts three for focus and three for screen. adjust only the affected screen (R).
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
P42W46X Zenith Plasma - No Picture - Mostly Yellow on screen
Mine looks like too, but the line running across isn't on my set, picture looks like this, and the sound works fine. I took the tuner board all the way out and turned the set on and it did the same thing, then I unplugged the top wire on the board next to the tuner board and the screen went black. plugged it back in and the screen came back with the scrambled picture. Anyone know why? Bad mainboard maybe? the left of the tuner board?
Nov 25, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Yellow and blue lines on 245BW
well, my monitor is going back to samsung for a replacement unit. I plugged in my monitor in a bunch of other PCs and it's doing the same thing regarless of the PC or graphics card I use. Now I know it's the monitor. Getting it RMA'd with Samsung. Only had it for 18 days. Hope they send me a new one and not a refurb.
Nov 21, 2007 | Samsung SyncMaster 245BW Monitor
Vertical colored lines
I had the same problem with my monitor, saw only coloured vertical lines. I opened it, opened the back of the metal casing to get access to the circuits. There I found a loose connector. I reset it and it worked again!
Aug 06, 2006 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Mitsubishi WT-46809 46" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
